[PATCH] Confstr Patches
Fri Sep 25 20:54:14 UTC 2020
This is the last discussion of the patch I could find. Have you made these
changes?
Also if it is going to go on the master, the waf build side needs updating.
For the near future, both build systems will be in place so we can ensure
the transition is smooth and doesn't introduce anything.
--joel
On Sun, Sep 13, 2020 at 4:05 PM Joel Sherrill <joel at rtems.org> wrote:
> Review feedback should stay on the list. :)
> On Sat, Sep 12, 2020 at 4:29 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> On Sat, Sep 12, 2020 at 2:45 AM Joel Sherrill <joel at rtems.org> wrote:
>>> This looks close to me but I see some minor issues. I have tried to
>>> annotate them.
>>> The spacing ones could be spaces vs tabs. Not sure.
>>> On Thu, Sep 10, 2020 at 3:48 PM Eshan dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>>> Adds Confstr file To RTEMS with test
>>>> Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
>>>>  cpukit/Makefile.am                            |   1 +
>>>>  cpukit/posix/src/confstr.c                    | 105 +++++++++++++++
>>>>  testsuites/psxtests/Makefile.am               |   9 ++
>>>>  testsuites/psxtests/configure.ac              |   1 +
>>>>  testsuites/psxtests/psxconfstr/init.c         | 125 ++++++++++++++++++
>>>>  testsuites/psxtests/psxconfstr/psxconfstr.doc |  17 +++
>>>>  testsuites/psxtests/psxconfstr/psxconfstr.scn |   4 +
>>>>  7 files changed, 262 insertions(+)
>>>>  create mode 100644 cpukit/posix/src/confstr.c
>>>>  create mode 100644 testsuites/psxtests/psxconfstr/init.c
>>>>  create mode 100644 testsuites/psxtests/psxconfstr/psxconfstr.doc
>>>>  create mode 100644 testsuites/psxtests/psxconfstr/psxconfstr.scn
>>>> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
>>>> index e5009e53c9..1c9e4697f1 100644
>>>> --- a/cpukit/Makefile.am
>>>> +++ b/cpukit/Makefile.am
>>>> @@ -509,6 +509,7 @@ librtemscpu_a_SOURCES += posix/src/condsignalsupp.c
>>>>  librtemscpu_a_SOURCES += posix/src/condtimedwait.c
>>>>  librtemscpu_a_SOURCES += posix/src/condwait.c
>>>>  librtemscpu_a_SOURCES += posix/src/condwaitsupp.c
>>>> +librtemscpu_a_SOURCES += posix/src/confstr.c
>>>>  librtemscpu_a_SOURCES += posix/src/_execve.c
>>>>  librtemscpu_a_SOURCES += posix/src/fork.c
>>>>  librtemscpu_a_SOURCES += posix/src/key.c
>>>> diff --git a/cpukit/posix/src/confstr.c b/cpukit/posix/src/confstr.c
>>>> new file mode 100644
>>>> index 0000000000..71041db462
>>>> --- /dev/null
>>>> +++ b/cpukit/posix/src/confstr.c
>>>> @@ -0,0 +1,105 @@
>>>> + * SPDX-License-Identifier: BSD-3-Clause
>>>> + * Copyright (c) 1993
>>>> + *     The Regents of the University of California.  All rights
>>>> reserved.
>>>> + * Redistribution and use in source and binary forms, with or without
>>>> + * modification, are permitted provided that the following conditions
>>>> + * are met:
>>>> + * 1. Redistributions of source code must retain the above copyright
>>>> + *    notice, this list of conditions and the following disclaimer.
>>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>>> + *    notice, this list of conditions and the following disclaimer in
>>>> the
>>>> + *    documentation and/or other materials provided with the
>>>> distribution.
>>>> + * 3. Neither the name of the University nor the names of its
>>>> contributors
>>>> + *    may be used to endorse or promote products derived from this
>>>> software
>>>> + *    without specific prior written permission.
>>>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS''
>>>> AND
>>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>>>> THE
>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>> PURPOSE
>>>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE
>>>> LIABLE
>>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>> CONSEQUENTIAL
>>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
>>>> GOODS
>>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>>>> INTERRUPTION)
>>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
>>>> STRICT
>>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
>>>> ANY WAY
>>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
>>>> OF
>>>> + * SUCH DAMAGE.
>>>> +#include <sys/cdefs.h>
>>>> +__SCCSID("@(#)confstr.c        8.1 (Berkeley) 6/4/93");
>>>> +__FBSDID("$FreeBSD$");
>>> Probably worth adding a comment above that the FreeBSD version
>>> was reduced to what made sense on RTEMS.
>> OK
>>>> +#include <sys/param.h>
>>>> +#include <errno.h>
>>>> +#include <limits.h>
>>>> +#include <paths.h>
>>>> +#include <string.h>
>>>> +#include <unistd.h>
>>>> If you do that, you won't need all these headers.
>> I left the headers there if someone adds an implementation or extends it.
>> If it made sense
> That makes sense but remove them anyway. One day we may be able to
> automatically check if something is really needed.
>>>> +size_t
>>>> +confstr(int name, char *buf, size_t len)
>>>> +       const char *p;
>>>> +       const char UPE[] = "unsupported programming environment";
>>>> +       switch (name) {
>>>> +#ifndef __rtems__
>>>> +       case _CS_PATH:
>>>> +               p = _PATH_STDPATH;
>>>> +               goto docopy;
>>>> +#endif
>>> It looks like the body of the other cases were gutted from the freebsd
>>> code. Why keep an ifndef RTEMS here? This is just going to produce
>>> an error for an unknown name via the default case. If we are going to
>>> delete all non-FreeBSD code from this and make it a more RTEMS
>>> specific implementation, you might as well just do this:
>>>         case _CS_PATH:
>>>               errno = EINVAL;
>>>               return (0);
>>> That keeps the order like the FreeBSD without ifdefs.
>> OK
>>>> +                * POSIX/SUS ``Programming Environments'' stuff
>>>> +                * We don't support more than one programming
>>>> environment
>>>> +                * on any platform (yet), so we just return the empty
>>>> +                * string for the environment we are compiled for,
>>>> +                * and the string "unsupported programming environment"
>>>> +                * for anything else.  (The Standard says that if these
>>>> +                * values are used on a system which does not support
>>>> +                * this environment -- determined via sysconf() -- then
>>>> +                * the value we return is unspecified.  So, we return
>>>> +                * something which will cause obvious breakage.)
>>>> +       case _CS_POSIX_V6_ILP32_OFF32_CFLAGS:
>>>> +       case _CS_POSIX_V6_ILP32_OFF32_LDFLAGS:
>>>> +       case _CS_POSIX_V6_ILP32_OFF32_LIBS:
>>>> +       case _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS:
>>>> +       case _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS:
>>>> +       case _CS_POSIX_V6_LPBIG_OFFBIG_LIBS:
>>>> +               p = UPE;
>>>> +               goto docopy;
>>>> +       case _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS:
>>>> +       case _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS:
>>>> +       case _CS_POSIX_V6_ILP32_OFFBIG_LIBS:
>>>> +                       p = UPE;
>>>> +               goto docopy;
>>> Spacing.
>> The spacing is coming from freebsd . I will update that :)
>>>> +       case _CS_POSIX_V6_LP64_OFF64_CFLAGS:
>>>> +       case _CS_POSIX_V6_LP64_OFF64_LDFLAGS:
>>>> +       case _CS_POSIX_V6_LP64_OFF64_LIBS:
>>>> +                       p = UPE;
>>>> +               goto docopy;
>>> Spacing.
>>>> +docopy:
>>>> +               if (len != 0 && buf != NULL)
>>>> +                       strlcpy(buf, p, len);
>>>> +               return (strlen(p) + 1);
>>>> +       default:
>>>> +               errno = EINVAL;
>>>> +               return (0);
>>>> +       /* NOTREACHED */
>>>> diff --git a/testsuites/psxtests/Makefile.am
>>>> b/testsuites/psxtests/Makefile.am
>>>> index aae5fe764a..f0910330a9 100755
>>>> --- a/testsuites/psxtests/Makefile.am
>>>> +++ b/testsuites/psxtests/Makefile.am
>>>> @@ -358,6 +358,15 @@ psxconfig01_CPPFLAGS = $(AM_CPPFLAGS)
>>>> $(TEST_FLAGS_psxconfig01) \
>>>>         $(support_includes) -I$(top_srcdir)/include
>>>>  endif
>>>> +if TEST_psxgetcpuclockid01
>>>> +psx_tests += psxconfstr
>>>> +psx_screens += psxconfstr/psxconfstr.scn
>>>> +psx_docs += psxconfstr/psxconfstr.doc
>>>> +psxconfstr_SOURCES = psxconfstr/init.c
>>>> +psxconfstr_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetcpuclockid01) \
>>>> +       $(support_includes)
>>>> +endif
>>>>  if TEST_psxdevctl01
>>>>  psx_tests += psxdevctl01
>>>>  psx_screens += psxdevctl01/psxdevctl01.scn
>>>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
>>>> configure.ac
>>>> index c509086abc..96c937cb4d 100644
>>>> --- a/testsuites/psxtests/configure.ac
>>>> +++ b/testsuites/psxtests/configure.ac
>>>> @@ -80,6 +80,7 @@ RTEMS_TEST_CHECK([psxconcurrency01])
>>>>  RTEMS_TEST_CHECK([psxcond01])
>>>>  RTEMS_TEST_CHECK([psxcond02])
>>>>  RTEMS_TEST_CHECK([psxconfig01])
>>>> +RTEMS_TEST_CHECK([psxconfstr])
>>>>  RTEMS_TEST_CHECK([psxdevctl01])
>>>>  RTEMS_TEST_CHECK([psxeintr_join])
>>>>  RTEMS_TEST_CHECK([psxenosys])
>>>> diff --git a/testsuites/psxtests/psxconfstr/init.c
>>>> b/testsuites/psxtests/psxconfstr/init.c
>>>> index 0000000000..7219470559
>>>> --- /dev/null
>>>> +++ b/testsuites/psxtests/psxconfstr/init.c
>>>> @@ -0,0 +1,125 @@
>>>> + *  @file
>>>> + *  @brief Test suite for confstr method
>>>> + * SPDX-License-Identifier: BSD-2-Clause
>>>> + * Copyright (C) 2020 Eshan Dhawan, Sebastian Huber
>>>> + * are met:
>>>> the
>>>> distribution.
>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>>> "AS IS"
>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>> TO, THE
>>>> PURPOSE
>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>>> CONTRIBUTORS BE
>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>> BUSINESS
>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>> WHETHER IN
>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>> OTHERWISE)
>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>>> OF THE
>>>> + * POSSIBILITY OF SUCH DAMAGE.
>>>> +#ifdef HAVE_CONFIG_H
>>>> +#include "config.h"
>>>> +#endif
>>>> +#include <errno.h>
>>>> +#include <stdio.h>
>>>> +#include <rtems.h>
>>>> +#include <rtems/test.h>
>>>> +#include <rtems/bspIo.h>
>>>> +#include "tmacros.h"
>>>> +#include "test_support.h"
>>>> +const char rtems_test_name[] = "PSXCONFSTR";
>>>> +/* Forward declaration to avoid warnings */
>>>> +rtems_task Init( rtems_task_argument ignored );
>>>> +static char buffer[512];
>>>> +static const T_action actions[] = {
>>>> +  T_report_hash_sha256,
>>>> +  T_check_task_context,
>>>> +  T_check_file_descriptors,
>>>> +  T_check_rtems_barriers,
>>>> +  T_check_rtems_extensions,
>>>> +  T_check_rtems_message_queues,
>>>> +  T_check_rtems_partitions,
>>>> +  T_check_rtems_periods,
>>>> +  T_check_rtems_regions,
>>>> +  T_check_rtems_semaphores,
>>>> +  T_check_rtems_tasks,
>>>> +  T_check_rtems_timers,
>>>> +  T_check_posix_keys
>>>> Is this a remnant of a copied test? Is it used?
>> I don't actually know its effect its the part of the generic runner
>> provided by sebastian for the new test framework.
>>>> +static const T_config config = {
>>>> +  .name = "psxconfstr",
>>>> +  .buf = buffer,
>>>> +  .putchar = rtems_put_char,
>>>> +  .buf_size = sizeof(buffer),
>>>> +  .verbosity = T_VERBOSE,
>>>> +  .now = T_now_clock,
>>>> +  .action_count = T_ARRAY_SIZE(actions),
>>>> +  .actions = actions
>>>> +/* init test function begins */
>>>> +T_TEST_CASE(confstr)
>>>> +int r;
>>>> +  char * buf ;
>>>> +  size_t len1;
>>>> +  len1 = strlen(UPE) + 1;
>>>> +  r = confstr(_CS_PATH, buf, sizeof(buf));
>>>> +  T_quiet_psx_success(r);
>>>> +  r = confstr(_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS, buf, sizeof(buf));
>>>> +  T_quiet_eq_int(r, len1);
>>>> You should exercise every known good value for a name. Plus a randomly
>>> bad one.
>> OK, I will update this
>>>> +rtems_task Init(rtems_task_argument ignored)
>>>> +  int exit_code;
>>>> +  TEST_BEGIN();
>>>> +  T_register();
>>>> +  exit_code = T_main(&config);
>>>> +  if (exit_code == 0) {
>>>> +    TEST_END();
>>>> + rtems_test_exit(exit_code);
>>>> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>>>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>> +#define CONFIGURE_MAXIMUM_TASKS 1
>>>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>> +#include <rtems/confdefs.h>
>>>> +/* end of file */
>>>> diff --git a/testsuites/psxtests/psxconfstr/psxconfstr.doc
>>>> b/testsuites/psxtests/psxconfstr/psxconfstr.doc
>>>> index 0000000000..e353f74ae7
>>>> --- /dev/null
>>>> +++ b/testsuites/psxtests/psxconfstr/psxconfstr.doc
>>>> @@ -0,0 +1,17 @@
>>>> +#  COPYRIGHT (c) 2020
>>>> +#  On-Line Applications Research Corporation (OAR).
>>>> +# SPDX-License-Identifier: BSD-2-Clause
>>>> +This file describes the directives and concepts tested by this test
>>>> set.
>>>> +test set name:  psxconfstr
>>>> +Directives:
>>>> +  Pthread_getcpuclockid()
>>> Not right.
>> this is a remenant from other test case :)
> I expected that. Just review and double check. I might have missed others.
>>>> +Concepts:
>>>> ++ This test exercises the confstr method
>>>> diff --git a/testsuites/psxtests/psxconfstr/psxconfstr.scn
>>>> b/testsuites/psxtests/psxconfstr/psxconfstr.scn
>>>> index 0000000000..705a08d51b
>>>> --- /dev/null
>>>> +++ b/testsuites/psxtests/psxconfstr/psxconfstr.scn
>>>> @@ -0,0 +1,4 @@
>>>> +*** BEGIN OF TEST PSXGETCPUCLOCKID 1 ***
>>>> +*** END OF TEST PSXGETCPUCLOCKID 1 ***
>>> I'm betting this isn't right either. :)
>> This is the remnant of the other test case :)
>> will update it in the next version :)
>>> --joel
>>>> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200925/123970b2/attachment-0001.html>
