[PATCH rtems-net-legacy] netlegacy: Use os.path to get the file extension
Vijay Kumar Banerjee
vijay at rtems.org
Wed Apr 14 06:01:52 UTC 2021
On Sat, Apr 3, 2021 at 8:36 AM Gedare Bloom <gedare at rtems.org> wrote:
> looks good
Pushed. Thanks.
> On Fri, Apr 2, 2021 at 7:32 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > bsp_drivers.py | 5 +++--
> > netlegacy.py | 5 +++--
> > 2 files changed, 6 insertions(+), 4 deletions(-)
> > diff --git a/bsp_drivers.py b/bsp_drivers.py
> > index cb6caa5..3ca10c6 100644
> > --- a/bsp_drivers.py
> > +++ b/bsp_drivers.py
> > @@ -62,9 +62,10 @@ def bsp_files(bld):
> > source_dir = os.walk(special_case_dirs[bsp])
> > for root, dirs, files in source_dir:
> > for name in files:
> > - if name[-2:] == '.c':
> > + ext = os.path.splitext(name)[1]
> > + if ext == '.c':
> > source_files[bsp].append(os.path.join(root, name))
> > - if name[-2:] == '.h':
> > + if ext == '.h':
> > if root not in include_dirs[bsp]:
> > include_dirs[bsp].append(root)
> > if bsp in special_case_sources:
> > diff --git a/netlegacy.py b/netlegacy.py
> > index 85c523e..f470da2 100644
> > --- a/netlegacy.py
> > +++ b/netlegacy.py
> > @@ -40,9 +40,10 @@ for root, dirs, files in os.walk("."):
> > dirs.append('./bsps/shared/net')
> > include_files[root[2:]] = []
> > for name in files:
> > + if ext == '.c':
> > source_files.append(os.path.join(root, name))
> > - if name[-2:] == '.h' and name not in exclude_headers:
> > + if ext == '.h' and name not in exclude_headers:
> > include_files[root[2:]].append(os.path.join(root, name))
> > 2.26.2
> > devel mailing list
> > devel at rtems.org
