Configure options not in waf
Fri Sep 25 16:11:34 UTC 2020
On 25/09/2020 17:39, Joel Sherrill wrote:
> Hi
> There may be more but so far, the generated default config.ini does
> not appear to have settings which correspond to --enable-profiling or
> --enable-cxx.
The --enable-profiling is RTEMS_PROFILING. I will add it to the
migration section.
C++ is always enabled, why should it be disabled?
