BSP_CONSOLE_MINOR option for Zynq board with new build system
Gedare Bloom
gedare at rtems.org
Fri Sep 25 15:14:49 UTC 2020
On Fri, Sep 25, 2020 at 9:11 AM Sebastian Huber
> On 25/09/2020 17:08, Gedare Bloom wrote:
> >> Yes, this could be a potential problem in several BSPs. I used a script
> >> to convert the BSP options, but to detect if it was an integer or
> >> boolean type was just an heuristic. In order to fix this, you first have
> >> to find the build specification item of the option:
> >> spec/build/bsps/arm/xilinx-zynqmp/optconminor.yml:name: BSP_CONSOLE_MINOR
> >> spec/build/bsps/arm/xilinx-zynq/optconminor.yml:name: BSP_CONSOLE_MINOR
> >> So, we have this option duplicated. This is an issue on its own. At some
> >> point in time we should unify the options across the BSPs.
> > Yes, I imagine we should like to use 'shared' folders at several
> > levels of the spec/.../bsps tree
> The "shared" folder is just a parent directory. For example
> "spec/build/bsps" contains all items relevant to BSPs in general,
> "spec/build/bsps/arm" contains all times relevant to "arm" architecture
> BSPs.
OK, that makes sense. But it does not allow for partially shared items I guess?
