[PATCH rtems-net-legacy 1/2] Remove RTEMS_NETWORKING checks
Vijay Kumar Banerjee
vijay at rtems.org
Sat Apr 3 01:33:34 UTC 2021
On Tue, Mar 30, 2021 at 10:48 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Mar 30, 2021 at 10:40 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > Hi,
> > On Tue, Mar 30, 2021 at 7:53 AM Gedare Bloom <gedare at rtems.org> wrote:
> > > On Mon, Mar 29, 2021 at 7:42 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > > > ping :)
> > > > On Tue, Mar 23, 2021 at 2:10 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > > > > * Remove nfsclient wscript and build from netlegacy.py
> > > > > bsps/powerpc/mpc55xxevb/net/smsc9218i.c | 4 +--
> > > > > libmisc/dummy-networking.c | 44 ++++++++++++-------------
> > > > > netlegacy.py | 17 +++++++++-
> > > > > nfsclient/wscript | 1 +
> > > > > telnetd/telnetd.c | 4 ---
> > > > > wscript | 2 +-
> > > > > 6 files changed, 41 insertions(+), 31 deletions(-)
> > > > > diff --git a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> > > > > index d88aa8a..384f9cd 100644
> > > > > --- a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> > > > > +++ b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> > > > > @@ -24,7 +24,7 @@
> > > > > #include <mpc55xx/regs.h>
> > > > > -#if defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU)
> > > > > +#if defined(MPC55XX_HAS_SIU)
> > > > > #include <machine/rtems-bsd-kernel-space.h>
> > > > > @@ -2121,4 +2121,4 @@ int smsc9218i_attach_detach(
> > > > > return 0;
> > > > > -#endif /* defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU) */
> > > > > +#endif /* defined(MPC55XX_HAS_SIU) */
> > > > > diff --git a/libmisc/dummy-networking.c b/libmisc/dummy-networking.c
> > > > > index 379e23e..b7f15c8 100644
> > > > > --- a/libmisc/dummy-networking.c
> > > > > +++ b/libmisc/dummy-networking.c
> > > > > @@ -16,27 +16,25 @@
> > > > > #include <rtems.h>
> > > > > /* Loopback Network Configuration */
> > > > > - #include <rtems/rtems_bsdnet.h>
> > > > > - #include <sys/socket.h>
> > > > > - #include <netinet/in.h>
> > > > > +#include <rtems/rtems_bsdnet.h>
> > > > > +#include <sys/socket.h>
> > > > > +#include <netinet/in.h>
> > > > > - struct rtems_bsdnet_config rtems_bsdnet_config = {
> > > > > - NULL, /* Network interface */
> > > > > - NULL, /* Use fixed network configuration */
> > > > > - 0, /* Default network task priority */
> > > > > - 0, /* Default mbuf capacity */
> > > > > - 0, /* Default mbuf cluster capacity */
> > > > > - "testSystem", /* Host name */
> > > > > - "nowhere.com", /* Domain name */
> > > > > - "127.0.0.1", /* Gateway */
> > > > > - "127.0.0.1", /* Log host */
> > > > > - {"127.0.0.1" }, /* Name server(s) */
> > > > > - {"127.0.0.1" }, /* NTP server(s) */
> > > > > - 1, /* sb_efficiency */
> > > > > - 0, /* udp_tx_buf_size */
> > > > > - 0, /* udp_rx_buf_size */
> > > > > - 0, /* tcp_tx_buf_size */
> > > > > - 0 /* tcp_rx_buf_size */
> > > > > -#endif
> > > > > +struct rtems_bsdnet_config rtems_bsdnet_config = {
> > > > > + NULL, /* Network interface */
> > > > > + NULL, /* Use fixed network configuration */
> > > > > + 0, /* Default network task priority */
> > > > > + 0, /* Default mbuf capacity */
> > > > > + 0, /* Default mbuf cluster capacity */
> > > > > + "testSystem", /* Host name */
> > > > > + "nowhere.com", /* Domain name */
> > > > > + "127.0.0.1", /* Gateway */
> > > > > + "127.0.0.1", /* Log host */
> > > > > + {"127.0.0.1" }, /* Name server(s) */
> > > > > + {"127.0.0.1" }, /* NTP server(s) */
> > > > > + 1, /* sb_efficiency */
> > > > > + 0, /* udp_tx_buf_size */
> > > > > + 0, /* udp_rx_buf_size */
> > > > > + 0, /* tcp_tx_buf_size */
> > > > > + 0 /* tcp_rx_buf_size */
> > > > > diff --git a/netlegacy.py b/netlegacy.py
> > > > > index 0889548..0e69076 100644
> > > > > --- a/netlegacy.py
> > > > > +++ b/netlegacy.py
> > > > > @@ -54,6 +54,12 @@ def build(bld):
> > > > > for s in os.listdir('./pppd') if s[-2:] == '.c']
> > > > > telnetd_source = [os.path.join('./telnetd', s)
> > > > > for s in os.listdir('telnetd') if s[-2:] == '.c']
> > > > > + nfs_source = []
> > > > > + for root, dirs, files in os.walk('./nfsclient'):
> > > > > + for name in files:
> > > > > + if name[-2:] == '.c':
> > > can you use os.path.splitext() here? You may like to propagate the
> > > change elsewhere.
> > yes, that would be nice. There are some more places in this file where
> > this has been used. Should that be a follow-up patch to update this in
> > all the places?
> Yes, that would be acceptable.
Sent a v2 and a follow-up patch to fix other places. Please have a look.
Thanks,
Vijay
> > Best regards,
> > Vijay
> > > > > + src_root = root.split('/')[2]
> > > If this is just one level, you can use os.path.split() instead?
> > > > > + nfs_source.append(os.path.join('./nfsclient', src_root, name))
> > > > > bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> > > > > @@ -66,6 +72,7 @@ def build(bld):
> > > > > './bsps/include'])
> > > > > arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> > > > > bld.env.RTEMS_ARCH_BSP)
> > > > > + lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> > > > > include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
> > > > > arch_lib_path)))
> > > > > @@ -73,6 +80,8 @@ def build(bld):
> > > > > 'include')))
> > > > > include_path.append('./bsps/include/libchip')
> > > > > + bld.read_stlib('rtemsbsp', paths=[lib_path])
> > > > > if bsp in bsp_dirs:
> > > > > include_path.extend(bsp_dirs[bsp])
> > > > > @@ -107,8 +116,14 @@ def build(bld):
> > > > > use='networking',
> > > > > source=telnetd_source)
> > > > > + bld.stlib(target='nfs',
> > > > > + features='c',
> > > > > + includes=ip,
> > > > > + use=['rtemsbsp', 'networking'],
> > > > > + source=nfs_source)
> > > > > bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> > > > > - ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> > > > > + ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> > > > > bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> > > > > 'include', 'libchip'),
> > > > > [os.path.join('./bsps/include/libchip/', f)
> > > > > diff --git a/nfsclient/wscript b/nfsclient/wscript
> > > > > index bc2f994..c0fe420 100644
> > > > > --- a/nfsclient/wscript
> > > > > +++ b/nfsclient/wscript
> > > > > @@ -52,5 +52,6 @@ def build(bld):
> > > > > features='c',
> > > > > cflags=['-O2', '-g'],
> > > > > includes=include_path,
> > > > > + use=['networking'],
> > > > > source=source_files)
> > > > > bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
> > > > > diff --git a/telnetd/telnetd.c b/telnetd/telnetd.c
> > > > > index b8adec2..3d401ff 100644
> > > > > --- a/telnetd/telnetd.c
> > > > > +++ b/telnetd/telnetd.c
> > > > > @@ -58,9 +58,7 @@
> > > > > #include <rtems/thread.h>
> > > > > #include <rtems/userenv.h>
> > > > > -#ifdef RTEMS_NETWORKING
> > > > > -#endif
> > > > > #define TELNETD_EVENT_SUCCESS RTEMS_EVENT_0
> > > > > @@ -401,11 +399,9 @@ rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config)
> > > > > LIST_INIT(&ctx->free_sessions);
> > > > > /* Check priority */
> > > > > if (ctx->config.priority == 0) {
> > > > > ctx->config.priority = rtems_bsdnet_config.network_task_priority;
> > > > > -#endif
> > > > > ctx->config.priority = 100;
> > > > > diff --git a/wscript b/wscript
> > > > > index 07f774d..7af317d 100644
> > > > > --- a/wscript
> > > > > +++ b/wscript
> > > > > @@ -33,7 +33,7 @@ import sys
> > > > > top = '.'
> > > > > rtems_version = "6"
> > > > > -subdirs = ['nfsclient', 'testsuites']
> > > > > +subdirs = ['testsuites']
> > > > > try:
> > > > > import rtems_waf.rtems as rtems
> > > > > 2.26.2
> > > > _______________________________________________
> > > > devel mailing list
> > > > devel at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/devel
