Configure options not in waf
Sebastian Huber
Fri Sep 25 16:38:55 UTC 2020
On 25/09/2020 18:36, Joel Sherrill wrote:
> On Fri, Sep 25, 2020, 11:11 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 25/09/2020 17:39, Joel Sherrill wrote:
> > Hi
> > There may be more but so far, the generated default config.ini does
> > not appear to have settings which correspond to
> --enable-profiling or
> > --enable-cxx.
> The --enable-profiling is RTEMS_PROFILING. I will add it to the
> migration section.
> Thanks. It isn't printed by bsp_defaults so it needs to be added.
Ok, this one is really missing.
> C++ is always enabled, why should it be disabled?
> Historically some targets did not have C++ support. I think epiphany
> was the most recent example of that.
> I don't think this should be eliminated.
Currently, all targets support C++. If we really need to disable it for
a target in the future, then we can add it again.
