[PATCH v4] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Gedare Bloom
gedare at rtems.org
Mon Sep 28 16:28:13 UTC 2020
Hi Utkarsh,
I was starting to review this, but then I got a little bit confused by
what you have done.
I think you may have gone down the wrong path to do this work. It
looks like you copied from libtests/ttest01 to construct this test.
That is actually a test for the testing infrastructure itself. So its
format isn't really the proper way to structure a posix clock test. I
know there aren't a lot of examples of the TTest framework, but this
should be structured more like one of the existing
sptests/smptests/psxtests that is using the T_TEST_CASE().
https://docs.rtems.org/branches/master/eng/test-framework.html#the-rtems-test-framework
Perhaps, restart with something simpler and send that first. Then you
should take a look at the existing test we have for the
clock_nanosleep() that only does CLOCK_REALTIME for some of the logic
to test as well. It seems like you have done a pretty basic API-level
test, but it is only checking some return values and not actually
verifying the implementation did anything.
On Mon, Sep 21, 2020 at 9:15 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> From: Utkarsh <utkarsh.rai60 at gmail.com>
Please use full (legal) name for commit metadata
> Closes #3890
> Signed-off-by: Utkarsh Rai <utkarsh.rai60 at gmail.com>
> spec/build/testsuites/psxtests/grp.yml | 2 +
> .../psxtests/psxclocknanosleep01.yml | 20 +++
> .../psxtests/psxclocknanosleep01/init.c | 94 ++++++++++++++
> .../psxclocknanosleep01.doc | 13 ++
> .../psxclocknanosleep01.scn | 41 ++++++
> .../test-clock-nanosleep.c | 120 ++++++++++++++++++
> 6 files changed, 290 insertions(+)
> create mode 100644 spec/build/testsuites/psxtests/psxclocknanosleep01.yml
> create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
> create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> create mode 100644 testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
> index 47dedac275..3342fc6c18 100644
> --- a/spec/build/testsuites/psxtests/grp.yml
> +++ b/spec/build/testsuites/psxtests/grp.yml
> @@ -79,6 +79,8 @@ links:
> uid: psxclock
> - role: build-dependency
> uid: psxclock01
> +- role: build-dependency
> + uid: psxclocknanosleep01
> uid: psxclockrealtime01
> diff --git a/spec/build/testsuites/psxtests/psxclocknanosleep01.yml b/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
> new file mode 100644
> index 0000000000..39ec1657d2
> --- /dev/null
> +++ b/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
> @@ -0,0 +1,20 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: test-program
> +cflags: []
> +copyrights:
> +- Copyright (C) 2020 Utkarsh Rai (utkarsh.rai60 at mail.com)
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +features: c cprogram
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/psxtests/psxclocknanosleep01/init.c
> +- testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> +stlib: []
> +target: testsuites/psxtests/psxclocknanosleep01.exe
> +type: build
> +use-after: []
> +use-before: []
> diff --git a/testsuites/psxtests/psxclocknanosleep01/init.c b/testsuites/psxtests/psxclocknanosleep01/init.c
> index 0000000000..a5cb4d6054
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep01/init.c
> @@ -0,0 +1,94 @@
> +/* SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2020 Utkarsh Rai
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems.h>
> +#include <rtems/bspIo.h>
> +#include <rtems/linkersets.h>
> +#include <rtems/test.h>
> +#include <rtems/test-info.h>
> +#include <tmacros.h>
> +const char rtems_test_name[] = "PSXCLOCKNANOSLEEP01";
> +static char buffer[512];
> +static const T_action actions[] = {
> + T_report_hash_sha256,
> + T_check_task_context,
> + T_check_file_descriptors,
> + T_check_rtems_barriers,
> + T_check_rtems_extensions,
> + T_check_rtems_message_queues,
> + T_check_rtems_partitions,
> + T_check_rtems_periods,
> + T_check_rtems_regions,
> + T_check_rtems_semaphores,
> + T_check_rtems_tasks,
> + T_check_rtems_timers,
> + T_check_posix_keys
> +static const T_config config = {
> + .name = "POSIXCLOCKNANOSLEEPTEST01",
> + .buf = buffer,
> + .buf_size = sizeof( buffer ),
> + .putchar = rtems_put_char,
> + .verbosity = T_VERBOSE,
> + .now = T_now_clock,
> + .action_count = T_ARRAY_SIZE( actions ),
> + .actions = actions
> +static void
> +Init( rtems_task_argument arg )
> + int exit_code;
> + (void) arg;
> + TEST_BEGIN();
> + T_register();
> + exit_code = T_main( &config );
> + if (exit_code == 0) {
> + TEST_END();
> + rtems_test_exit( exit_code );
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT
> +#include <rtems/confdefs.h>
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> index 0000000000..803c2cff15
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> @@ -0,0 +1,13 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: psxclocknanosleep01
> +directives:
> +- clock_nanosleep()
> +concepts:
> +- Test some invalid and extreme timeout values.
> +- Ensure that the CLOCK_MONOTONIC based delay is not affected by changes to
> + CLOCK_REALTIME
> diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> index 0000000000..aa0050e3cd
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> @@ -0,0 +1,41 @@
> +*** BEGIN OF TEST PSXCLOCKNANOSLEEP01 ***
> +*** TEST VERSION: 6.0.0.314dae32156aa3d1f54f1ee104b26604a32cae4f
> +*** TEST STATE: EXPECTED_PASS
> +*** TEST BUILD:
> +*** TEST TOOLS: 10.2.1 20200904 (RTEMS 6, RSB 47f32b8b1a597b5ed3475722bdc155249ef51115, Newlib a0d7982)
> +A:POSIXCLOCKNANOSLEEPTEST01
> +S:Platform:RTEMS
> +S:Compiler:10.2.1 20200904 (RTEMS 6, RSB 47f32b8b1a597b5ed3475722bdc155249ef51115, Newlib a0d7982)
> +S:Version:6.0.0.314dae32156aa3d1f54f1ee104b26604a32cae4f
> +S:BSP:realview_pbx_a9_qemu
> +S:RTEMS_DEBUG:0
> +S:RTEMS_MULTIPROCESSING:0
> +S:RTEMS_POSIX_API:0
> +S:RTEMS_PROFILING:0
> +S:RTEMS_SMP:0
> +B:POSIXClock_Timeout_negative_sec_nsec
> +P:0:0:UI1:test-clock-nanosleep.c:97
> +E:POSIXClock_Timeout_negative_sec_nsec:N:1:F:0:D:0.003693
> +P:0:0:UI1:test-clock-nanosleep.c:72
> +E:POSIXClock_Timeout_negative_sec:N:1:F:0:D:0.000347
> +B:POSIXClock_Timeout_negative_nsec
> +P:0:0:UI1:test-clock-nanosleep.c:85
> +E:POSIXClock_Timeout_negative_nsec:N:1:F:0:D:0.000227
> +B:POSIXClock_Timeout_huge_nsec
> +P:0:0:UI1:test-clock-nanosleep.c:60
> +E:POSIXClock_Timeout_huge_nsec:N:1:F:0:D:0.000224
> +B:POSIXClock_Timeout_finite
> +P:0:0:UI1:test-clock-nanosleep.c:43
> +P:1:0:UI1:test-clock-nanosleep.c:48
> +E:POSIXClock_Timeout_finite:N:2:F:0:D:0.002504
> +B:POSIXClock_Timeout_clock_modify
> +P:0:0:UI1:test-clock-nanosleep.c:107
> +P:1:0:UI1:test-clock-nanosleep.c:111
> +P:2:0:UI1:test-clock-nanosleep.c:114
> +P:3:0:UI1:test-clock-nanosleep.c:119
> +E:POSIXClock_Timeout_clock_modify:N:4:F:0:D:1.009321
> +Z:POSIXCLOCKNANOSLEEPTEST01:C:6:N:10:F:0:D:1.018286
> +Y:ReportHash:SHA256:cc043d8e8d1a25d2d3a5fb341169ebd8b64e8ba10bc85f34c9905e89c1e01b4f
> +*** END OF TEST PSXCLOCKNANOSLEEP01 ***
> diff --git a/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c b/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> index 0000000000..d61829c5fe
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> @@ -0,0 +1,120 @@
> + * are met:
> +#endif
> +#include <errno.h>
> +#include <limits.h>
> +#include <time.h>
> +T_TEST_CASE( POSIXClock_Timeout_finite )
> + struct timespec delay_time;
> + int eno;
> + eno = clock_gettime( CLOCK_MONOTONIC, &delay_time );
> + T_eno_success( eno );
> + delay_time.tv_sec = 1;
> + eno = clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &delay_time, NULL );
> +T_TEST_CASE( POSIXClock_Timeout_huge_nsec )
> + int eno;
> + delay_time.tv_nsec = LONG_MAX;
> + T_eno( EINVAL, eno );
> +T_TEST_CASE( POSIXClock_Timeout_negative_sec )
> + int eno;
> + delay_time.tv_sec = -1;
> + delay_time.tv_nsec = 1;
> +T_TEST_CASE( POSIXClock_Timeout_negative_nsec )
> + int eno;
> + delay_time.tv_nsec = -1;
> +T_TEST_CASE(POSIXClock_Timeout_negative_sec_nsec)
> + int eno;
> + T_eno( EINVAL, eno);
> +T_TEST_CASE( POSIXClock_Timeout_clock_modify )
> + struct timespec configure_time;
> + int eno;
> + eno = clock_gettime( CLOCK_REALTIME, &configure_time );
> + configure_time.tv_sec += 3600;
> + eno = clock_settime( CLOCK_REALTIME, &configure_time );
> + delay_time.tv_sec += 1;
> 2.17.1
> devel mailing list
> devel at rtems.org
