Configure options not in waf
Fri Sep 25 16:36:19 UTC 2020
On Fri, Sep 25, 2020, 11:11 AM Sebastian Huber <
> On 25/09/2020 17:39, Joel Sherrill wrote:
> > Hi
> > There may be more but so far, the generated default config.ini does
> > not appear to have settings which correspond to --enable-profiling or
> > --enable-cxx.
> The --enable-profiling is RTEMS_PROFILING. I will add it to the
> migration section.
Thanks. It isn't printed by bsp_defaults so it needs to be added.
> C++ is always enabled, why should it be disabled?
Historically some targets did not have C++ support. I think epiphany was
the most recent example of that.
I don't think this should be eliminated.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200925/7a5e0c92/attachment.html>
