[PATCH rtems-net-legacy] nfsclient: Build nfsclient from the top level netlegacy script
Mon Apr 5 16:34:06 UTC 2021
ok, push on Wednesday if no one complains
On Sat, Apr 3, 2021 at 7:06 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>  netlegacy.py      | 18 +++++++++++++++++-
>  nfsclient/wscript |  1 +
>  wscript           |  2 +-
>  3 files changed, 19 insertions(+), 2 deletions(-)
> diff --git a/netlegacy.py b/netlegacy.py
> index 89176e6..f470da2 100644
> --- a/netlegacy.py
> +++ b/netlegacy.py
> @@ -55,6 +55,13 @@ def build(bld):
>                     for s in os.listdir('./pppd') if s[-2:] == '.c']
>      telnetd_source = [os.path.join('./telnetd', s)
>                        for s in os.listdir('telnetd') if s[-2:] == '.c']
> +    nfs_source = []
> +    for root, dirs, files in os.walk('./nfsclient'):
> +        for name in files:
> +            ext = os.path.splitext(name)[1]
> +            if ext == '.c':
> +                src_root = os.path.split(root)[1]
> +                nfs_source.append(os.path.join('./nfsclient', src_root, name))
>      bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> @@ -67,6 +74,7 @@ def build(bld):
>                           './bsps/include'])
>      arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
>                                              bld.env.RTEMS_ARCH_BSP)
> +    lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
>      include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
>                                                       arch_lib_path)))
> @@ -74,6 +82,8 @@ def build(bld):
>                                                       'include')))
>      include_path.append('./bsps/include/libchip')
> +    bld.read_stlib('rtemsbsp', paths=[lib_path])
>      if bsp in bsp_dirs:
>          include_path.extend(bsp_dirs[bsp])
> @@ -108,8 +118,14 @@ def build(bld):
>                use='networking',
>                source=telnetd_source)
> +    bld.stlib(target='nfs',
> +              features='c',
> +              includes=ip,
> +              use=['rtemsbsp', 'networking'],
> +              source=nfs_source)
>      bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> -                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> +                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
>      bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
>                                     'include', 'libchip'),
>                        [os.path.join('./bsps/include/libchip/', f)
> diff --git a/nfsclient/wscript b/nfsclient/wscript
> index bc2f994..c0fe420 100644
> --- a/nfsclient/wscript
> +++ b/nfsclient/wscript
> @@ -52,5 +52,6 @@ def build(bld):
>                features='c',
>                cflags=['-O2', '-g'],
>                includes=include_path,
> +              use=['networking'],
>                source=source_files)
>      bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
> diff --git a/wscript b/wscript
> index 07f774d..7af317d 100644
> --- a/wscript
> +++ b/wscript
> @@ -33,7 +33,7 @@ import sys
>  top = '.'
>  rtems_version = "6"
> -subdirs = ['nfsclient', 'testsuites']
> +subdirs = ['testsuites']
>  try:
>      import rtems_waf.rtems as rtems
> 2.26.2
> devel mailing list
> devel at rtems.org
