[PATCH rtems-net-legacy v2] Remove RTEMS_NETWORKING checks
Vijay Kumar Banerjee vijay at rtems.org
Sat Apr 3 01:19:07 UTC 2021
* Remove nfsclient wscript and build from netlegacy.py
 bsps/powerpc/mpc55xxevb/net/smsc9218i.c |  4 +--
 libmisc/dummy-networking.c              | 44 ++++++++++++-------------
 netlegacy.py                            | 18 +++++++++-
 nfsclient/wscript                       |  1 +
 telnetd/telnetd.c                       |  4 ---
 wscript                                 |  2 +-
 6 files changed, 42 insertions(+), 31 deletions(-)
diff --git a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
index d88aa8a..384f9cd 100644
--- a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
+++ b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
@@ -24,7 +24,7 @@
 #include <mpc55xx/regs.h>
-#if defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU)
+#if defined(MPC55XX_HAS_SIU)
 #include <machine/rtems-bsd-kernel-space.h>
@@ -2121,4 +2121,4 @@ int smsc9218i_attach_detach(
   return 0;
-#endif /* defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU) */
+#endif /* defined(MPC55XX_HAS_SIU) */
diff --git a/libmisc/dummy-networking.c b/libmisc/dummy-networking.c
index 379e23e..b7f15c8 100644
--- a/libmisc/dummy-networking.c
+++ b/libmisc/dummy-networking.c
@@ -16,27 +16,25 @@
 /* Loopback Network Configuration */
-  #include <rtems/rtems_bsdnet.h>
-  #include <sys/socket.h>
-  #include <netinet/in.h>
+#include <rtems/rtems_bsdnet.h>
+#include <sys/socket.h>
+#include <netinet/in.h>
-  struct rtems_bsdnet_config rtems_bsdnet_config = {
-      NULL,                   /* Network interface */
-      NULL,                   /* Use fixed network configuration */
-      0,                      /* Default network task priority */
-      0,                      /* Default mbuf capacity */
-      0,                      /* Default mbuf cluster capacity */
-      "testSystem",           /* Host name */
-      "nowhere.com",          /* Domain name */
-      "127.0.0.1",            /* Gateway */
-      "127.0.0.1",            /* Log host */
-      {"127.0.0.1" },         /* Name server(s) */
-      {"127.0.0.1" },         /* NTP server(s) */
-      1,                      /* sb_efficiency */
-      0,                      /* udp_tx_buf_size */
-      0,                      /* udp_rx_buf_size */
-      0,                      /* tcp_tx_buf_size */
-      0                       /* tcp_rx_buf_size */
-#endif
+struct rtems_bsdnet_config rtems_bsdnet_config = {
+    NULL,                   /* Network interface */
+    NULL,                   /* Use fixed network configuration */
+    0,                      /* Default network task priority */
+    0,                      /* Default mbuf capacity */
+    0,                      /* Default mbuf cluster capacity */
+    "testSystem",           /* Host name */
+    "nowhere.com",          /* Domain name */
+    "127.0.0.1",            /* Gateway */
+    "127.0.0.1",            /* Log host */
+    {"127.0.0.1" },         /* Name server(s) */
+    {"127.0.0.1" },         /* NTP server(s) */
+    1,                      /* sb_efficiency */
+    0,                      /* udp_tx_buf_size */
+    0,                      /* udp_rx_buf_size */
+    0,                      /* tcp_tx_buf_size */
+    0                       /* tcp_rx_buf_size */
diff --git a/netlegacy.py b/netlegacy.py
index 0889548..85c523e 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -54,6 +54,13 @@ def build(bld):
                    for s in os.listdir('./pppd') if s[-2:] == '.c']
     telnetd_source = [os.path.join('./telnetd', s)
                       for s in os.listdir('telnetd') if s[-2:] == '.c']
+    nfs_source = []
+    for root, dirs, files in os.walk('./nfsclient'):
+        for name in files:
+            ext = os.path.splitext(name)[1]
+            if ext == '.c':
+                src_root = os.path.split(root)[1]
+                nfs_source.append(os.path.join('./nfsclient', src_root, name))
     bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
@@ -66,6 +73,7 @@ def build(bld):
                          './bsps/include'])
     arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
                                             bld.env.RTEMS_ARCH_BSP)
+    lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
     include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
                                                      arch_lib_path)))
@@ -73,6 +81,8 @@ def build(bld):
                                                      'include')))
     include_path.append('./bsps/include/libchip')
+    bld.read_stlib('rtemsbsp', paths=[lib_path])
     if bsp in bsp_dirs:
         include_path.extend(bsp_dirs[bsp])
@@ -107,8 +117,14 @@ def build(bld):
               use='networking',
               source=telnetd_source)
+    bld.stlib(target='nfs',
+              features='c',
+              includes=ip,
+              use=['rtemsbsp', 'networking'],
+              source=nfs_source)
     bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
-                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
+                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
     bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
                                    'include', 'libchip'),
                       [os.path.join('./bsps/include/libchip/', f)
diff --git a/nfsclient/wscript b/nfsclient/wscript
index bc2f994..c0fe420 100644
--- a/nfsclient/wscript
+++ b/nfsclient/wscript
@@ -52,5 +52,6 @@ def build(bld):
               features='c',
               cflags=['-O2', '-g'],
               includes=include_path,
+              use=['networking'],
               source=source_files)
     bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
diff --git a/telnetd/telnetd.c b/telnetd/telnetd.c
index b8adec2..3d401ff 100644
--- a/telnetd/telnetd.c
+++ b/telnetd/telnetd.c
@@ -58,9 +58,7 @@
 #include <rtems/thread.h>
 #include <rtems/userenv.h>
-#ifdef RTEMS_NETWORKING
-#endif
 #define TELNETD_EVENT_SUCCESS RTEMS_EVENT_0
@@ -401,11 +399,9 @@ rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config)
   LIST_INIT(&ctx->free_sessions);
   /* Check priority */
   if (ctx->config.priority == 0) {
     ctx->config.priority = rtems_bsdnet_config.network_task_priority;
-#endif
     ctx->config.priority = 100;
diff --git a/wscript b/wscript
index 07f774d..7af317d 100644
--- a/wscript
+++ b/wscript
@@ -33,7 +33,7 @@ import sys
 top = '.'
 rtems_version = "6"
-subdirs = ['nfsclient', 'testsuites']
+subdirs = ['testsuites']
 try:
     import rtems_waf.rtems as rtems
2.26.2
