BSP_CONSOLE_MINOR option for Zynq board with new build system
Fri Sep 25 15:11:04 UTC 2020
On 25/09/2020 17:08, Gedare Bloom wrote:
>> Yes, this could be a potential problem in several BSPs. I used a script
>> to convert the BSP options, but to detect if it was an integer or
>> boolean type was just an heuristic. In order to fix this, you first have
>> to find the build specification item of the option:
>> spec/build/bsps/arm/xilinx-zynqmp/optconminor.yml:name: BSP_CONSOLE_MINOR
>> spec/build/bsps/arm/xilinx-zynq/optconminor.yml:name: BSP_CONSOLE_MINOR
>> So, we have this option duplicated. This is an issue on its own. At some
>> point in time we should unify the options across the BSPs.
> Yes, I imagine we should like to use 'shared' folders at several
> levels of the spec/.../bsps tree
The "shared" folder is just a parent directory. For example
"spec/build/bsps" contains all items relevant to BSPs in general,
"spec/build/bsps/arm" contains all times relevant to "arm" architecture
BSPs.
