[PATCH v2 8/9] rtems: Add rtems_message_queue_construct()
    Sebastian Huber
    Fri Sep 25 09:51:31 UTC 2020
In contrast to message queues created by rtems_message_queue_create(), the
message queues constructed by this directive use a user-provided message buffer
storage area.
Add RTEMS_MESSAGE_QUEUE_BUFFER() to define a message buffer type for message
buffer storage areas.
Update #4007.
 cpukit/Makefile.am                       |   2 +
 cpukit/include/rtems/rtems/message.h     | 131 ++++++++++++++++
 cpukit/include/rtems/rtems/messageimpl.h |  17 ++
 cpukit/include/rtems/score/coremsg.h     |  10 ++
 cpukit/include/rtems/score/coremsgimpl.h |  67 +++++++-
 cpukit/posix/src/mqueueopen.c            |   4 +-
 cpukit/rtems/src/msgqconstruct.c         | 189 +++++++++++++++++++++++
 cpukit/rtems/src/msgqcreate.c            | 178 +++++----------------
 cpukit/score/src/coremsg.c               |  17 +-
 cpukit/score/src/coremsgclose.c          |   7 +-
 cpukit/score/src/coremsgwkspace.c        |  53 +++++++
 spec/build/cpukit/librtemscpu.yml        |   2 +
 testsuites/sptests/sp13/init.c           |  21 ++-
 testsuites/sptests/sp13/system.h         |   2 +-
 14 files changed, 539 insertions(+), 161 deletions(-)
 create mode 100644 cpukit/rtems/src/msgqconstruct.c
 create mode 100644 cpukit/score/src/coremsgwkspace.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index e2bed4b844..2c35354e66 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -706,6 +706,7 @@ librtemscpu_a_SOURCES += rtems/src/intrcatch.c
 librtemscpu_a_SOURCES += rtems/src/modes.c
 librtemscpu_a_SOURCES += rtems/src/msg.c
 librtemscpu_a_SOURCES += rtems/src/msgqbroadcast.c
+librtemscpu_a_SOURCES += rtems/src/msgqconstruct.c
 librtemscpu_a_SOURCES += rtems/src/msgqcreate.c
 librtemscpu_a_SOURCES += rtems/src/msgqdelete.c
 librtemscpu_a_SOURCES += rtems/src/msgqflush.c
@@ -839,6 +840,7 @@ librtemscpu_a_SOURCES += score/src/coremsgflushwait.c
 librtemscpu_a_SOURCES += score/src/coremsginsert.c
 librtemscpu_a_SOURCES += score/src/coremsgseize.c
 librtemscpu_a_SOURCES += score/src/coremsgsubmit.c
+librtemscpu_a_SOURCES += score/src/coremsgwkspace.c
 librtemscpu_a_SOURCES += score/src/coremutexseize.c
 librtemscpu_a_SOURCES += score/src/percpu.c
 librtemscpu_a_SOURCES += score/src/percpuasm.c
diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
index 675cd98acc..14083b8cd0 100644
--- a/cpukit/include/rtems/rtems/message.h
+++ b/cpukit/include/rtems/rtems/message.h
@@ -21,6 +21,7 @@
 #include <rtems/rtems/options.h>
+#include <rtems/score/coremsgbuffer.h>
 #ifdef __cplusplus
 extern "C" {
@@ -36,6 +37,136 @@ extern "C" {
+ * @brief This structure defines the configuration of a message queue
+ *   constructed by rtems_message_queue_construct().
+typedef struct {
+   * @brief This member defines the name of the message queue.
+  rtems_name name;
+   * @brief This member defines the maximum number of pending messages supported
+   *   by the message queue.
+  uint32_t maximum_pending_messages;
+   * @brief This member defines the maximum message size supported by the message
+   *   queue.
+  size_t maximum_message_size;
+   * @brief This member shall point to the message buffer storage area begin.
+   * The message buffer storage area for the message queue shall be an array of
+   * the type defined by RTEMS_MESSAGE_QUEUE_BUFFER() with a maximum message size
+   * equal to the maximum message size of this configuration.
+  void *storage_area;
+   * @brief This member defines size of the message buffer storage area in bytes.
+  size_t storage_size;
+   * @brief This member defines the optional handler to free the message buffer
+   *   storage area.
+   * It is called when the message queue is deleted.  It is called from task
+   * context under protection of the object allocator lock.  It is allowed to
+   * call free() in this handler.  If handler is NULL, then no action will be
+   * performed.
+  void ( *storage_free )( void * );
+   * @brief This member defines the attributes of the message queue.
+  rtems_attribute attributes;
+} rtems_message_queue_config;
+ * @brief Defines a structure which can be used as a message queue buffer for
+ *   messages of the specified maximum size.
+ * Use this macro to define the message buffer storage area for
+ * rtems_message_queue_construct().
+ * @param _maximum_message_size is the maximum message size in bytes.
+#define RTEMS_MESSAGE_QUEUE_BUFFER( _maximum_message_size ) \
+  struct { \
+    CORE_message_queue_Buffer _buffer; \
+    char _message[ _maximum_message_size ]; \
+ * @brief Constructs a message queue from the specified the message queue
+ *   configuration.
+ * In contrast to message queues created by rtems_message_queue_create(), the
+ * message queues constructed by this directive use a user-provided message
+ * buffer storage area.
+ * This directive is intended for applications which do not want to use the
+ * RTEMS Workspace and instead statically allocate all operating system
+ * resources.  An application based solely on static allocation can avoid any
+ * runtime memory allocators.  This can simplify the application architecture
+ * as well as any analysis that may be required.
+ * The value for #CONFIGURE_MESSAGE_BUFFER_MEMORY should not include memory for
+ * message queues constructed by rtems_message_queue_construct().
+ * @param config is the message queue configuration.
+ * @param[out] id is the pointer to an object identifier variable.  The
+ *   identifier of the constructed message queue object will be stored in this
+ *   variable, in case of a successful operation.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_INVALID_ADDRESS The id parameter was NULL.
+ * @retval ::RTEMS_INVALID_NAME The message queue name in the configuration was
+ *   invalid.
+ * @retval ::RTEMS_INVALID_NUMBER The maximum number of pending messages in the
+ *   configuration was zero.
+ * @retval ::RTEMS_INVALID_SIZE The maximum message size in the configuration
+ *   was zero.
+ * @retval ::RTEMS_TOO_MANY There was no inactive message queue object
+ *   available to construct a message queue.
+ * @retval ::RTEMS_TOO_MANY In multiprocessing configurations, there was no
+ *   inactive global object available to construct a global message queue.
+ *   was too big and resulted in integer overflows in calculations carried out
+ *   to determine the size of the message buffer area.
+ *   configuration was too big and resulted in integer overflows in
+ *   calculations carried out to determine the size of the message buffer area.
+ * @retval ::RTEMS_UNSATISFIED The message queue storage area begin pointer in
+ *   the configuration was NULL.
+ * @retval ::RTEMS_UNSATISFIED The message queue storage area size in the
+ *   configuration was not equal to the size calculated from the maximum number
+ *   of pending messages and the maximum message size.
+rtems_status_code rtems_message_queue_construct(
+  const rtems_message_queue_config *config,
+  rtems_id                         *id
  * @brief RTEMS Create Message Queue
diff --git a/cpukit/include/rtems/rtems/messageimpl.h b/cpukit/include/rtems/rtems/messageimpl.h
index e317244025..c90ac97da9 100644
--- a/cpukit/include/rtems/rtems/messageimpl.h
+++ b/cpukit/include/rtems/rtems/messageimpl.h
@@ -101,6 +101,23 @@ RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Allocate( void )
     _Objects_Allocate( &_Message_queue_Information );
+ * @brief Creates a message queue.
+ * @param[out] id contains the object identifier if the operation was
+ *   successful.
+ * @param allocate_buffers is the message buffer storage area allocation
+ *   handler.
+rtems_status_code _Message_queue_Create(
+  rtems_id                            *id,
+  CORE_message_queue_Allocate_buffers  allocate_buffers
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/coremsg.h b/cpukit/include/rtems/score/coremsg.h
index 220c9839a5..51c638bcc3 100644
--- a/cpukit/include/rtems/score/coremsg.h
+++ b/cpukit/include/rtems/score/coremsg.h
@@ -124,6 +124,16 @@ struct CORE_message_queue_Control {
    *  as part of destroying it.
   CORE_message_queue_Buffer         *message_buffers;
+   * @brief This member contains the optional message buffer storage area free
+   * handler.
+   * It may be NULL.  In this case no action is performed to free the message
+  void                            ( *free_message_buffers )( void * );
   #if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
     /** This is the routine invoked when the message queue transitions
      *  from zero (0) messages pending to one (1) message pending.
diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
index cb84bfb207..0bf5fa52d0 100644
--- a/cpukit/include/rtems/score/coremsgimpl.h
+++ b/cpukit/include/rtems/score/coremsgimpl.h
@@ -68,6 +68,54 @@ extern "C" {
 typedef int CORE_message_queue_Submit_types;
+ * @brief This handler shall allocate the message buffer storage area for a
+ *   message queue.
+ * The handler shall set the CORE_message_queue_Control::free_message_buffers
+ * member.
+ * @param[out] the_message_queue is the message queue control.
+ * @param size is the message buffer storage area size to allocate.
+ * @param arg is the handler argument.
+ * @retval NULL The allocation failed.
+ * @return Otherwise the pointer to the allocated message buffer storage area
+ *   begin shall be returned.
+typedef void *( *CORE_message_queue_Allocate_buffers )(
+  CORE_message_queue_Control *the_message_queue,
+  size_t                      size,
+  const void                 *arg
+ * @brief This handler allocates the message buffer storage area for a message
+ *   queue from the RTEMS Workspace.
+ * The handler sets the CORE_message_queue_Control::free_message_buffers
+ * to _Workspace_Free().
+ * @param arg is the unused handler argument.
+ *   begin is returned.
+void *_CORE_message_queue_Workspace_allocate(
+  size_t                      size,
+  const void                 *arg
  * @brief Initializes a message queue.
@@ -81,19 +129,26 @@ typedef int CORE_message_queue_Submit_types;
  * @param maximum_message_size is the size of the largest message that may be
  *   sent to this message queue instance.
+ *   handler.
+ * @param arg is the message buffer storage area allocation handler argument.
  * @retval STATUS_SUCCESSFUL The message queue was initialized.
  * @retval STATUS_MESSAGE_QUEUE_INVALID_SIZE Calculations with the maximum
  *   pending messages or maximum message size produced an integer overflow.
- * @retval STATUS_MESSAGE_QUEUE_NO_MEMORY There was not enough memory to
- *   allocate the message buffers.
+ * @retval STATUS_MESSAGE_QUEUE_NO_MEMORY The message buffer storage area
+ *   allocation failed.
 Status_Control _CORE_message_queue_Initialize(
-  CORE_message_queue_Control     *the_message_queue,
-  CORE_message_queue_Disciplines  discipline,
-  uint32_t                        maximum_pending_messages,
-  size_t                          maximum_message_size
+  CORE_message_queue_Disciplines       discipline,
+  uint32_t                             maximum_pending_messages,
+  size_t                               maximum_message_size,
+  CORE_message_queue_Allocate_buffers  allocate_buffers,
+  const void                          *arg
diff --git a/cpukit/posix/src/mqueueopen.c b/cpukit/posix/src/mqueueopen.c
index af8abebea8..af50dc2754 100644
--- a/cpukit/posix/src/mqueueopen.c
+++ b/cpukit/posix/src/mqueueopen.c
@@ -102,7 +102,9 @@ static mqd_t _POSIX_Message_queue_Create(
     &the_mq->Message_queue,
     CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO,
     attr->mq_maxmsg,
-    attr->mq_msgsize
+    attr->mq_msgsize,
+    _CORE_message_queue_Workspace_allocate,
+    NULL
   if ( status != STATUS_SUCCESSFUL ) {
diff --git a/cpukit/rtems/src/msgqconstruct.c b/cpukit/rtems/src/msgqconstruct.c
new file mode 100644
index 0000000000..61d0472e7c
--- /dev/null
+++ b/cpukit/rtems/src/msgqconstruct.c
@@ -0,0 +1,189 @@
+ *  @file
+ *  @brief RTEMS Create Message Queue
+ *  @ingroup ClassicMessageQueue
+ *  COPYRIGHT (c) 1989-2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/messageimpl.h>
+#include <rtems/rtems/attrimpl.h>
+#include <rtems/rtems/support.h>
+#include <rtems/score/coremsgimpl.h>
+#include <rtems/sysinit.h>
+static void *_Message_queue_Get_buffers(
+  size_t                      size,
+  const void                 *arg
+  const rtems_message_queue_config *config;
+  config = arg;
+  if ( config->storage_size != size ) {
+    return NULL;
+  the_message_queue->free_message_buffers = config->storage_free;
+  return config->storage_area;
+  rtems_id                         *id
+  return _Message_queue_Create( config, id, _Message_queue_Get_buffers );
+  rtems_id                            *id,
+  Message_queue_Control          *the_message_queue;
+  CORE_message_queue_Disciplines  discipline;
+  Status_Control                  status;
+#if defined(RTEMS_MULTIPROCESSING)
+  bool                            is_global;
+#endif
+  if ( id == NULL ) {
+    return RTEMS_INVALID_ADDRESS;
+  if ( !rtems_is_name_valid( config->name ) ) {
+    return RTEMS_INVALID_NAME;
+  if ( config->maximum_pending_messages == 0 ) {
+    return RTEMS_INVALID_NUMBER;
+  if ( config->maximum_message_size == 0 ) {
+    return RTEMS_INVALID_SIZE;
+  if ( _System_state_Is_multiprocessing ) {
+    is_global = _Attributes_Is_global( config->attributes );
+  } else {
+    is_global = false;
+#if 1
+   * I am not 100% sure this should be an error.
+   * It seems reasonable to create a que with a large max size,
+   * and then just send smaller msgs from remote (or all) nodes.
+  if ( is_global ) {
+    size_t max_packet_payload_size = _MPCI_table->maximum_packet_size
+      - MESSAGE_QUEUE_MP_PACKET_SIZE;
+    if ( config->maximum_message_size > max_packet_payload_size ) {
+#endif
+#endif
+  the_message_queue = _Message_queue_Allocate();
+  if ( !the_message_queue ) {
+    _Objects_Allocator_unlock();
+    return RTEMS_TOO_MANY;
+  if (
+    is_global
+      && !_Objects_MP_Allocate_and_open(
+            &_Message_queue_Information,
+            config->name,
+            the_message_queue->Object.id,
+            false
+    _Message_queue_Free( the_message_queue );
+  the_message_queue->is_global = is_global;
+#endif
+  if ( _Attributes_Is_priority( config->attributes ) ) {
+    discipline = CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY;
+  } else {
+    discipline = CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO;
+  status = _CORE_message_queue_Initialize(
+    &the_message_queue->message_queue,
+    discipline,
+    config->maximum_pending_messages,
+    config->maximum_message_size,
+    allocate_buffers,
+    config
+  if ( status != STATUS_SUCCESSFUL ) {
+    if ( is_global )
+        _Objects_MP_Close(
+          &_Message_queue_Information, the_message_queue->Object.id);
+#endif
+    return STATUS_GET_CLASSIC( status );
+  _Objects_Open(
+    &the_message_queue->Object,
+    (Objects_Name) config->name
+  *id = the_message_queue->Object.id;
+  if ( is_global )
+    _Message_queue_MP_Send_process_packet(
+      MESSAGE_QUEUE_MP_ANNOUNCE_CREATE,
+      config->name,
+      0
+#endif
+  return RTEMS_SUCCESSFUL;
+static void _Message_queue_Manager_initialization( void )
+  _Objects_Initialize_information( &_Message_queue_Information);
+RTEMS_SYSINIT_ITEM(
+  _Message_queue_Manager_initialization,
+  RTEMS_SYSINIT_CLASSIC_MESSAGE_QUEUE,
+  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/rtems/src/msgqcreate.c b/cpukit/rtems/src/msgqcreate.c
index 20787f00a6..7469f10509 100644
--- a/cpukit/rtems/src/msgqcreate.c
+++ b/cpukit/rtems/src/msgqcreate.c
@@ -1,17 +1,37 @@
- *  @file
+ * @file
+ * @ingroup ClassicMessageQueueImpl
- *  @brief RTEMS Create Message Queue
- *  @ingroup ClassicMessageQueue
+ * @brief This source file contains the implementation of
+ *   rtems_message_queue_create().
- *  COPYRIGHT (c) 1989-2014.
- *  On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
@@ -19,17 +39,9 @@
 #endif
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/attrimpl.h>
-#include <rtems/rtems/options.h>
-#include <rtems/rtems/support.h>
-#include <rtems/score/sysstate.h>
-#include <rtems/score/chain.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/sysinit.h>
+#include <string.h>
 rtems_status_code rtems_message_queue_create(
   rtems_name       name,
@@ -39,123 +51,17 @@ rtems_status_code rtems_message_queue_create(
   rtems_id        *id
-  Message_queue_Control          *the_message_queue;
-  CORE_message_queue_Disciplines  discipline;
-  Status_Control                  status;
-#if defined(RTEMS_MULTIPROCESSING)
-  bool                            is_global;
-#endif
-  if ( !rtems_is_name_valid( name ) )
-    return RTEMS_INVALID_NAME;
-  if ( !id )
-    return RTEMS_INVALID_ADDRESS;
-  if ( _System_state_Is_multiprocessing ) {
-    is_global = _Attributes_Is_global( attribute_set );
-  } else {
-    is_global = false;
-#endif
-  if ( count == 0 )
-      return RTEMS_INVALID_NUMBER;
-  if ( max_message_size == 0 )
-      return RTEMS_INVALID_SIZE;
-#if 1
-   * I am not 100% sure this should be an error.
-   * It seems reasonable to create a que with a large max size,
-   * and then just send smaller msgs from remote (or all) nodes.
-  if ( is_global ) {
-    size_t max_packet_payload_size = _MPCI_table->maximum_packet_size
-      - MESSAGE_QUEUE_MP_PACKET_SIZE;
-    if ( max_message_size > max_packet_payload_size ) {
-#endif
-#endif
-  the_message_queue = _Message_queue_Allocate();
-  if ( !the_message_queue ) {
-    _Objects_Allocator_unlock();
-    return RTEMS_TOO_MANY;
-  if ( is_global &&
-    !( _Objects_MP_Allocate_and_open( &_Message_queue_Information,
-                              name, the_message_queue->Object.id, false ) ) ) {
-    _Message_queue_Free( the_message_queue );
-  the_message_queue->is_global = is_global;
-#endif
-  if (_Attributes_Is_priority( attribute_set ) )
-    discipline = CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY;
-  else
-    discipline = CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO;
-  status = _CORE_message_queue_Initialize(
-    &the_message_queue->message_queue,
-    discipline,
-    count,
-    max_message_size
-  if ( status != STATUS_SUCCESSFUL ) {
-    if ( is_global )
-        _Objects_MP_Close(
-          &_Message_queue_Information, the_message_queue->Object.id);
-#endif
-    return STATUS_GET_CLASSIC( status );
-  _Objects_Open(
-    &the_message_queue->Object,
-    (Objects_Name) name
+  rtems_message_queue_config config;
+  memset( &config, 0, sizeof( config ) );
+  config.name = name;
+  config.maximum_pending_messages = count;
+  config.maximum_message_size = max_message_size;
+  config.attributes = attribute_set;
+    &config,
+    id,
-  *id = the_message_queue->Object.id;
-  if ( is_global )
-    _Message_queue_MP_Send_process_packet(
-      MESSAGE_QUEUE_MP_ANNOUNCE_CREATE,
-      the_message_queue->Object.id,
-      name,
-      0
-#endif
-  return RTEMS_SUCCESSFUL;
-static void _Message_queue_Manager_initialization( void )
-  _Objects_Initialize_information( &_Message_queue_Information);
-RTEMS_SYSINIT_ITEM(
-  _Message_queue_Manager_initialization,
-  RTEMS_SYSINIT_CLASSIC_MESSAGE_QUEUE,
-  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
index f7caca1ebf..967ce2355a 100644
--- a/cpukit/score/src/coremsg.c
+++ b/cpukit/score/src/coremsg.c
@@ -20,7 +20,6 @@
 #define MESSAGE_SIZE_LIMIT \
   ( SIZE_MAX - sizeof( uintptr_t ) + 1 - sizeof( CORE_message_queue_Buffer ) )
@@ -32,10 +31,12 @@ RTEMS_STATIC_ASSERT(
+  const void                          *arg
   size_t buffer_size;
@@ -56,8 +57,10 @@ Status_Control _CORE_message_queue_Initialize(
     return STATUS_MESSAGE_QUEUE_INVALID_NUMBER;
-  the_message_queue->message_buffers = _Workspace_Allocate(
-    (size_t) maximum_pending_messages * buffer_size
+  the_message_queue->message_buffers = ( *allocate_buffers )(
+    the_message_queue,
+    (size_t) maximum_pending_messages * buffer_size,
+    arg
   if ( the_message_queue->message_buffers == NULL ) {
diff --git a/cpukit/score/src/coremsgclose.c b/cpukit/score/src/coremsgclose.c
index 18b49b096c..98032dd3ad 100644
--- a/cpukit/score/src/coremsgclose.c
+++ b/cpukit/score/src/coremsgclose.c
@@ -19,7 +19,6 @@
 #endif
 static Thread_Control *_CORE_message_queue_Was_deleted(
   Thread_Control       *the_thread,
@@ -50,7 +49,11 @@ void _CORE_message_queue_Close(
     queue_context
-  (void) _Workspace_Free( the_message_queue->message_buffers );
+  if ( the_message_queue->free_message_buffers != NULL ) {
+    ( *the_message_queue->free_message_buffers )(
   _Thread_queue_Destroy( &the_message_queue->Wait_queue );
diff --git a/cpukit/score/src/coremsgwkspace.c b/cpukit/score/src/coremsgwkspace.c
index 0000000000..8441701813
--- /dev/null
+++ b/cpukit/score/src/coremsgwkspace.c
@@ -0,0 +1,53 @@
+ * @file
+ * @ingroup RTEMSScoreMessageQueue
+ *   _CORE_message_queue_Workspace_allocate().
+ * are met:
+#endif
+#include <rtems/score/wkspace.h>
+  size_t                      size,
+  const void                 *arg
+  (void) arg;
+  the_message_queue->free_message_buffers = _Workspace_Free;
+  return _Workspace_Allocate( size );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 2baf8ef01c..21dc239b1b 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1198,6 +1198,7 @@ source:
 - cpukit/rtems/src/modes.c
 - cpukit/rtems/src/msg.c
 - cpukit/rtems/src/msgqbroadcast.c
+- cpukit/rtems/src/msgqconstruct.c
 - cpukit/rtems/src/msgqcreate.c
 - cpukit/rtems/src/msgqdelete.c
 - cpukit/rtems/src/msgqflush.c
@@ -1376,6 +1377,7 @@ source:
 - cpukit/score/src/coremsginsert.c
 - cpukit/score/src/coremsgseize.c
 - cpukit/score/src/coremsgsubmit.c
+- cpukit/score/src/coremsgwkspace.c
 - cpukit/score/src/coremutexseize.c
 - cpukit/score/src/corerwlock.c
 - cpukit/score/src/corerwlockobtainread.c
diff --git a/testsuites/sptests/sp13/init.c b/testsuites/sptests/sp13/init.c
index a23d369001..f8ffd55426 100644
--- a/testsuites/sptests/sp13/init.c
+++ b/testsuites/sptests/sp13/init.c
@@ -28,6 +28,17 @@
 const char rtems_test_name[] = "SP 13";
+static RTEMS_MESSAGE_QUEUE_BUFFER( MESSAGE_SIZE ) Queue_3_buffers[ 100 ];
+static const rtems_message_queue_config Queue_3_config = {
+  .name = rtems_build_name( 'Q', '3', ' ', ' ' ),
+  .maximum_pending_messages = RTEMS_ARRAY_SIZE( Queue_3_buffers ),
+  .maximum_message_size = MESSAGE_SIZE,
+  .storage_area = Queue_3_buffers,
+  .storage_size = sizeof( Queue_3_buffers ),
+  .attributes = RTEMS_GLOBAL
 rtems_task Init(
   rtems_task_argument argument
@@ -101,14 +112,8 @@ rtems_task Init(
   directive_failed( status, "rtems_message_queue_create of Q2" );
-  status = rtems_message_queue_create(
-    Queue_name[ 3 ],
-    100,
-    MESSAGE_SIZE,
-    RTEMS_GLOBAL,
-    &Queue_id[ 3 ]
-  directive_failed( status, "rtems_message_queue_create of Q3" );
+  status = rtems_message_queue_construct( &Queue_3_config, &Queue_id[ 3 ] );
+  directive_failed( status, "rtems_message_queue_construct of Q3" );
   rtems_task_exit();
diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
index 7a495963f6..1abfc96b1d 100644
--- a/testsuites/sptests/sp13/system.h
+++ b/testsuites/sptests/sp13/system.h
@@ -91,7 +91,7 @@ TEST_EXTERN rtems_name Queue_name[ 4 ];      /* array of queue names */
 #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
    /* Q1 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
    /* Q2 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + \
-   /* Q3 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
+   /* Q3 is statically allocated */ \
    /* Q1 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 ) + \
    /* Q1 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 2,  1030 )
2.26.2
