[PATCH rtems-net-legacy] netlegacy: Use os.path to get the file extension
Gedare Bloom
gedare at rtems.org
Sat Apr 3 14:36:05 UTC 2021
looks good
On Fri, Apr 2, 2021 at 7:32 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> bsp_drivers.py | 5 +++--
> netlegacy.py | 5 +++--
> 2 files changed, 6 insertions(+), 4 deletions(-)
> diff --git a/bsp_drivers.py b/bsp_drivers.py
> index cb6caa5..3ca10c6 100644
> --- a/bsp_drivers.py
> +++ b/bsp_drivers.py
> @@ -62,9 +62,10 @@ def bsp_files(bld):
> source_dir = os.walk(special_case_dirs[bsp])
> for root, dirs, files in source_dir:
> for name in files:
> - if name[-2:] == '.c':
> + ext = os.path.splitext(name)[1]
> + if ext == '.c':
> source_files[bsp].append(os.path.join(root, name))
> - if name[-2:] == '.h':
> + if ext == '.h':
> if root not in include_dirs[bsp]:
> include_dirs[bsp].append(root)
> if bsp in special_case_sources:
> diff --git a/netlegacy.py b/netlegacy.py
> index 85c523e..f470da2 100644
> --- a/netlegacy.py
> +++ b/netlegacy.py
> @@ -40,9 +40,10 @@ for root, dirs, files in os.walk("."):
> dirs.append('./bsps/shared/net')
> include_files[root[2:]] = []
> for name in files:
> + if ext == '.c':
> source_files.append(os.path.join(root, name))
> - if name[-2:] == '.h' and name not in exclude_headers:
> + if ext == '.h' and name not in exclude_headers:
> include_files[root[2:]].append(os.path.join(root, name))
> 2.26.2
> devel mailing list
> devel at rtems.org
