[PATCH v1 8/8] bsps: Add Cortex-A53 ILP32 BSP variant
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Sep 25 15:27:32 UTC 2020
This adds an AArch64 ILP32 BSP variant based on Qemu's Cortex-A53
emulation with interrupt support using GICv3 and clock support using
the ARM GPT.
bsps/aarch64/shared/start/linkcmds.base | 4 --
bsps/aarch64/shared/start/start.S | 16 +++++
spec/build/bsps/aarch64/a53/abi.yml | 7 +-
.../bsps/aarch64/a53/bspa53ilp32qemu.yml | 70 +++++++++++++++++++
.../build/bsps/aarch64/a53/bspa53lp64qemu.yml | 2 +-
.../build/bsps/aarch64/a53/linkcmds_ilp32.yml | 68 ++++++++++++++++++
.../a53/{linkcmds.yml => linkcmds_lp64.yml} | 3 +
7 files changed, 164 insertions(+), 6 deletions(-)
create mode 100644 spec/build/bsps/aarch64/a53/bspa53ilp32qemu.yml
create mode 100644 spec/build/bsps/aarch64/a53/linkcmds_ilp32.yml
rename spec/build/bsps/aarch64/a53/{linkcmds.yml => linkcmds_lp64.yml} (97%)
diff --git a/bsps/aarch64/shared/start/linkcmds.base b/bsps/aarch64/shared/start/linkcmds.base
index ff8b379fa7..3da707e627 100644
--- a/bsps/aarch64/shared/start/linkcmds.base
+++ b/bsps/aarch64/shared/start/linkcmds.base
@@ -34,10 +34,6 @@
* POSSIBILITY OF SUCH DAMAGE.
-OUTPUT_FORMAT ("elf64-littleaarch64")
-OUTPUT_ARCH (aarch64)
ENTRY (_start)
STARTUP (start.o)
diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
index d152aaa57f..2a665a4116 100644
--- a/bsps/aarch64/shared/start/start.S
+++ b/bsps/aarch64/shared/start/start.S
@@ -99,19 +99,31 @@ _start:
* Get current per-CPU control and store it in PL1 only Thread ID
* Register (TPIDRPRW).
+#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
+ ldr w1, =_Per_CPU_Information
+#else
ldr x1, =_Per_CPU_Information
+#endif
add x1, x1, x7, asl #PER_CPU_CONTROL_SIZE_LOG2
mcr p15, 0, x1, c13, c0, 4
#endif
/* Calculate interrupt stack area end for current processor */
+ ldr w1, =_ISR_Stack_size
+#else
ldr x1, =_ISR_Stack_size
+#endif
#ifdef RTEMS_SMP
add x3, x7, #1
mul x1, x1, x3
#endif
+ ldr w2, =_ISR_Stack_area_begin
+#else
ldr x2, =_ISR_Stack_area_begin
+#endif
add x3, x1, x2
/* Save original DAIF value */
@@ -133,7 +145,11 @@ _start:
* Normal operation for RTEMS on AArch64 uses SPx and runs on EL1
* Exception operation (synchronous errors, IRQ, FIQ, System Errors) uses SP0
+ ldr w1, =bsp_stack_exception_size
+#else
ldr x1, =bsp_stack_exception_size
+#endif
/* Switch to SP0 and set exception stack */
msr spsel, #0
mov sp, x3
diff --git a/spec/build/bsps/aarch64/a53/abi.yml b/spec/build/bsps/aarch64/a53/abi.yml
index f744a14464..745045382c 100644
--- a/spec/build/bsps/aarch64/a53/abi.yml
+++ b/spec/build/bsps/aarch64/a53/abi.yml
@@ -5,7 +5,12 @@ actions:
build-type: option
default:
- -mcpu=cortex-a53
-default-by-variant: []
+default-by-variant:
+- value:
+ - -mcpu=cortex-a53
+ - -mabi=ilp32
+ variants:
+ - aarch64/a53_ilp32_qemu
enabled-by: true
links: []
diff --git a/spec/build/bsps/aarch64/a53/bspa53ilp32qemu.yml b/spec/build/bsps/aarch64/a53/bspa53ilp32qemu.yml
new file mode 100644
index 0000000000..88c9cf948f
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/bspa53ilp32qemu.yml
@@ -0,0 +1,70 @@
+arch: aarch64
+bsp: a53_ilp32_qemu
+build-type: bsp
+cflags: []
+cppflags: []
+enabled-by: true
+family: a53
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+ source:
+ - bsps/aarch64/a53/include/bsp.h
+ - bsps/aarch64/a53/include/tm27.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+ source:
+ - bsps/aarch64/a53/include/bsp/irq.h
+ - bsps/include/bsp/arm-gic-irq.h
+ - bsps/include/bsp/arm-gic-regs.h
+ - bsps/include/bsp/arm-gic-tm27.h
+ - bsps/include/bsp/arm-gic.h
+ - bsps/aarch64/include/bsp/irq-arch.h
+ - bsps/include/bsp/clock-arm-generic-timer.h
+links:
+- role: build-dependency
+ uid: ../start
+ uid: abi
+ uid: optloadoff
+ uid: optnocachelen
+ uid: optramlen
+ uid: optramori
+ uid: tsta53
+ uid: ../../obj
+ uid: ../../objirq
+ uid: ../../optcachedata
+ uid: ../../optcacheinst
+ uid: ../../opto2
+ uid: linkcmds_ilp32
+ uid: ../../bspopts
+source:
+- bsps/aarch64/shared/cache/cache.c
+- bsps/aarch64/a53/console/console.c
+- bsps/aarch64/a53/start/bspstart.c
+- bsps/aarch64/a53/start/bspstarthooks.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspgetworkarea-default.c
+- bsps/shared/start/bspreset-psci.c
+- bsps/shared/start/sbrk.c
+- bsps/shared/irq/irq-arm-gicv3.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/clock/clock-arm-generic-timer.c
+- bsps/aarch64/shared/clock/clock-arm-generic-timer-aarch64.c
+type: build
diff --git a/spec/build/bsps/aarch64/a53/bspa53lp64qemu.yml b/spec/build/bsps/aarch64/a53/bspa53lp64qemu.yml
index 06c3a91265..ee99200b18 100644
--- a/spec/build/bsps/aarch64/a53/bspa53lp64qemu.yml
+++ b/spec/build/bsps/aarch64/a53/bspa53lp64qemu.yml
@@ -46,7 +46,7 @@ links:
uid: ../../opto2
- uid: linkcmds
+ uid: linkcmds_lp64
uid: ../../bspopts
source:
diff --git a/spec/build/bsps/aarch64/a53/linkcmds_ilp32.yml b/spec/build/bsps/aarch64/a53/linkcmds_ilp32.yml
index 0000000000..9f6872215a
--- /dev/null
+++ b/spec/build/bsps/aarch64/a53/linkcmds_ilp32.yml
@@ -0,0 +1,68 @@
+build-type: config-file
+content: |
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ MEMORY {
+ RAM : ORIGIN = ${BSP_A53_RAM_BASE} + ${BSP_A53_LOAD_OFFSET}, LENGTH = ${BSP_A53_RAM_LENGTH} - ${BSP_A53_LOAD_OFFSET} - ${BSP_A53_NOCACHE_LENGTH}
+ NOCACHE : ORIGIN = ${BSP_A53_RAM_BASE} + ${BSP_A53_RAM_LENGTH} - ${BSP_A53_NOCACHE_LENGTH}, LENGTH = ${BSP_A53_NOCACHE_LENGTH}
+ REGION_ALIAS ("REGION_START", RAM);
+ REGION_ALIAS ("REGION_VECTOR", RAM);
+ REGION_ALIAS ("REGION_TEXT", RAM);
+ REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_RODATA", RAM);
+ REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_DATA", RAM);
+ REGION_ALIAS ("REGION_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_BSS", RAM);
+ REGION_ALIAS ("REGION_WORK", RAM);
+ REGION_ALIAS ("REGION_STACK", RAM);
+ REGION_ALIAS ("REGION_NOCACHE", NOCACHE);
+ REGION_ALIAS ("REGION_NOCACHE_LOAD", NOCACHE);
+ bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 1024;
+ bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+ bsp_vector_table_in_start_section = 1;
+ OUTPUT_FORMAT ("elf32-littleaarch64")
+ OUTPUT_ARCH (aarch64:ilp32)
+ INCLUDE linkcmds.base
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/aarch64/a53/linkcmds.yml b/spec/build/bsps/aarch64/a53/linkcmds_lp64.yml
similarity index 97%
rename from spec/build/bsps/aarch64/a53/linkcmds.yml
rename to spec/build/bsps/aarch64/a53/linkcmds_lp64.yml
index 23c99f693a..33732a7fbb 100644
--- a/spec/build/bsps/aarch64/a53/linkcmds.yml
+++ b/spec/build/bsps/aarch64/a53/linkcmds_lp64.yml
@@ -57,6 +57,9 @@ content: |
+ OUTPUT_FORMAT ("elf64-littleaarch64")
+ OUTPUT_ARCH (aarch64)
enabled-by: true
2.20.1
