[PATCH v4] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Utkarsh Rai
utkarsh.rai60 at gmail.com
Mon Sep 28 16:55:17 UTC 2020
On Mon, Sep 28, 2020 at 9:58 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Utkarsh,
> I was starting to review this, but then I got a little bit confused by
> what you have done.
> I think you may have gone down the wrong path to do this work. It
> looks like you copied from libtests/ttest01 to construct this test.
> That is actually a test for the testing infrastructure itself. So its
> format isn't really the proper way to structure a posix clock test. I
> know there aren't a lot of examples of the TTest framework, but this
> should be structured more like one of the existing
> sptests/smptests/psxtests that is using the T_TEST_CASE().
> https://docs.rtems.org/branches/master/eng/test-framework.html#the-rtems-test-framework
Oh, Ok I will make the changes.
> Perhaps, restart with something simpler and send that first. Then you
> should take a look at the existing test we have for the
> clock_nanosleep() that only does CLOCK_REALTIME for some of the logic
> to test as well. It seems like you have done a pretty basic API-level
> test, but it is only checking some return values and not actually
> verifying the implementation did anything.
Dr. Joel suggested in the previous review
<https://lists.rtems.org/pipermail/devel/2020-April/059380.html> that this
test could be the same as clock real-time with the clock type changed but
looking
back I realize that there is much more to that test than what I have
implemented. I will change this.
> On Mon, Sep 21, 2020 at 9:15 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
> wrote:
> > From: Utkarsh <utkarsh.rai60 at gmail.com>
> Please use full (legal) name for commit metadata
> > Closes #3890
> > Signed-off-by: Utkarsh Rai <utkarsh.rai60 at gmail.com>
> > spec/build/testsuites/psxtests/grp.yml | 2 +
> > .../psxtests/psxclocknanosleep01.yml | 20 +++
> > .../psxtests/psxclocknanosleep01/init.c | 94 ++++++++++++++
> > .../psxclocknanosleep01.doc | 13 ++
> > .../psxclocknanosleep01.scn | 41 ++++++
> > .../test-clock-nanosleep.c | 120 ++++++++++++++++++
> > 6 files changed, 290 insertions(+)
> > create mode 100644
> spec/build/testsuites/psxtests/psxclocknanosleep01.yml
> > create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
> > create mode 100644
> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> > create mode 100644
> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> > create mode 100644
> testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> > diff --git a/spec/build/testsuites/psxtests/grp.yml
> b/spec/build/testsuites/psxtests/grp.yml
> > index 47dedac275..3342fc6c18 100644
> > --- a/spec/build/testsuites/psxtests/grp.yml
> > +++ b/spec/build/testsuites/psxtests/grp.yml
> > @@ -79,6 +79,8 @@ links:
> > uid: psxclock
> > - role: build-dependency
> > uid: psxclock01
> > +- role: build-dependency
> > + uid: psxclocknanosleep01
> > uid: psxclockrealtime01
> > diff --git a/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
> b/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
> > new file mode 100644
> > index 0000000000..39ec1657d2
> > --- /dev/null
> > +++ b/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
> > @@ -0,0 +1,20 @@
> > +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > +build-type: test-program
> > +cflags: []
> > +copyrights:
> > +- Copyright (C) 2020 Utkarsh Rai (utkarsh.rai60 at mail.com)
> > +cppflags: []
> > +cxxflags: []
> > +enabled-by: true
> > +features: c cprogram
> > +includes: []
> > +ldflags: []
> > +links: []
> > +source:
> > +- testsuites/psxtests/psxclocknanosleep01/init.c
> > +- testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> > +stlib: []
> > +target: testsuites/psxtests/psxclocknanosleep01.exe
> > +type: build
> > +use-after: []
> > +use-before: []
> > diff --git a/testsuites/psxtests/psxclocknanosleep01/init.c
> b/testsuites/psxtests/psxclocknanosleep01/init.c
> > index 0000000000..a5cb4d6054
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxclocknanosleep01/init.c
> > @@ -0,0 +1,94 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause
> > + * Copyright (C) 2020 Utkarsh Rai
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + * notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + * notice, this list of conditions and the following disclaimer in
> the
> > + * documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <rtems.h>
> > +#include <rtems/bspIo.h>
> > +#include <rtems/linkersets.h>
> > +#include <rtems/test.h>
> > +#include <rtems/test-info.h>
> > +#include <tmacros.h>
> > +const char rtems_test_name[] = "PSXCLOCKNANOSLEEP01";
> > +static char buffer[512];
> > +static const T_action actions[] = {
> > + T_report_hash_sha256,
> > + T_check_task_context,
> > + T_check_file_descriptors,
> > + T_check_rtems_barriers,
> > + T_check_rtems_extensions,
> > + T_check_rtems_message_queues,
> > + T_check_rtems_partitions,
> > + T_check_rtems_periods,
> > + T_check_rtems_regions,
> > + T_check_rtems_semaphores,
> > + T_check_rtems_tasks,
> > + T_check_rtems_timers,
> > + T_check_posix_keys
> > +static const T_config config = {
> > + .name = "POSIXCLOCKNANOSLEEPTEST01",
> > + .buf = buffer,
> > + .buf_size = sizeof( buffer ),
> > + .putchar = rtems_put_char,
> > + .verbosity = T_VERBOSE,
> > + .now = T_now_clock,
> > + .action_count = T_ARRAY_SIZE( actions ),
> > + .actions = actions
> > +static void
> > +Init( rtems_task_argument arg )
> > + int exit_code;
> > + (void) arg;
> > + TEST_BEGIN();
> > + T_register();
> > + exit_code = T_main( &config );
> > + if (exit_code == 0) {
> > + TEST_END();
> > + rtems_test_exit( exit_code );
> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > +#define CONFIGURE_MAXIMUM_TASKS 1
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#define CONFIGURE_INIT
> > +#include <rtems/confdefs.h>
> > \ No newline at end of file
> > diff --git
> a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> > index 0000000000..803c2cff15
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> > @@ -0,0 +1,13 @@
> > +This file describes the directives and concepts tested by this test set.
> > +test set name: psxclocknanosleep01
> > +directives:
> > +- clock_nanosleep()
> > +concepts:
> > +- Test some invalid and extreme timeout values.
> > +- Ensure that the CLOCK_MONOTONIC based delay is not affected by
> changes to
> > + CLOCK_REALTIME
> > diff --git
> a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> > index 0000000000..aa0050e3cd
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> > @@ -0,0 +1,41 @@
> > +*** BEGIN OF TEST PSXCLOCKNANOSLEEP01 ***
> > +*** TEST VERSION: 6.0.0.314dae32156aa3d1f54f1ee104b26604a32cae4f
> > +*** TEST STATE: EXPECTED_PASS
> > +*** TEST BUILD:
> > +*** TEST TOOLS: 10.2.1 20200904 (RTEMS 6, RSB
> 47f32b8b1a597b5ed3475722bdc155249ef51115, Newlib a0d7982)
> > +A:POSIXCLOCKNANOSLEEPTEST01
> > +S:Platform:RTEMS
> > +S:Compiler:10.2.1 20200904 (RTEMS 6, RSB
> > +S:Version:6.0.0.314dae32156aa3d1f54f1ee104b26604a32cae4f
> > +S:BSP:realview_pbx_a9_qemu
> > +S:RTEMS_DEBUG:0
> > +S:RTEMS_MULTIPROCESSING:0
> > +S:RTEMS_POSIX_API:0
> > +S:RTEMS_PROFILING:0
> > +S:RTEMS_SMP:0
> > +B:POSIXClock_Timeout_negative_sec_nsec
> > +P:0:0:UI1:test-clock-nanosleep.c:97
> > +E:POSIXClock_Timeout_negative_sec_nsec:N:1:F:0:D:0.003693
> > +P:0:0:UI1:test-clock-nanosleep.c:72
> > +E:POSIXClock_Timeout_negative_sec:N:1:F:0:D:0.000347
> > +B:POSIXClock_Timeout_negative_nsec
> > +P:0:0:UI1:test-clock-nanosleep.c:85
> > +E:POSIXClock_Timeout_negative_nsec:N:1:F:0:D:0.000227
> > +B:POSIXClock_Timeout_huge_nsec
> > +P:0:0:UI1:test-clock-nanosleep.c:60
> > +E:POSIXClock_Timeout_huge_nsec:N:1:F:0:D:0.000224
> > +B:POSIXClock_Timeout_finite
> > +P:0:0:UI1:test-clock-nanosleep.c:43
> > +P:1:0:UI1:test-clock-nanosleep.c:48
> > +E:POSIXClock_Timeout_finite:N:2:F:0:D:0.002504
> > +B:POSIXClock_Timeout_clock_modify
> > +P:0:0:UI1:test-clock-nanosleep.c:107
> > +P:1:0:UI1:test-clock-nanosleep.c:111
> > +P:2:0:UI1:test-clock-nanosleep.c:114
> > +P:3:0:UI1:test-clock-nanosleep.c:119
> > +E:POSIXClock_Timeout_clock_modify:N:4:F:0:D:1.009321
> > +Z:POSIXCLOCKNANOSLEEPTEST01:C:6:N:10:F:0:D:1.018286
> +Y:ReportHash:SHA256:cc043d8e8d1a25d2d3a5fb341169ebd8b64e8ba10bc85f34c9905e89c1e01b4f
> > +*** END OF TEST PSXCLOCKNANOSLEEP01 ***
> > diff --git
> a/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> b/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> > index 0000000000..d61829c5fe
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
> > @@ -0,0 +1,120 @@
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#endif
> > +#include <errno.h>
> > +#include <limits.h>
> > +#include <time.h>
> > +T_TEST_CASE( POSIXClock_Timeout_finite )
> > + struct timespec delay_time;
> > + int eno;
> > + eno = clock_gettime( CLOCK_MONOTONIC, &delay_time );
> > + T_eno_success( eno );
> > + delay_time.tv_sec = 1;
> > + eno = clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &delay_time,
> NULL );
> > +T_TEST_CASE( POSIXClock_Timeout_huge_nsec )
> > + int eno;
> > + delay_time.tv_nsec = LONG_MAX;
> NULL );
> > + T_eno( EINVAL, eno );
> > +T_TEST_CASE( POSIXClock_Timeout_negative_sec )
> > + int eno;
> > + delay_time.tv_sec = -1;
> > + delay_time.tv_nsec = 1;
> NULL );
> > +T_TEST_CASE( POSIXClock_Timeout_negative_nsec )
> > + int eno;
> > + delay_time.tv_nsec = -1;
> NULL );
> > +T_TEST_CASE(POSIXClock_Timeout_negative_sec_nsec)
> > + int eno;
> NULL );
> > + T_eno( EINVAL, eno);
> > +T_TEST_CASE( POSIXClock_Timeout_clock_modify )
> > + struct timespec configure_time;
> > + int eno;
> > + eno = clock_gettime( CLOCK_REALTIME, &configure_time );
> > + configure_time.tv_sec += 3600;
> > + eno = clock_settime( CLOCK_REALTIME, &configure_time );
> > + delay_time.tv_sec += 1;
> NULL );
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200928/ba7af609/attachment-0001.html>
