[PATCH rtems-net-legacy] nfsclient: Build nfsclient from the top level netlegacy script
Vijay Kumar Banerjee
vijay at rtems.org
Sun Apr 4 01:05:53 UTC 2021
netlegacy.py | 18 +++++++++++++++++-
nfsclient/wscript | 1 +
wscript | 2 +-
3 files changed, 19 insertions(+), 2 deletions(-)
diff --git a/netlegacy.py b/netlegacy.py
index 89176e6..f470da2 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -55,6 +55,13 @@ def build(bld):
for s in os.listdir('./pppd') if s[-2:] == '.c']
telnetd_source = [os.path.join('./telnetd', s)
for s in os.listdir('telnetd') if s[-2:] == '.c']
+ nfs_source = []
+ for root, dirs, files in os.walk('./nfsclient'):
+ for name in files:
+ ext = os.path.splitext(name)[1]
+ if ext == '.c':
+ src_root = os.path.split(root)[1]
+ nfs_source.append(os.path.join('./nfsclient', src_root, name))
bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
@@ -67,6 +74,7 @@ def build(bld):
'./bsps/include'])
arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
bld.env.RTEMS_ARCH_BSP)
+ lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
arch_lib_path)))
@@ -74,6 +82,8 @@ def build(bld):
'include')))
include_path.append('./bsps/include/libchip')
+ bld.read_stlib('rtemsbsp', paths=[lib_path])
if bsp in bsp_dirs:
include_path.extend(bsp_dirs[bsp])
@@ -108,8 +118,14 @@ def build(bld):
use='networking',
source=telnetd_source)
+ bld.stlib(target='nfs',
+ features='c',
+ includes=ip,
+ use=['rtemsbsp', 'networking'],
+ source=nfs_source)
bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
- ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
+ ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
'include', 'libchip'),
[os.path.join('./bsps/include/libchip/', f)
diff --git a/nfsclient/wscript b/nfsclient/wscript
index bc2f994..c0fe420 100644
--- a/nfsclient/wscript
+++ b/nfsclient/wscript
@@ -52,5 +52,6 @@ def build(bld):
features='c',
cflags=['-O2', '-g'],
includes=include_path,
+ use=['networking'],
source=source_files)
bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
diff --git a/wscript b/wscript
index 07f774d..7af317d 100644
--- a/wscript
+++ b/wscript
@@ -33,7 +33,7 @@ import sys
top = '.'
rtems_version = "6"
-subdirs = ['nfsclient', 'testsuites']
+subdirs = ['testsuites']
try:
import rtems_waf.rtems as rtems
2.26.2
