[PATCH v1 7/8] bsps: Add Cortex-A53 LP64 basic BSP
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Sep 25 15:27:31 UTC 2020
This adds an AArch64 basic BSP based on Qemu's Cortex-A53 emulation with
interrupt support using GICv3 and clock support using the ARM GPT.
bsps/aarch64/a53/console/console.c | 61 ++
bsps/aarch64/a53/include/bsp.h | 74 +++
bsps/aarch64/a53/include/bsp/irq.h | 59 ++
bsps/aarch64/a53/include/tm27.h | 38 ++
bsps/aarch64/a53/start/bspstart.c | 41 ++
bsps/aarch64/a53/start/bspstarthooks.c | 42 ++
bsps/aarch64/include/bsp/irq-arch.h | 42 ++
bsps/aarch64/include/bsp/linker-symbols.h | 161 +++++
bsps/aarch64/include/bsp/start.h | 189 ++++++
bsps/aarch64/shared/cache/cache.c | 612 ++++++++++++++++++
.../clock/clock-arm-generic-timer-aarch64.c | 102 +++
.../shared/irq/irq-arm-gicv3-aarch64.c | 50 ++
bsps/aarch64/shared/start/linkcmds.base | 450 +++++++++++++
bsps/aarch64/shared/start/start.S | 217 +++++++
spec/build/bsps/aarch64/a53/abi.yml | 14 +
.../build/bsps/aarch64/a53/bspa53lp64qemu.yml | 70 ++
spec/build/bsps/aarch64/a53/linkcmds.yml | 65 ++
spec/build/bsps/aarch64/a53/optloadoff.yml | 15 +
spec/build/bsps/aarch64/a53/optnocachelen.yml | 15 +
spec/build/bsps/aarch64/a53/optramlen.yml | 15 +
spec/build/bsps/aarch64/a53/optramori.yml | 15 +
spec/build/bsps/aarch64/a53/tsta53.yml | 53 ++
spec/build/bsps/aarch64/start.yml | 11 +
23 files changed, 2411 insertions(+)
create mode 100644 bsps/aarch64/a53/console/console.c
create mode 100644 bsps/aarch64/a53/include/bsp.h
create mode 100644 bsps/aarch64/a53/include/bsp/irq.h
create mode 100644 bsps/aarch64/a53/include/tm27.h
create mode 100644 bsps/aarch64/a53/start/bspstart.c
create mode 100644 bsps/aarch64/a53/start/bspstarthooks.c
create mode 100644 bsps/aarch64/include/bsp/irq-arch.h
create mode 100644 bsps/aarch64/include/bsp/linker-symbols.h
create mode 100644 bsps/aarch64/include/bsp/start.h
create mode 100644 bsps/aarch64/shared/cache/cache.c
create mode 100644 bsps/aarch64/shared/clock/clock-arm-generic-timer-aarch64.c
create mode 100644 bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c
create mode 100644 bsps/aarch64/shared/start/linkcmds.base
create mode 100644 bsps/aarch64/shared/start/start.S
create mode 100644 spec/build/bsps/aarch64/a53/abi.yml
create mode 100644 spec/build/bsps/aarch64/a53/bspa53lp64qemu.yml
create mode 100644 spec/build/bsps/aarch64/a53/linkcmds.yml
create mode 100644 spec/build/bsps/aarch64/a53/optloadoff.yml
create mode 100644 spec/build/bsps/aarch64/a53/optnocachelen.yml
create mode 100644 spec/build/bsps/aarch64/a53/optramlen.yml
create mode 100644 spec/build/bsps/aarch64/a53/optramori.yml
create mode 100644 spec/build/bsps/aarch64/a53/tsta53.yml
create mode 100644 spec/build/bsps/aarch64/start.yml
diff --git a/bsps/aarch64/a53/console/console.c b/bsps/aarch64/a53/console/console.c
new file mode 100644
index 0000000000..1a3c8fe8b0
--- /dev/null
+++ b/bsps/aarch64/a53/console/console.c
@@ -0,0 +1,61 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/bspIo.h>
+#include <bsp.h>
+#include <libchip/arm-pl011.h>
+#include <bsp/console-termios.h>
+#include <bspopts.h>
+arm_pl011_context a53_qemu_vpl011_context = {
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
+ .regs = (volatile pl011 *) BSP_A53_QEMU_VPL011_BASE,
+ .initial_baud = 115200
+const console_device console_device_table[] = {
+ .device_file = "/dev/ttyS0",
+ .probe = console_device_probe_default,
+ .handler = &arm_pl011_fns,
+ .context = &a53_qemu_vpl011_context.base
+const size_t console_device_count = RTEMS_ARRAY_SIZE(console_device_table);
+static void output_char( char c )
+ arm_pl011_write_polled(&a53_qemu_vpl011_context.base, c);
+BSP_output_char_function_type BSP_output_char = output_char;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/bsps/aarch64/a53/include/bsp.h b/bsps/aarch64/a53/include/bsp.h
index 0000000000..28785232f3
--- /dev/null
+++ b/bsps/aarch64/a53/include/bsp.h
@@ -0,0 +1,74 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64a53_qemu
+ * @brief Global BSP definitions.
+ * are met:
+#ifndef LIBBSP_AARCH64_A53_QEMU_BSP_H
+#define LIBBSP_AARCH64_A53_QEMU_BSP_H
+ * @addtogroup RTEMSBSPsAArch64
+#ifndef ASM
+#include <bsp/default-initial-extension.h>
+#include <bsp/start.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_ARM_GIC_CPUIF_BASE 0x08010000
+#define BSP_ARM_GIC_DIST_BASE 0x08000000
+#define BSP_ARM_GIC_REDIST_BASE 0x080A0000
+#define BSP_A53_QEMU_VPL011_BASE 0x9000000
+#define BSP_A53_QEMU_VPL011_LENGTH 0x1000
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_A53_QEMU_BSP_H */
diff --git a/bsps/aarch64/a53/include/bsp/irq.h b/bsps/aarch64/a53/include/bsp/irq.h
index 0000000000..c8115ed30b
--- /dev/null
+++ b/bsps/aarch64/a53/include/bsp/irq.h
@@ -0,0 +1,59 @@
+ * are met:
+#ifndef LIBBSP_AARCH64_A53_IRQ_H
+#define LIBBSP_AARCH64_A53_IRQ_H
+#ifndef ASM
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#include <bsp/arm-gic-irq.h>
+#ifdef __cplusplus
+extern "C" {
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX 1023
+/* Interrupts vectors */
+#define BSP_TIMER_VIRT_PPI 27
+#define BSP_TIMER_PHYS_NS_PPI 30
+#define BSP_VPL011_SPI 32
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_A53_IRQ_H */
diff --git a/bsps/aarch64/a53/include/tm27.h b/bsps/aarch64/a53/include/tm27.h
index 0000000000..edacadc171
--- /dev/null
+++ b/bsps/aarch64/a53/include/tm27.h
@@ -0,0 +1,38 @@
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <bsp/arm-gic-tm27.h>
+#endif /* __tm27_h */
diff --git a/bsps/aarch64/a53/start/bspstart.c b/bsps/aarch64/a53/start/bspstart.c
index 0000000000..e42726fb9b
--- /dev/null
+++ b/bsps/aarch64/a53/start/bspstart.c
@@ -0,0 +1,41 @@
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/irq-generic.h>
+#include <bsp/linker-symbols.h>
+void bsp_start( void )
+ bsp_interrupt_initialize();
+ rtems_cache_coherent_add_area(
+ bsp_section_nocacheheap_begin,
+ (uintptr_t) bsp_section_nocacheheap_size
diff --git a/bsps/aarch64/a53/start/bspstarthooks.c b/bsps/aarch64/a53/start/bspstarthooks.c
index 0000000000..875f9fd05b
--- /dev/null
+++ b/bsps/aarch64/a53/start/bspstarthooks.c
@@ -0,0 +1,42 @@
+ * are met:
+#include <bsp.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+ /* Do nothing */
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+ AArch64_start_set_vector_base();
+ bsp_start_copy_sections();
+ bsp_start_clear_bss();
diff --git a/bsps/aarch64/include/bsp/irq-arch.h b/bsps/aarch64/include/bsp/irq-arch.h
index 0000000000..5078ac0a93
--- /dev/null
+++ b/bsps/aarch64/include/bsp/irq-arch.h
@@ -0,0 +1,42 @@
+ * are met:
+#ifndef LIBBSP_AARCH64_SHARED_IRQ_ARCH_H
+#define LIBBSP_AARCH64_SHARED_IRQ_ARCH_H
+#ifdef __cplusplus
+extern "C" {
+void bsp_interrupt_dispatch( void );
+#ifdef __cplusplus
+#endif /* LIBBSP_AARCH64_SHARED_IRQ_ARCH_H */
diff --git a/bsps/aarch64/include/bsp/linker-symbols.h b/bsps/aarch64/include/bsp/linker-symbols.h
index 0000000000..36660e15cc
--- /dev/null
+++ b/bsps/aarch64/include/bsp/linker-symbols.h
@@ -0,0 +1,161 @@
+ * @file
+ * @ingroup aarch64_linker
+ * @brief Symbols defined in linker command base file.
+ * are met:
+#ifndef LIBBSP_AARCH64_SHARED_LINKER_SYMBOLS_H
+#define LIBBSP_AARCH64_SHARED_LINKER_SYMBOLS_H
+#include <rtems/score/basedefs.h>
+#ifdef __cplusplus
+extern "C" {
+ * @defgroup aarch64_linker Linker Support
+ * @ingroup RTEMSBSPsAARCH64Shared
+ * @brief Linker support.
+#ifndef ASM
+ #define LINKER_SYMBOL(sym) extern char sym [];
+#else
+ #define LINKER_SYMBOL(sym) .extern sym
+#endif
+LINKER_SYMBOL(bsp_stack_exception_size)
+LINKER_SYMBOL(bsp_stack_hyp_size)
+LINKER_SYMBOL(bsp_section_start_begin)
+LINKER_SYMBOL(bsp_section_start_end)
+LINKER_SYMBOL(bsp_section_start_size)
+LINKER_SYMBOL(bsp_section_vector_begin)
+LINKER_SYMBOL(bsp_section_vector_end)
+LINKER_SYMBOL(bsp_section_vector_size)
+LINKER_SYMBOL(bsp_section_text_begin)
+LINKER_SYMBOL(bsp_section_text_end)
+LINKER_SYMBOL(bsp_section_text_size)
+LINKER_SYMBOL(bsp_section_text_load_begin)
+LINKER_SYMBOL(bsp_section_text_load_end)
+LINKER_SYMBOL(bsp_section_rodata_begin)
+LINKER_SYMBOL(bsp_section_rodata_end)
+LINKER_SYMBOL(bsp_section_rodata_size)
+LINKER_SYMBOL(bsp_section_rodata_load_begin)
+LINKER_SYMBOL(bsp_section_rodata_load_end)
+LINKER_SYMBOL(bsp_section_data_begin)
+LINKER_SYMBOL(bsp_section_data_end)
+LINKER_SYMBOL(bsp_section_data_size)
+LINKER_SYMBOL(bsp_section_data_load_begin)
+LINKER_SYMBOL(bsp_section_data_load_end)
+LINKER_SYMBOL(bsp_section_fast_text_begin)
+LINKER_SYMBOL(bsp_section_fast_text_end)
+LINKER_SYMBOL(bsp_section_fast_text_size)
+LINKER_SYMBOL(bsp_section_fast_text_load_begin)
+LINKER_SYMBOL(bsp_section_fast_text_load_end)
+LINKER_SYMBOL(bsp_section_fast_data_begin)
+LINKER_SYMBOL(bsp_section_fast_data_end)
+LINKER_SYMBOL(bsp_section_fast_data_size)
+LINKER_SYMBOL(bsp_section_fast_data_load_begin)
+LINKER_SYMBOL(bsp_section_fast_data_load_end)
+LINKER_SYMBOL(bsp_section_bss_begin)
+LINKER_SYMBOL(bsp_section_bss_end)
+LINKER_SYMBOL(bsp_section_bss_size)
+LINKER_SYMBOL(bsp_section_work_begin)
+LINKER_SYMBOL(bsp_section_work_end)
+LINKER_SYMBOL(bsp_section_work_size)
+LINKER_SYMBOL(bsp_section_stack_begin)
+LINKER_SYMBOL(bsp_section_stack_end)
+LINKER_SYMBOL(bsp_section_stack_size)
+LINKER_SYMBOL(bsp_section_nocache_begin)
+LINKER_SYMBOL(bsp_section_nocache_end)
+LINKER_SYMBOL(bsp_section_nocache_size)
+LINKER_SYMBOL(bsp_section_nocache_load_begin)
+LINKER_SYMBOL(bsp_section_nocache_load_end)
+LINKER_SYMBOL(bsp_section_nocachenoload_begin)
+LINKER_SYMBOL(bsp_section_nocachenoload_end)
+LINKER_SYMBOL(bsp_section_nocachenoload_size)
+LINKER_SYMBOL(bsp_section_nocacheheap_begin)
+LINKER_SYMBOL(bsp_section_nocacheheap_end)
+LINKER_SYMBOL(bsp_section_nocacheheap_size)
+LINKER_SYMBOL(bsp_vector_table_begin)
+LINKER_SYMBOL(bsp_vector_table_end)
+LINKER_SYMBOL(bsp_vector_table_size)
+LINKER_SYMBOL(bsp_start_vector_table_begin)
+LINKER_SYMBOL(bsp_start_vector_table_end)
+LINKER_SYMBOL(bsp_start_vector_table_size)
+#define BSP_FAST_TEXT_SECTION \
+ RTEMS_SECTION(".bsp_fast_text")
+#define BSP_FAST_DATA_SECTION \
+ RTEMS_SECTION(".bsp_fast_data")
+#define BSP_NOCACHE_SECTION \
+ RTEMS_SECTION(".bsp_nocache")
+#define BSP_NOCACHE_SUBSECTION(subsection) \
+ RTEMS_SECTION(".bsp_nocache." # subsection)
+#define BSP_NOCACHENOLOAD_SECTION \
+ RTEMS_SECTION(".bsp_noload_nocache")
+#define BSP_NOCACHENOLOAD_SUBSECTION(subsection) \
+ RTEMS_SECTION(".bsp_noload_nocache." # subsection)
+#ifdef __cplusplus
+#endif /* LIBBSP_AARCH64_SHARED_LINKER_SYMBOLS_H */
diff --git a/bsps/aarch64/include/bsp/start.h b/bsps/aarch64/include/bsp/start.h
index 0000000000..465bfc845e
--- /dev/null
+++ b/bsps/aarch64/include/bsp/start.h
@@ -0,0 +1,189 @@
+ * @file
+ * @ingroup aarch64_start
+ * @brief Aarch64 system low level start.
+ * are met:
+#ifndef LIBBSP_AARCH64_SHARED_START_H
+#define LIBBSP_AARCH64_SHARED_START_H
+#include <string.h>
+#ifdef __cplusplus
+extern "C" {
+ * @defgroup aarch64_start System Start
+ * @ingroup RTEMSBSPsAarch64Shared
+#define BSP_START_TEXT_SECTION __attribute__((section(".bsp_start_text")))
+#define BSP_START_DATA_SECTION __attribute__((section(".bsp_start_data")))
+* @brief System start entry.
+void _start(void);
+* @brief Start entry hook 0.
+* This hook will be called from the start entry code after all modes and
+* stack pointers are initialized but before the copying of the exception
+* vectors.
+void bsp_start_hook_0(void);
+* @brief Start entry hook 1.
+* This hook will be called from the start entry code after copying of the
+* exception vectors but before the call to boot_card().
+void bsp_start_hook_1(void);
+BSP_START_TEXT_SECTION static inline void
+bsp_start_memcpy_libc(void *dest, const void *src, size_t n)
+ if (dest != src) {
+ memcpy(dest, src, n);
+ * @brief Copies all standard sections from the load to the runtime area.
+BSP_START_TEXT_SECTION static inline void bsp_start_copy_sections(void)
+ /* Copy .text section */
+ bsp_start_memcpy_libc(
+ (int *) bsp_section_text_begin,
+ (const int *) bsp_section_text_load_begin,
+ (size_t) bsp_section_text_size
+ /* Copy .rodata section */
+ (int *) bsp_section_rodata_begin,
+ (const int *) bsp_section_rodata_load_begin,
+ (size_t) bsp_section_rodata_size
+ /* Copy .data section */
+ (int *) bsp_section_data_begin,
+ (const int *) bsp_section_data_load_begin,
+ (size_t) bsp_section_data_size
+ /* Copy .fast_text section */
+ (int *) bsp_section_fast_text_begin,
+ (const int *) bsp_section_fast_text_load_begin,
+ (size_t) bsp_section_fast_text_size
+ /* Copy .fast_data section */
+ (int *) bsp_section_fast_data_begin,
+ (const int *) bsp_section_fast_data_load_begin,
+ (size_t) bsp_section_fast_data_size
+ * @brief Copies the .data, .fast_text and .fast_data sections from the load to
+ * the runtime area using the C library memcpy().
+ * Works only in case the .start, .text and .rodata sections reside in one
+ * memory region.
+BSP_START_TEXT_SECTION static inline void bsp_start_copy_sections_compact(void)
+ bsp_section_data_begin,
+ bsp_section_data_load_begin,
+ bsp_section_fast_text_begin,
+ bsp_section_fast_text_load_begin,
+ bsp_section_fast_data_begin,
+ bsp_section_fast_data_load_begin,
+BSP_START_TEXT_SECTION static inline void bsp_start_clear_bss(void)
+ memset(bsp_section_bss_begin, 0, (size_t) bsp_section_bss_size);
+AArch64_start_set_vector_base(void)
+ * Do not use bsp_vector_table_begin == 0, since this will get optimized away.
+ if (bsp_vector_table_end != bsp_vector_table_size) {
+ __asm__ volatile (
+ "msr VBAR_EL1, %[vtable]\n"
+ : : [vtable] "r" (bsp_start_vector_table_begin)
+#ifdef __cplusplus
+#endif /* LIBBSP_AARCH64_SHARED_START_H */
diff --git a/bsps/aarch64/shared/cache/cache.c b/bsps/aarch64/shared/cache/cache.c
index 0000000000..4efdeec913
--- /dev/null
+++ b/bsps/aarch64/shared/cache/cache.c
@@ -0,0 +1,612 @@
+ * @file
+ * @brief AArch64 cache defines and implementation.
+ * are met:
+#include <rtems.h>
+#include <bsp.h>
+#include <bsp/utility.h>
+#define AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT ((size_t)64)
+#define AARCH64_CACHE_L1_DATA_LINE_MASK ( AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT - 1 )
+#define AARCH64_CACHE_PREPARE_MVA(mva) \
+ ((const void *) (((size_t) (mva)) & AARCH64_CACHE_L1_DATA_LINE_MASK))
+static inline void AArch64_data_cache_clean_and_invalidate_line(const void *d_addr)
+ d_addr = AARCH64_CACHE_PREPARE_MVA(d_addr);
+ "dc civac, %[d_addr]"
+ : [d_addr] "r" (d_addr)
+ : "memory"
+static inline void _CPU_cache_flush_1_data_line(const void *d_addr)
+ /* Flush the Data cache */
+ AArch64_data_cache_clean_and_invalidate_line( d_addr );
+ /* Wait for L1 flush to complete */
+ _AARCH64_Data_synchronization_barrier();
+static inline void
+_CPU_cache_flush_data_range(
+ const void *d_addr,
+ size_t n_bytes
+ if ( n_bytes != 0 ) {
+ size_t adx = (size_t) d_addr & ~AARCH64_CACHE_L1_DATA_LINE_MASK;
+ const size_t ADDR_LAST = (size_t) d_addr + n_bytes - 1;
+ for (; adx <= ADDR_LAST; adx += AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT ) {
+ /* Store and invalidate the Data cache line */
+ AArch64_data_cache_clean_and_invalidate_line( (void*)adx );
+ /* Wait for L1 store to complete */
+static inline void AArch64_data_cache_invalidate_line(const void *d_addr)
+ "dc ivac, %[d_addr]"
+ : "memory"
+static inline void _CPU_cache_invalidate_1_data_line(const void *d_addr)
+ /* Invalidate the data cache line */
+ AArch64_data_cache_invalidate_line( d_addr );
+ /* Wait for L1 invalidate to complete */
+static inline void
+_CPU_cache_invalidate_data_range(
+ size_t n_bytes
+ & ~AARCH64_CACHE_L1_DATA_LINE_MASK;
+ const size_t end = (size_t)d_addr + n_bytes -1;
+ /* Back starting address up to start of a line and invalidate until end */
+ for (;
+ adx <= end;
+ adx += AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT ) {
+ /* Invalidate the Instruction cache line */
+ AArch64_data_cache_invalidate_line( (void*)adx );
+static inline void _CPU_cache_freeze_data(void)
+ /* TODO */
+static inline void _CPU_cache_unfreeze_data(void)
+ /* TODO */
+static inline void AArch64_instruction_cache_invalidate_line(const void *i_addr)
+ /* __builtin___clear_cache is explicitly only for instruction cacche */
+ __builtin___clear_cache((void *)i_addr, ((char *)i_addr) + sizeof(void*) - 1);
+static inline void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
+ AArch64_instruction_cache_invalidate_line( d_addr );
+static inline void
+_CPU_cache_invalidate_instruction_range( const void *i_addr, size_t n_bytes)
+ __builtin___clear_cache((void *)i_addr, ((char *)i_addr) + n_bytes - 1);
+ _AARCH64_Instruction_synchronization_barrier();
+static inline void _CPU_cache_freeze_instruction(void)
+ /* TODO */
+static inline void _CPU_cache_unfreeze_instruction(void)
+ /* TODO */
+static inline uint64_t
+AArch64_get_ccsidr(void)
+ uint64_t val;
+ "mrs %[val], CCSIDR_EL1\n"
+ : [val] "=&r" (val)
+ return val;
+#define CCSIDR_NUMSETS(val) BSP_FLD64(val, 13, 27)
+#define CCSIDR_NUMSETS_GET(reg) BSP_FLD64GET(reg, 13, 27)
+#define CCSIDR_NUMSETS_SET(reg, val) BSP_FLD64SET(reg, val, 13, 27)
+#define CCSIDR_ASSOCIATIVITY(val) BSP_FLD64(val, 3, 12)
+#define CCSIDR_ASSOCIATIVITY_GET(reg) BSP_FLD64GET(reg, 3, 12)
+#define CCSIDR_ASSOCIATIVITY_SET(reg, val) BSP_FLD64SET(reg, val, 3, 12)
+/* line size == 1 << (GET(reg)+4): 0 -> (1 << 4) == 16 */
+#define CCSIDR_LINE_SIZE(val) BSP_FLD64(val, 0, 2)
+#define CCSIDR_LINE_SIZE_GET(reg) BSP_FLD64GET(reg, 0, 2)
+#define CCSIDR_LINE_SIZE_SET(reg, val) BSP_FLD64SET(reg, val, 0, 2)
+AArch64_ccsidr_get_line_power(uint64_t ccsidr)
+ return CCSIDR_LINE_SIZE_GET(ccsidr) + 4;
+AArch64_ccsidr_get_associativity(uint64_t ccsidr)
+ return CCSIDR_ASSOCIATIVITY_GET(ccsidr) + 1;
+AArch64_ccsidr_get_num_sets(uint64_t ccsidr)
+ return CCSIDR_NUMSETS_GET(ccsidr) + 1;
+static inline void
+AArch64_set_csselr(uint64_t val)
+ "msr CSSELR_EL1, %[val]\n"
+ : [val] "r" (val)
+#define CSSELR_TND BSP_BIT64(4)
+/* This field is level-1: L1 cache is 0, L2 cache is 1, etc */
+#define CSSELR_LEVEL(val) BSP_FLD64(val, 1, 3)
+#define CSSELR_LEVEL_GET(reg) BSP_FLD64GET(reg, 1, 3)
+#define CSSELR_LEVEL_SET(reg, val) BSP_FLD64SET(reg, val, 1, 3)
+#define CSSELR_IND BSP_BIT64(0)
+static inline uint64_t AArch64_get_ccsidr_for_level(uint64_t val)
+ AArch64_set_csselr(val);
+ return AArch64_get_ccsidr();
+static inline void AArch64_data_cache_clean_level(uint64_t level)
+ uint64_t ccsidr;
+ uint64_t line_power;
+ uint64_t associativity;
+ uint64_t way;
+ uint64_t way_shift;
+ ccsidr = AArch64_get_ccsidr_for_level(CSSELR_LEVEL(level));
+ line_power = AArch64_ccsidr_get_line_power(ccsidr);
+ associativity = AArch64_ccsidr_get_associativity(ccsidr);
+ way_shift = __builtin_clz(associativity - 1);
+ for (way = 0; way < associativity; ++way) {
+ uint64_t num_sets = AArch64_ccsidr_get_num_sets(ccsidr);
+ uint64_t set;
+ for (set = 0; set < num_sets; ++set) {
+ uint64_t set_and_way = (way << way_shift)
+ | (set << line_power)
+ | (level << 1);
+ "dc csw, %[set_and_way]"
+ : [set_and_way] "r" (set_and_way)
+ : "memory"
+AArch64_get_clidr(void)
+ uint64_t val;
+ "mrs %[val], CLIDR_EL1\n"
+ return val;
+#define CLIDR_LOC(val) BSP_FLD64(val, 24, 26)
+#define CLIDR_LOC_GET(reg) BSP_FLD64GET(reg, 24, 26)
+#define CLIDR_LOC_SET(reg, val) BSP_FLD64SET(reg, val, 24, 26)
+#define CLIDR_CTYPE7(val) BSP_FLD64(val, 18, 20)
+#define CLIDR_CTYPE7_GET(reg) BSP_FLD64GET(reg, 18, 20)
+#define CLIDR_CTYPE7_SET(reg, val) BSP_FLD64SET(reg, val, 18, 20)
+#define CLIDR_CTYPE6(val) BSP_FLD64(val, 15, 17)
+#define CLIDR_CTYPE6_GET(reg) BSP_FLD64GET(reg, 15, 17)
+#define CLIDR_CTYPE6_SET(reg, val) BSP_FLD64SET(reg, val, 15, 17)
+#define CLIDR_CTYPE5(val) BSP_FLD64(val, 12, 14)
+#define CLIDR_CTYPE5_GET(reg) BSP_FLD64GET(reg, 12, 14)
+#define CLIDR_CTYPE5_SET(reg, val) BSP_FLD64SET(reg, val, 12, 14)
+#define CLIDR_CTYPE4(val) BSP_FLD64(val, 9, 11)
+#define CLIDR_CTYPE4_GET(reg) BSP_FLD64GET(reg, 9, 11)
+#define CLIDR_CTYPE4_SET(reg, val) BSP_FLD64SET(reg, val, 9, 11)
+#define CLIDR_CTYPE3(val) BSP_FLD64(val, 6, 8)
+#define CLIDR_CTYPE3_GET(reg) BSP_FLD64GET(reg, 6, 8)
+#define CLIDR_CTYPE3_SET(reg, val) BSP_FLD64SET(reg, val, 6, 8)
+#define CLIDR_CTYPE2(val) BSP_FLD64(val, 3, 5)
+#define CLIDR_CTYPE2_GET(reg) BSP_FLD64GET(reg, 3, 5)
+#define CLIDR_CTYPE2_SET(reg, val) BSP_FLD64SET(reg, val, 3, 5)
+#define CLIDR_CTYPE1(val) BSP_FLD64(val, 0, 2)
+#define CLIDR_CTYPE1_GET(reg) BSP_FLD64GET(reg, 0, 2)
+#define CLIDR_CTYPE1_SET(reg, val) BSP_FLD64SET(reg, val, 0, 2)
+static inline uint64_t AArch64_clidr_get_cache_type(uint64_t clidr, uint64_t level)
+ switch (level)
+ case 1:
+ return CLIDR_CTYPE1_GET(clidr);
+ case 2:
+ return CLIDR_CTYPE2_GET(clidr);
+ case 3:
+ return CLIDR_CTYPE3_GET(clidr);
+ case 4:
+ return CLIDR_CTYPE4_GET(clidr);
+ case 5:
+ return CLIDR_CTYPE5_GET(clidr);
+ case 6:
+ return CLIDR_CTYPE6_GET(clidr);
+ case 7:
+ return CLIDR_CTYPE7_GET(clidr);
+ default:
+ return 0;
+static inline uint64_t AArch64_clidr_get_level_of_coherency(uint64_t clidr)
+ return CLIDR_LOC_GET(clidr);
+static inline void AArch64_data_cache_clean_all_levels(void)
+ uint64_t clidr = AArch64_get_clidr();
+ uint64_t loc = AArch64_clidr_get_level_of_coherency(clidr);
+ uint64_t level = 0;
+ for (level = 0; level < loc; ++level) {
+ uint64_t ctype = AArch64_clidr_get_cache_type(clidr, level);
+ /* Check if this level has a data cache or unified cache */
+ if (((ctype & (0x6)) == 2) || (ctype == 4)) {
+ AArch64_data_cache_clean_level(level);
+static inline void _CPU_cache_flush_entire_data(void)
+ AArch64_data_cache_clean_all_levels();
+static inline void AArch64_cache_invalidate_level(uint64_t level)
+ uint64_t ccsidr;
+ uint64_t way;
+ uint64_t set;
+ | (level << 1);
+ "dc isw, %[set_and_way]"
+ : "memory"
+static inline void AArch64_data_cache_invalidate_all_levels(void)
+ if ((ctype & 0x2) || (ctype == 4)) {
+ AArch64_cache_invalidate_level(level);
+static inline void _CPU_cache_invalidate_entire_data(void)
+ AArch64_data_cache_invalidate_all_levels();
+AArch64_get_sctlr(void)
+ uint64_t val;
+ "mrs %[val], SCTLR_EL1\n"
+ return val;
+static inline void
+AArch64_set_sctlr(uint64_t val)
+ "msr SCTLR_EL1, %[val]\n"
+ : [val] "r" (val)
+#define SCTLR_TWEDEL(val) BSP_FLD64(val, 46, 49)
+#define SCTLR_TWEDEL_GET(reg) BSP_FLD64GET(reg, 46, 49)
+#define SCTLR_TWEDEL_SET(reg, val) BSP_FLD64SET(reg, val, 46, 49)
+#define SCTLR_TWEDEN BSP_BIT64(45)
+#define SCTLR_DSSBS BSP_BIT64(44)
+#define SCTLR_ATA BSP_BIT64(43)
+#define SCTLR_ATA0 BSP_BIT64(42)
+#define SCTLR_TCF(val) BSP_FLD64(val, 40, 41)
+#define SCTLR_TCF_GET(reg) BSP_FLD64GET(reg, 40, 41)
+#define SCTLR_TCF_SET(reg, val) BSP_FLD64SET(reg, val, 40, 41)
+#define SCTLR_TCF0(val) BSP_FLD64(val, 38, 39)
+#define SCTLR_TCF0_GET(reg) BSP_FLD64GET(reg, 38, 39)
+#define SCTLR_TCF0_SET(reg, val) BSP_FLD64SET(reg, val, 38, 39)
+#define SCTLR_ITFSB BSP_BIT64(37)
+#define SCTLR_BT1 BSP_BIT64(36)
+#define SCTLR_BT0 BSP_BIT64(35)
+#define SCTLR_ENIA BSP_BIT64(31)
+#define SCTLR_ENIB BSP_BIT64(30)
+#define SCTLR_LSMAOE BSP_BIT64(29)
+#define SCTLR_NTLSMD BSP_BIT64(28)
+#define SCTLR_ENDA BSP_BIT64(27)
+#define SCTLR_UCI BSP_BIT64(26)
+#define SCTLR_EE BSP_BIT64(25)
+#define SCTLR_E0E BSP_BIT64(24)
+#define SCTLR_SPAN BSP_BIT64(23)
+#define SCTLR_EIS BSP_BIT64(22)
+#define SCTLR_IESB BSP_BIT64(21)
+#define SCTLR_TSCXT BSP_BIT64(20)
+#define SCTLR_WXN BSP_BIT64(19)
+#define SCTLR_NTWE BSP_BIT64(18)
+#define SCTLR_NTWI BSP_BIT64(16)
+#define SCTLR_UCT BSP_BIT64(15)
+#define SCTLR_DZE BSP_BIT64(14)
+#define SCTLR_ENDB BSP_BIT64(13)
+#define SCTLR_I BSP_BIT64(12)
+#define SCTLR_EOS BSP_BIT64(11)
+#define SCTLR_ENRCTX BSP_BIT64(10)
+#define SCTLR_UMA BSP_BIT64(9)
+#define SCTLR_SED BSP_BIT64(8)
+#define SCTLR_ITD BSP_BIT64(7)
+#define SCTLR_NAA BSP_BIT64(6)
+#define SCTLR_CP15BEN BSP_BIT64(5)
+#define SCTLR_SA0 BSP_BIT64(4)
+#define SCTLR_SA BSP_BIT64(3)
+#define SCTLR_C BSP_BIT64(2)
+#define SCTLR_A BSP_BIT64(1)
+#define SCTLR_M BSP_BIT64(0)
+static inline void _CPU_cache_enable_data(void)
+ rtems_interrupt_level level;
+ uint64_t sctlr;
+ rtems_interrupt_local_disable(level);
+ sctlr = AArch64_get_sctlr();
+ sctlr |= SCTLR_C;
+ AArch64_set_sctlr(sctlr);
+ rtems_interrupt_local_enable(level);
+static inline void _CPU_cache_disable_data(void)
+ uint64_t sctlr;
+ sctlr &= ~SCTLR_C;
+static inline void AArch64_instruction_cache_inner_shareable_invalidate_all(void)
+ "ic ialluis\n"
+ : "memory"
+static inline void AArch64_instruction_cache_invalidate(void)
+ "ic iallu\n"
+ : "memory"
+static inline void _CPU_cache_invalidate_entire_instruction(void)
+ /* There is no way to manage branch prediction in AArch64.
+ * See D4.4.12 in the ARMv8 technical manual. */
+ #ifdef RTEMS_SMP
+ /* invalidate I-cache inner shareable */
+ AArch64_instruction_cache_inner_shareable_invalidate_all();
+ #endif /* RTEMS_SMP */
+ /* I+BTB cache invalidate */
+ AArch64_instruction_cache_invalidate();
+static inline void _CPU_cache_enable_instruction(void)
+ uint64_t sctlr;
+ sctlr |= SCTLR_I;
+static inline void _CPU_cache_disable_instruction(void)
+ uint64_t sctlr;
+ sctlr &= ~SCTLR_I;
+static inline size_t AArch64_get_cache_size(
+ uint64_t level,
+ bool instruction
+ uint64_t clidr;
+ uint64_t loc;
+ uint64_t ccsidr;
+ clidr = AArch64_get_clidr();
+ loc = AArch64_clidr_get_level_of_coherency(clidr);
+ if (level >= loc) {
+ return 0;
+ if (level == 0) {
+ level = loc - 1;
+ CSSELR_LEVEL(level) | (instruction ? CSSELR_IND : 0)
+ return (1U << (AArch64_ccsidr_get_line_power(ccsidr)+4))
+ * AArch64_ccsidr_get_associativity(ccsidr)
+ * AArch64_ccsidr_get_num_sets(ccsidr);
+static inline size_t _CPU_cache_get_data_cache_size(uint64_t level)
+ return AArch64_get_cache_size(level, false);
+static inline size_t _CPU_cache_get_instruction_cache_size(uint64_t level)
+ return AArch64_get_cache_size(level, true);
+#include "../../shared/cache/cacheimpl.h"
diff --git a/bsps/aarch64/shared/clock/clock-arm-generic-timer-aarch64.c b/bsps/aarch64/shared/clock/clock-arm-generic-timer-aarch64.c
index 0000000000..c5ac80fed1
--- /dev/null
+++ b/bsps/aarch64/shared/clock/clock-arm-generic-timer-aarch64.c
@@ -0,0 +1,102 @@
+ * are met:
+#include <bsp/clock-arm-generic-timer.h>
+#include <bsp/irq.h>
+uint64_t aarch_gt_clock_get_compare_value(void)
+ uint64_t val;
+#ifdef AARCH64_GENERIC_TIMER_USE_VIRTUAL
+ "mrs %[val], cntv_cval_el0"
+#else
+ "mrs %[val], cntp_cval_el0"
+#endif
+ return val;
+void aarch_gt_clock_set_compare_value(uint64_t cval)
+ "msr cntv_cval_el0, %[cval]"
+#else
+ "msr cntp_cval_el0, %[cval]"
+#endif
+ : [cval] "r" (cval)
+uint64_t aarch_gt_clock_get_count(void)
+ uint64_t val;
+ "mrs %[val], cntvct_el0"
+#else
+ "mrs %[val], cntpct_el0"
+#endif
+ return val;
+void aarch_gt_clock_set_control(uint32_t ctl)
+ "msr cntv_ctl_el0, %[ctl]"
+#else
+ "msr cntp_ctl_el0, %[ctl]"
+#endif
+ : [ctl] "r" (ctl)
+void aarch_generic_timer_get_config( uint32_t *frequency, uint32_t *irq )
+ uint64_t val;
+ "mrs %[val], cntfrq_el0"
+ *frequency = val;
+#ifdef ARM_GENERIC_TIMER_USE_VIRTUAL
+ *irq = BSP_TIMER_VIRT_PPI;
+#else
+ *irq = BSP_TIMER_PHYS_NS_PPI;
+#endif
diff --git a/bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c b/bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c
index 0000000000..4b5a0142da
--- /dev/null
+++ b/bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c
@@ -0,0 +1,50 @@
+ * are met:
+void aarch_interrupt_handler_dispatch(rtems_vector_number vector)
+ uint32_t interrupt_level = _CPU_ISR_Get_level();
+ AArch64_interrupt_enable(1);
+ bsp_interrupt_handler_dispatch(vector);
+ _CPU_ISR_Set_level(interrupt_level);
+void aarch_interrupt_facility_set_exception_handler(void)
+ AArch64_set_exception_handler(
+ AARCH64_EXCEPTION_SPx_IRQ,
+ _AArch64_Exception_interrupt_no_nest
+ AARCH64_EXCEPTION_SP0_IRQ,
+ _AArch64_Exception_interrupt_nest
diff --git a/bsps/aarch64/shared/start/linkcmds.base b/bsps/aarch64/shared/start/linkcmds.base
index 0000000000..ff8b379fa7
--- /dev/null
+++ b/bsps/aarch64/shared/start/linkcmds.base
@@ -0,0 +1,450 @@
+ * @file
+ * @ingroup bsp_linker
+ * @brief Linker command base file.
+ * are met:
+OUTPUT_FORMAT ("elf64-littleaarch64")
+OUTPUT_ARCH (aarch64)
+ENTRY (_start)
+STARTUP (start.o)
+ * Global symbols that may be defined externally
+bsp_vector_table_size = DEFINED (bsp_vector_table_size) ? bsp_vector_table_size : 64;
+bsp_section_xbarrier_align = DEFINED (bsp_section_xbarrier_align) ? bsp_section_xbarrier_align : 1;
+bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
+bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
+bsp_stack_align = DEFINED (bsp_stack_align) ? bsp_stack_align : 8;
+bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 0;
+bsp_stack_exception_size = ALIGN (bsp_stack_exception_size, bsp_stack_align);
+bsp_stack_hyp_size = DEFINED (bsp_stack_hyp_size) ? bsp_stack_hyp_size : 0;
+bsp_stack_hyp_size = ALIGN (bsp_stack_hyp_size, bsp_stack_align);
+MEMORY {
+ UNEXPECTED_SECTIONS : ORIGIN = 0xffffffff, LENGTH = 0
+SECTIONS {
+ .start : ALIGN_WITH_INPUT {
+ bsp_section_start_begin = .;
+ KEEP (*(.bsp_start_text))
+ KEEP (*(.bsp_start_data))
+ bsp_section_start_end = .;
+ } > REGION_START AT > REGION_START
+ bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
+ .xbarrier : ALIGN_WITH_INPUT {
+ . = ALIGN (bsp_section_xbarrier_align);
+ } > REGION_VECTOR AT > REGION_VECTOR
+ .text : ALIGN_WITH_INPUT {
+ bsp_section_text_begin = .;
+ *(.text.unlikely .text.*_unlikely)
+ *(.text .stub .text.* .gnu.linkonce.t.*)
+ /* .gnu.warning sections are handled specially by elf32.em. */
+ *(.gnu.warning)
+ *(.glue_7t) *(.glue_7) *(.vfp11_veneer) *(.v4_bx)
+ } > REGION_TEXT AT > REGION_TEXT_LOAD
+ .init : ALIGN_WITH_INPUT {
+ KEEP (*(.init))
+ .fini : ALIGN_WITH_INPUT {
+ KEEP (*(.fini))
+ * If requested, align the size of the combined start and text
+ * section to the next power of two to meet MPU region
+ * alignment requirements.
+ . = DEFINED (bsp_section_do_mpu_align) ?
+ + ALIGN (. - bsp_section_start_begin,
+ 1 << LOG2CEIL (. - bsp_section_start_begin)) : .;
+ bsp_section_text_end = .;
+ bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
+ bsp_section_text_load_begin = LOADADDR (.text);
+ bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
+ .robarrier : ALIGN_WITH_INPUT {
+ . = ALIGN (bsp_section_robarrier_align);
+ } > REGION_RODATA AT > REGION_RODATA
+ .rodata : ALIGN_WITH_INPUT {
+ bsp_section_rodata_begin = .;
+ *(.rodata .rodata.* .gnu.linkonce.r.*)
+ } > REGION_RODATA AT > REGION_RODATA_LOAD
+ .rodata1 : ALIGN_WITH_INPUT {
+ *(.rodata1)
+ .ARM.extab : ALIGN_WITH_INPUT {
+ *(.ARM.extab* .gnu.linkonce.armextab.*)
+ .ARM.exidx : ALIGN_WITH_INPUT {
+ __exidx_start = .;
+ *(.ARM.exidx* .gnu.linkonce.armexidx.*)
+ __exidx_end = .;
+ .eh_frame : ALIGN_WITH_INPUT {
+ KEEP (*(.eh_frame))
+ .gcc_except_table : ALIGN_WITH_INPUT {
+ *(.gcc_except_table .gcc_except_table.*)
+ .tdata : ALIGN_WITH_INPUT {
+ _TLS_Data_begin = .;
+ *(.tdata .tdata.* .gnu.linkonce.td.*)
+ _TLS_Data_end = .;
+ .tbss : ALIGN_WITH_INPUT {
+ _TLS_BSS_begin = .;
+ *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
+ _TLS_BSS_end = .;
+ _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
+ _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
+ _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
+ _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
+ _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
+ _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
+ .preinit_array : ALIGN_WITH_INPUT {
+ PROVIDE_HIDDEN (__preinit_array_start = .);
+ KEEP (*(.preinit_array))
+ PROVIDE_HIDDEN (__preinit_array_end = .);
+ .init_array : ALIGN_WITH_INPUT {
+ PROVIDE_HIDDEN (__init_array_start = .);
+ KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*)))
+ KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .ctors))
+ PROVIDE_HIDDEN (__init_array_end = .);
+ .fini_array : ALIGN_WITH_INPUT {
+ PROVIDE_HIDDEN (__fini_array_start = .);
+ KEEP (*(SORT_BY_INIT_PRIORITY(.fini_array.*) SORT_BY_INIT_PRIORITY(.dtors.*)))
+ KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .dtors))
+ PROVIDE_HIDDEN (__fini_array_end = .);
+ .data.rel.ro : ALIGN_WITH_INPUT {
+ *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
+ *(.data.rel.ro* .gnu.linkonce.d.rel.ro.*)
+ .jcr : ALIGN_WITH_INPUT {
+ KEEP (*(.jcr))
+ .interp : ALIGN_WITH_INPUT {
+ *(.interp)
+ .note.gnu.build-id : ALIGN_WITH_INPUT {
+ *(.note.gnu.build-id)
+ .hash : ALIGN_WITH_INPUT {
+ *(.hash)
+ .gnu.hash : ALIGN_WITH_INPUT {
+ *(.gnu.hash)
+ .dynsym : ALIGN_WITH_INPUT {
+ *(.dynsym)
+ .dynstr : ALIGN_WITH_INPUT {
+ *(.dynstr)
+ .gnu.version : ALIGN_WITH_INPUT {
+ *(.gnu.version)
+ .gnu.version_d : ALIGN_WITH_INPUT {
+ *(.gnu.version_d)
+ .gnu.version_r : ALIGN_WITH_INPUT {
+ *(.gnu.version_r)
+ .rel.dyn : ALIGN_WITH_INPUT {
+ *(.rel.init)
+ *(.rel.text .rel.text.* .rel.gnu.linkonce.t.*)
+ *(.rel.fini)
+ *(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*)
+ *(.rel.data.rel.ro* .rel.gnu.linkonce.d.rel.ro.*)
+ *(.rel.data .rel.data.* .rel.gnu.linkonce.d.*)
+ *(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*)
+ *(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*)
+ *(.rel.ctors)
+ *(.rel.dtors)
+ *(.rel.got)
+ *(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*)
+ PROVIDE_HIDDEN (__rel_iplt_start = .);
+ *(.rel.iplt)
+ PROVIDE_HIDDEN (__rel_iplt_end = .);
+ PROVIDE_HIDDEN (__rela_iplt_start = .);
+ PROVIDE_HIDDEN (__rela_iplt_end = .);
+ .rela.dyn : ALIGN_WITH_INPUT {
+ *(.rela.init)
+ *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
+ *(.rela.fini)
+ *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
+ *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
+ *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
+ *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
+ *(.rela.ctors)
+ *(.rela.dtors)
+ *(.rela.got)
+ *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
+ *(.rela.rtemsroset*)
+ *(.rela.rtemsrwset*)
+ *(.rela.iplt)
+ .rel.plt : ALIGN_WITH_INPUT {
+ *(.rel.plt)
+ .rela.plt : ALIGN_WITH_INPUT {
+ *(.rela.plt)
+ .plt : ALIGN_WITH_INPUT {
+ *(.plt)
+ .iplt : ALIGN_WITH_INPUT {
+ *(.iplt)
+ .dynamic : ALIGN_WITH_INPUT {
+ *(.dynamic)
+ .tm_clone_table : ALIGN_WITH_INPUT {
+ *(.tm_clone_table)
+ .got : ALIGN_WITH_INPUT {
+ *(.got.plt) *(.igot.plt) *(.got) *(.igot)
+ .rtemsroset : ALIGN_WITH_INPUT SUBALIGN(4) {
+ /* Special FreeBSD linker set sections */
+ __start_set_sysctl_set = .;
+ *(set_sysctl_*);
+ __stop_set_sysctl_set = .;
+ *(set_domain_*);
+ *(set_pseudo_*);
+ KEEP (*(SORT(.rtemsroset.*)))
+ * If requested, align the size of the rodata section to the
+ * next power of two to meet MPU region alignment requirements.
+ + ALIGN (. - bsp_section_rodata_begin,
+ 1 << LOG2CEIL (. - bsp_section_rodata_begin)) : .;
+ bsp_section_rodata_end = .;
+ bsp_section_rodata_size = bsp_section_rodata_end - bsp_section_rodata_begin;
+ bsp_section_rodata_load_begin = LOADADDR (.rodata);
+ bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
+ .rwbarrier : ALIGN_WITH_INPUT {
+ . = ALIGN (bsp_section_rwbarrier_align);
+ } > REGION_DATA AT > REGION_DATA
+ .vector : ALIGN_WITH_INPUT {
+ bsp_section_vector_begin = .;
+ . = . + DEFINED (bsp_vector_table_in_start_section) ? 0 : bsp_vector_table_size;
+ bsp_section_vector_end = .;
+ bsp_section_vector_size = bsp_section_vector_end - bsp_section_vector_begin;
+ bsp_vector_table_begin = DEFINED (bsp_vector_table_in_start_section) ? bsp_section_start_begin : bsp_section_vector_begin;
+ bsp_vector_table_end = bsp_vector_table_begin + bsp_vector_table_size;
+ .fast_text : ALIGN_WITH_INPUT {
+ bsp_section_fast_text_begin = .;
+ *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.bsp_fast_text*)))
+ bsp_section_fast_text_end = .;
+ } > REGION_FAST_TEXT AT > REGION_FAST_TEXT_LOAD
+ bsp_section_fast_text_size = bsp_section_fast_text_end - bsp_section_fast_text_begin;
+ bsp_section_fast_text_load_begin = LOADADDR (.fast_text);
+ bsp_section_fast_text_load_end = bsp_section_fast_text_load_begin + bsp_section_fast_text_size;
+ .fast_data : ALIGN_WITH_INPUT {
+ bsp_section_fast_data_begin = .;
+ *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.bsp_fast_data*)))
+ bsp_section_fast_data_end = .;
+ } > REGION_FAST_DATA AT > REGION_FAST_DATA_LOAD
+ bsp_section_fast_data_size = bsp_section_fast_data_end - bsp_section_fast_data_begin;
+ bsp_section_fast_data_load_begin = LOADADDR (.fast_data);
+ bsp_section_fast_data_load_end = bsp_section_fast_data_load_begin + bsp_section_fast_data_size;
+ .data : ALIGN_WITH_INPUT {
+ bsp_section_data_begin = .;
+ *(.data .data.* .gnu.linkonce.d.*)
+ SORT(CONSTRUCTORS)
+ } > REGION_DATA AT > REGION_DATA_LOAD
+ .data1 : ALIGN_WITH_INPUT {
+ *(.data1)
+ .rtemsrwset : ALIGN_WITH_INPUT SUBALIGN(4) {
+ KEEP (*(SORT(.rtemsrwset.*)))
+ bsp_section_data_end = .;
+ bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
+ bsp_section_data_load_begin = LOADADDR (.data);
+ bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
+ .bss : ALIGN_WITH_INPUT {
+ bsp_section_bss_begin = .;
+ *(.dynbss)
+ *(.bss .bss.* .gnu.linkonce.b.*)
+ *(COMMON)
+ bsp_section_bss_end = .;
+ } > REGION_BSS AT > REGION_BSS
+ bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
+ .rtemsstack (NOLOAD) : ALIGN_WITH_INPUT {
+ bsp_section_rtemsstack_begin = .;
+ *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
+ bsp_section_rtemsstack_end = .;
+ } > REGION_WORK AT > REGION_WORK
+ bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
+ .work : ALIGN_WITH_INPUT {
+ * The work section will occupy the remaining REGION_WORK region and
+ * contains the RTEMS work space and heap.
+ bsp_section_work_begin = .;
+ . += ORIGIN (REGION_WORK) + LENGTH (REGION_WORK) - ABSOLUTE (.);
+ bsp_section_work_end = .;
+ bsp_section_work_size = bsp_section_work_end - bsp_section_work_begin;
+ .stack : ALIGN_WITH_INPUT {
+ * The stack section will occupy the remaining REGION_STACK region and may
+ * contain the task stacks. Depending on the region distribution this
+ * section may be of zero size.
+ bsp_section_stack_begin = .;
+ . += ORIGIN (REGION_STACK) + LENGTH (REGION_STACK) - ABSOLUTE (.);
+ bsp_section_stack_end = .;
+ } > REGION_STACK AT > REGION_STACK
+ bsp_section_stack_size = bsp_section_stack_end - bsp_section_stack_begin;
+ .nocache : ALIGN_WITH_INPUT {
+ bsp_section_nocache_begin = .;
+ *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.bsp_nocache*)))
+ bsp_section_nocache_end = .;
+ } > REGION_NOCACHE AT > REGION_NOCACHE_LOAD
+ bsp_section_nocache_size = bsp_section_nocache_end - bsp_section_nocache_begin;
+ bsp_section_nocache_load_begin = LOADADDR (.nocache);
+ bsp_section_nocache_load_end = bsp_section_nocache_load_begin + bsp_section_nocache_size;
+ .nocachenoload (NOLOAD) : ALIGN_WITH_INPUT {
+ bsp_section_nocachenoload_begin = .;
+ *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.bsp_noload_nocache*)))
+ bsp_section_nocacheheap_begin = .;
+ . += ORIGIN (REGION_NOCACHE) + LENGTH (REGION_NOCACHE) - ABSOLUTE (.);
+ bsp_section_nocacheheap_end = .;
+ bsp_section_nocachenoload_end = .;
+ bsp_section_nocacheheap_size = bsp_section_nocacheheap_end - bsp_section_nocacheheap_begin;
+ bsp_section_nocachenoload_size = bsp_section_nocachenoload_end - bsp_section_nocachenoload_begin;
+ /* FIXME */
+ RamBase = ORIGIN (REGION_WORK);
+ RamSize = LENGTH (REGION_WORK);
+ RamEnd = RamBase + RamSize;
+ WorkAreaBase = bsp_section_work_begin;
+ HeapSize = 0;
+ /* Stabs debugging sections. */
+ .stab 0 : { *(.stab) }
+ .stabstr 0 : { *(.stabstr) }
+ .stab.excl 0 : { *(.stab.excl) }
+ .stab.exclstr 0 : { *(.stab.exclstr) }
+ .stab.index 0 : { *(.stab.index) }
+ .stab.indexstr 0 : { *(.stab.indexstr) }
+ .comment 0 : { *(.comment) }
+ /* DWARF debug sections.
+ Symbols in the DWARF debugging sections are relative to the beginning
+ of the section so we begin them at 0. */
+ /* DWARF 1 */
+ .debug 0 : { *(.debug) }
+ .line 0 : { *(.line) }
+ /* GNU DWARF 1 extensions */
+ .debug_srcinfo 0 : { *(.debug_srcinfo) }
+ .debug_sfnames 0 : { *(.debug_sfnames) }
+ /* DWARF 1.1 and DWARF 2 */
+ .debug_aranges 0 : { *(.debug_aranges) }
+ .debug_pubnames 0 : { *(.debug_pubnames) }
+ /* DWARF 2 */
+ .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
+ .debug_abbrev 0 : { *(.debug_abbrev) }
+ .debug_line 0 : { *(.debug_line) }
+ .debug_frame 0 : { *(.debug_frame) }
+ .debug_str 0 : { *(.debug_str) }
+ .debug_loc 0 : { *(.debug_loc) }
+ .debug_macinfo 0 : { *(.debug_macinfo) }
+ /* SGI/MIPS DWARF 2 extensions */
+ .debug_weaknames 0 : { *(.debug_weaknames) }
+ .debug_funcnames 0 : { *(.debug_funcnames) }
+ .debug_typenames 0 : { *(.debug_typenames) }
+ .debug_varnames 0 : { *(.debug_varnames) }
+ /* DWARF 3 */
+ .debug_pubtypes 0 : { *(.debug_pubtypes) }
+ .debug_ranges 0 : { *(.debug_ranges) }
+ /* DWARF extension */
+ .debug_macro 0 : { *(.debug_macro) }
+ .ARM.attributes 0 : { KEEP (*(.ARM.attributes)) KEEP (*(.gnu.attributes)) }
+ .note.gnu.arm.ident 0 : { KEEP (*(.note.gnu.arm.ident)) }
+ /DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) *(.gnu.lto_*) }
+ * This is a RTEMS specific section to catch all unexpected input
+ * sections. In case you get an error like
+ * "section `.unexpected_sections' will not fit in region
+ * `UNEXPECTED_SECTIONS'"
+ * you have to figure out the offending input section and add it to the
+ * appropriate output section definition above.
+ .unexpected_sections : { *(*) } > UNEXPECTED_SECTIONS
diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
index 0000000000..d152aaa57f
--- /dev/null
+++ b/bsps/aarch64/shared/start/start.S
@@ -0,0 +1,217 @@
+ * @file
+ * @brief Boot and system start code.
+ * are met:
+#include <rtems/asm.h>
+#include <rtems/score/percpu.h>
+ /* Global symbols */
+ .globl _start
+ .section ".bsp_start_text", "ax"
+/* Start entry */
+_start:
+ * We do not save the context since we do not return to the boot
+ * loader but preserve x1 and x2 to allow access to bootloader parameters
+#ifndef BSP_START_NEEDS_REGISTER_INITIALIZATION
+ mov x5, x1 /* machine type number or ~0 for DT boot */
+ mov x6, x2 /* physical address of ATAGs or DTB */
+#else /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
+ mov x0, XZR
+ mov x1, XZR
+ mov x2, XZR
+ mov x3, XZR
+ mov x4, XZR
+ mov x5, XZR
+ mov x6, XZR
+ mov x7, XZR
+ mov x8, XZR
+ mov x9, XZR
+ mov x10, XZR
+ mov x11, XZR
+ mov x12, XZR
+ mov x13, XZR
+ mov x14, XZR
+ mov x15, XZR
+ mov x16, XZR
+ mov x17, XZR
+ mov x18, XZR
+ mov x19, XZR
+ mov x20, XZR
+ mov x21, XZR
+ mov x22, XZR
+ mov x23, XZR
+ mov x24, XZR
+ mov x25, XZR
+ mov x26, XZR
+ mov x27, XZR
+ mov x28, XZR
+ mov x29, XZR
+ mov x30, XZR
+#ifdef AARCH64_MULTILIB_VFP
+#endif
+#endif
+#ifdef RTEMS_SMP
+ /* Read MPIDR and get current processor index */
+ mrs x7, mpidr_el1
+ and x7, #0xff
+#endif
+#ifdef RTEMS_SMP
+ * Get current per-CPU control and store it in PL1 only Thread ID
+ * Register (TPIDRPRW).
+ ldr x1, =_Per_CPU_Information
+ add x1, x1, x7, asl #PER_CPU_CONTROL_SIZE_LOG2
+ mcr p15, 0, x1, c13, c0, 4
+#endif
+ /* Calculate interrupt stack area end for current processor */
+ ldr x1, =_ISR_Stack_size
+#ifdef RTEMS_SMP
+ add x3, x7, #1
+ mul x1, x1, x3
+#endif
+ ldr x2, =_ISR_Stack_area_begin
+ add x3, x1, x2
+ /* Save original DAIF value */
+ mrs x4, DAIF
+#ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
+ mov x8, XZR
+ mov x9, XZR
+ mov x10, XZR
+ mov x11, XZR
+ mov x12, XZR
+ mov x13, XZR
+ mov x14, XZR
+ mov x15, XZR
+#endif
+ * SPx: the stack pointer corresponding to the current exception level
+ * Normal operation for RTEMS on AArch64 uses SPx and runs on EL1
+ * Exception operation (synchronous errors, IRQ, FIQ, System Errors) uses SP0
+ ldr x1, =bsp_stack_exception_size
+ /* Switch to SP0 and set exception stack */
+ msr spsel, #0
+ mov sp, x3
+ /* Switch back to SPx for normal operation */
+ msr spsel, #1
+ sub x3, x3, x1
+ /* Set SP1 stack used for normal operation */
+ mov sp, x3
+ /* Stay in EL1 mode */
+#ifdef AARCH64_MULTILIB_HAS_CPACR
+ /* Read CPACR */
+ mrs x0, CPACR_EL1
+ /* Enable EL1 access permissions for CP10 */
+ orr x0, x0, #(1 << 20)
+ /* Write CPACR */
+ msr CPACR_EL1, x0
+ isb
+#endif
+ /* FPU does not need to be enabled on AArch64 */
+ mov x0, #0
+ mov CPTR_EL3, XZR
+ mov CPTR_EL2, XZR
+ mov d0, XZR
+ mov d1, XZR
+ mov d2, XZR
+ mov d3, XZR
+ mov d4, XZR
+ mov d5, XZR
+ mov d6, XZR
+ mov d7, XZR
+ mov d8, XZR
+ mov d9, XZR
+ mov d10, XZR
+ mov d11, XZR
+ mov d12, XZR
+ mov d13, XZR
+ mov d14, XZR
+ mov d15, XZR
+ mov d16, XZR
+ mov d17, XZR
+ mov d18, XZR
+ mov d19, XZR
+ mov d20, XZR
+ mov d21, XZR
+ mov d22, XZR
+ mov d23, XZR
+ mov d24, XZR
+ mov d25, XZR
+ mov d26, XZR
+ mov d27, XZR
+ mov d28, XZR
+ mov d29, XZR
+ mov d30, XZR
+ mov d31, XZR
+#endif /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
+#endif /* AARCH64_MULTILIB_VFP */
+ * Invoke the start hook 0.
+ mov x1, x5 /* machine type number or ~0 for DT boot */
+ bl bsp_start_hook_0
+ /* Branch to start hook 1 */
+ bl bsp_start_hook_1
+ /* Branch to boot card */
+ mov x0, #0
+ bl boot_card
diff --git a/spec/build/bsps/aarch64/a53/abi.yml b/spec/build/bsps/aarch64/a53/abi.yml
index 0000000000..f744a14464
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/abi.yml
@@ -0,0 +1,14 @@
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+default:
+- -mcpu=cortex-a53
+default-by-variant: []
+enabled-by: true
+links: []
+name: ABI_FLAGS
+description: |
+ ABI flags
+type: build
diff --git a/spec/build/bsps/aarch64/a53/bspa53lp64qemu.yml b/spec/build/bsps/aarch64/a53/bspa53lp64qemu.yml
index 0000000000..06c3a91265
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/bspa53lp64qemu.yml
@@ -0,0 +1,70 @@
+arch: aarch64
+bsp: a53_lp64_qemu
+build-type: bsp
+cflags: []
+cppflags: []
+enabled-by: true
+family: a53
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+ source:
+ - bsps/aarch64/a53/include/bsp.h
+ - bsps/aarch64/a53/include/tm27.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+ source:
+ - bsps/aarch64/a53/include/bsp/irq.h
+ - bsps/include/bsp/arm-gic-irq.h
+ - bsps/include/bsp/arm-gic-regs.h
+ - bsps/include/bsp/arm-gic-tm27.h
+ - bsps/include/bsp/arm-gic.h
+ - bsps/aarch64/include/bsp/irq-arch.h
+ - bsps/include/bsp/clock-arm-generic-timer.h
+links:
+- role: build-dependency
+ uid: ../start
+ uid: abi
+ uid: optloadoff
+ uid: optnocachelen
+ uid: optramlen
+ uid: optramori
+ uid: tsta53
+ uid: ../../obj
+ uid: ../../objirq
+ uid: ../../optcachedata
+ uid: ../../optcacheinst
+ uid: ../../opto2
+ uid: linkcmds
+ uid: ../../bspopts
+source:
+- bsps/aarch64/shared/cache/cache.c
+- bsps/aarch64/a53/console/console.c
+- bsps/aarch64/a53/start/bspstart.c
+- bsps/aarch64/a53/start/bspstarthooks.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspgetworkarea-default.c
+- bsps/shared/start/bspreset-psci.c
+- bsps/shared/start/sbrk.c
+- bsps/shared/irq/irq-arm-gicv3.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/clock/clock-arm-generic-timer.c
+- bsps/aarch64/shared/clock/clock-arm-generic-timer-aarch64.c
+type: build
diff --git a/spec/build/bsps/aarch64/a53/linkcmds.yml b/spec/build/bsps/aarch64/a53/linkcmds.yml
index 0000000000..23c99f693a
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/linkcmds.yml
@@ -0,0 +1,65 @@
+build-type: config-file
+content: |
+ * are met:
+ MEMORY {
+ RAM : ORIGIN = ${BSP_A53_RAM_BASE} + ${BSP_A53_LOAD_OFFSET}, LENGTH = ${BSP_A53_RAM_LENGTH} - ${BSP_A53_LOAD_OFFSET} - ${BSP_A53_NOCACHE_LENGTH}
+ NOCACHE : ORIGIN = ${BSP_A53_RAM_BASE} + ${BSP_A53_RAM_LENGTH} - ${BSP_A53_NOCACHE_LENGTH}, LENGTH = ${BSP_A53_NOCACHE_LENGTH}
+ REGION_ALIAS ("REGION_START", RAM);
+ REGION_ALIAS ("REGION_VECTOR", RAM);
+ REGION_ALIAS ("REGION_TEXT", RAM);
+ REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_RODATA", RAM);
+ REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_DATA", RAM);
+ REGION_ALIAS ("REGION_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_BSS", RAM);
+ REGION_ALIAS ("REGION_WORK", RAM);
+ REGION_ALIAS ("REGION_STACK", RAM);
+ REGION_ALIAS ("REGION_NOCACHE", NOCACHE);
+ REGION_ALIAS ("REGION_NOCACHE_LOAD", NOCACHE);
+ bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 1024;
+ bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+ bsp_vector_table_in_start_section = 1;
+ INCLUDE linkcmds.base
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/aarch64/a53/optloadoff.yml b/spec/build/bsps/aarch64/a53/optloadoff.yml
index 0000000000..96e4cea778
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/optloadoff.yml
@@ -0,0 +1,15 @@
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+default: 32768
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_A53_LOAD_OFFSET
+description: |
+ offset of RAM region from memory area base
+type: build
diff --git a/spec/build/bsps/aarch64/a53/optnocachelen.yml b/spec/build/bsps/aarch64/a53/optnocachelen.yml
index 0000000000..c117f2b644
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/optnocachelen.yml
@@ -0,0 +1,15 @@
+actions:
+- env-assign: null
+build-type: option
+default: 1048576
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_A53_NOCACHE_LENGTH
+description: |
+ length of nocache RAM region
+type: build
diff --git a/spec/build/bsps/aarch64/a53/optramlen.yml b/spec/build/bsps/aarch64/a53/optramlen.yml
index 0000000000..7af7d6e13f
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/optramlen.yml
@@ -0,0 +1,15 @@
+actions:
+- env-assign: null
+build-type: option
+default: 8388608
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_A53_RAM_LENGTH
+description: |
+ length of memory area available to the BSP
+type: build
diff --git a/spec/build/bsps/aarch64/a53/optramori.yml b/spec/build/bsps/aarch64/a53/optramori.yml
index 0000000000..0637b9ee91
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/optramori.yml
@@ -0,0 +1,15 @@
+actions:
+- env-assign: null
+build-type: option
+default: 1073741824
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_A53_RAM_BASE
+description: |
+ base address of memory area available to the BSP
+type: build
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index 0000000000..afc0e40043
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -0,0 +1,53 @@
+actions:
+- set-test-state:
+ # should pass, but don't?
+ spcpucounter01: exclude
+ rtmonuse: exclude
+ sp37: exclude
+ spedfsched04: exclude
+ sp68: exclude
+ spqreslib: exclude
+ sptimecounter02: exclude
+ # tests that are passing intermittently
+ sp04: exclude
+ sp20: exclude
+ sp69: exclude
+ rtmonusxtimes01: exclude
+ spedfsched02: exclude
+ psxtimes01: exclude
+ sprmsched01: exclude
+ sptimecounter04: exclude
+ # tests that time out
+ spintrcritical06: exclude
+ spintrcritical07: exclude
+ spintrcritical12: exclude
+ spintrcritical11: exclude
+ spintrcritical13: exclude
+ spintrcritical14: exclude
+ spintrcritical15: exclude
+ spintrcritical18: exclude
+ spintrcritical24: exclude
+ # don't compile due to toolchain issues
+ spconfig01: exclude
+ spmisc01: exclude
+default: null
+enabled-by: true
+links:
+ uid: ../../tstnoiconv
+ uid: ../../tstnojffs2
+ uid: ../../tstnolibdl
+ uid: ../../tstnorfs
+description: ''
+type: build
+build-type: option
diff --git a/spec/build/bsps/aarch64/start.yml b/spec/build/bsps/aarch64/start.yml
index 0000000000..809319beac
--- /dev/null
+++ b/spec/build/bsps/aarch64/start.yml
@@ -0,0 +1,11 @@
+asflags: []
+build-type: start-file
+cppflags: []
+enabled-by: true
+includes: []
+links: []
+source:
+- bsps/aarch64/shared/start/start.S
+target: start.o
+type: build
2.20.1
