[PATCH rtems-net-legacy] netlegacy: Use os.path to get the file extension
Vijay Kumar Banerjee
vijay at rtems.org
Sat Apr 3 01:32:21 UTC 2021
bsp_drivers.py | 5 +++--
netlegacy.py | 5 +++--
2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/bsp_drivers.py b/bsp_drivers.py
index cb6caa5..3ca10c6 100644
--- a/bsp_drivers.py
+++ b/bsp_drivers.py
@@ -62,9 +62,10 @@ def bsp_files(bld):
source_dir = os.walk(special_case_dirs[bsp])
for root, dirs, files in source_dir:
for name in files:
- if name[-2:] == '.c':
+ ext = os.path.splitext(name)[1]
+ if ext == '.c':
source_files[bsp].append(os.path.join(root, name))
- if name[-2:] == '.h':
+ if ext == '.h':
if root not in include_dirs[bsp]:
include_dirs[bsp].append(root)
if bsp in special_case_sources:
diff --git a/netlegacy.py b/netlegacy.py
index 85c523e..f470da2 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -40,9 +40,10 @@ for root, dirs, files in os.walk("."):
dirs.append('./bsps/shared/net')
include_files[root[2:]] = []
for name in files:
+ if ext == '.c':
source_files.append(os.path.join(root, name))
- if name[-2:] == '.h' and name not in exclude_headers:
+ if ext == '.h' and name not in exclude_headers:
include_files[root[2:]].append(os.path.join(root, name))
2.26.2
