#3860 - GSoC enquiries
Ida Delphine idadelm at gmail.com
Tue Apr 13 04:15:42 UTC 2021
Hello everyone,
Before submitting my final GSoC proposal will love it if my draft can be
reviewed one more time so that in case I still got errors I could fix them.
Just want to be sure everything is okay.
https://docs.google.com/document/d/1VADJh3_kIhs578IEmBJ98rjR6p5E1XcksUkq1Ms4jRA/edit?usp=sharing
Thanks,
Ida.
On Mon, Apr 12, 2021 at 6:40 AM Ida Delphine <idadelm at gmail.com> wrote:
> Hello all,
> I made some changes to my initial proposal draft based on some feedback I
> got. Here's is the modified version. Please help me review and suggest
> improvements.
> Cheers,
> Ida.
> On Fri, Apr 9, 2021 at 1:51 AM Ida Delphine <idadelm at gmail.com> wrote:
>> Hello All,
>> Just a gentle reminder to please help me review this my proposal draft
>> and help me with ways to make it better :)
>> Cheers,
>> Ida
>> On Thu, 8 Apr 2021, 6:51 am Ida Delphine, <idadelm at gmail.com> wrote:
>>> Hello everyone,
>>> Here is the link to my GSoC proposal. Will love if you leave comments on
>>> ways I could make it better or any corrections (Especially the *Proposesd
>>> Schedule* section so that I will be sure about my project deliverables
>>> when inputting them).
>>> I will also love to know about any future improvements to this project.
>>> Cheers,
>>> Ida.
>>> On Wed, Apr 7, 2021 at 5:27 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>> On Wed, Apr 7, 2021 at 10:11 AM Ida Delphine <idadelm at gmail.com> wrote:
>>>> > Hello,
>>>> > In case I succeed with this project will I be required to do some
>>>> documentation on how it works?
>>>> Yes, in general we expect students to produce documentation while they
>>>> work on also creating code.
>>>> I think the direction we're heading right now is toward using
>>>> clang-format, perhaps with an update to a common coding style. In this
>>>> case, we solve our problem by policy rather than technical solution,
>>>> and your work should focus on tool integration and automation without
>>>> concern about the coding style itself.
>>>> > On Wed, Apr 7, 2021 at 9:51 AM Sebastian Huber <
>>>> sebastian.huber at embedded-brains.de> wrote:
>>>> >> On 07/04/2021 09:03, Chris Johns wrote:
>>>> >> > Would it be pragmatic to review these cases and change the
>>>> standard?
>>>> >> I sent a patch to review the format changes done by clang-format
>>>> recently:
>>>> >> https://lists.rtems.org/pipermail/devel/2021-April/066311.html
>>>> >> It doesn't look that bad from my point of view. Fixing the alignment
>>>> >> issue would make it even better:
>>>> >> https://reviews.llvm.org/D27651
>>>> >> > I understand the long history but as you point out we either
>>>> invest in the tools
>>>> >> > to support the format, we change what we have or we manage it
>>>> manually.
>>>> >> I would prefer to change the style and use a widely used formatting
>>>> >> tool. I think we spend to much time on the coding style in reviews.
>>>> This
>>>> >> is quite bad since we are all busy with all sorts of things and our
>>>> time
>>>> >> is better spent on more important tasks. A consistently formatted
>>>> source
>>>> >> code is very important, but enforcing this style manually is a waste
>>>> of
>>>> >> time.
>>>> >> embedded brains GmbH
>>>> >> Herr Sebastian HUBER
>>>> >> Dornierstr. 4
>>>> >> 82178 Puchheim
>>>> >> Germany
>>>> >> email: sebastian.huber at embedded-brains.de
>>>> >> phone: +49-89-18 94 741 - 16
>>>> >> fax:   +49-89-18 94 741 - 08
>>>> >> Registergericht: Amtsgericht München
>>>> >> Registernummer: HRB 157899
>>>> >> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
>>>> Dörfler
>>>> >> Unsere Datenschutzerklärung finden Sie hier:
>>>> >> https://embedded-brains.de/datenschutzerklaerung/
>>>> >> _______________________________________________
>>>> >> devel mailing list
>>>> >> devel at rtems.org
>>>> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210413/5cc2e83c/attachment-0001.html>
