#3860 - GSoC enquiries
Ida Delphine
idadelm at gmail.com
Sun Apr 4 19:24:46 UTC 2021
Hello,
Please who are the possible mentors for this project?
On Sun, 4 Apr 2021, 3:32 am Ida Delphine, <idadelm at gmail.com> wrote:
> Regarding adding a script similar to linux/checkpatch.pl the criteria
> whether patches should need changes before being applied will be based on
> the output from running uncrustify right?
> On Sat, Apr 3, 2021 at 2:32 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Fri, Apr 2, 2021 at 6:09 PM Joel Sherrill <joel at rtems.org> wrote:
>> > On Fri, Apr 2, 2021, 6:59 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Fri, Apr 2, 2021 at 4:48 PM Ida Delphine <idadelm at gmail.com> wrote:
>> >> > Hello,
>> >> > Please can you help explain what you mean by Adding a "check-style"
>> target to the RTEMS build system?
>> >> > And how I could possibly go about this?
>> >> I don't know if this makes sense exactly to me. When compiling RTEMS
>> >> it could be nice to have an option to check the style rules for
>> >> compliance. This would be something to integrate in the
>> >> rtems.git/wscript file most likely, as part of the waf build system.
>> >> However, since checking style does not generate a target file, I don't
>> >> know that this really is suitable as a way to verify style rules. It
>> >> may be suitable to add a standalone script in rtems-tools.git that can
>> >> be run over the rtems.git that creates a report about style problems.
>> >> Maybe, a way to configure it to ignore some files or to add exceptions
>> >> to the style rules for certain cases then could be possible.
>> > If you have a configuration that produces the code formatted as
>> expected in certain directories, then if a change is made as part of normal
>> development, running uncrustify will result in changes to the file needed.
>> In a way the goal is to have a directory full of files that an RTEMS
>> uncrustify configuration does not change.
>> > If you have a script that can do that manually then we can easily add
>> an automated check somewhere in the process to ensure that directories that
>> adhere to the style rules continue to adhere to them.
>> > One thing to keep in mind is that there there are places where
>> uncrustify does not have the ability to format code the way RTEMS has
>> historically done it. we want the rules to be as close as possible to the
>> existing practice but we are willing to adjust practice if it allows the
>> tool to produce formatted output we can trust.
>> Also on the table could be modifications to uncrustify.
>> > On each point where this type of issue occurs, we'll have to have a
>> discussion about our Style versus what tool supports. It's likely indicates
>> we're doing something that's not common in the open source world.
>> > Once the delta between the output of uncrustify and the committed
>> source is zero, running uncrustify should produce no changes. Anything
>> uncrustify wants to change at that point would be a style violation and
>> flagged. In a perfect world it would prevent you from committing.
>> >> I think focus on 1 and 3 is better as a way to start, and perhaps
>> >> something like the above can be the phase 2 effort.
>> >> Gedare
>> >> > Cheers,
>> >> > Ida
>> >> > On Mon, Mar 29, 2021 at 9:45 PM Gedare Bloom <gedare at rtems.org>
>> wrote:
>> >> >> On Mon, Mar 29, 2021 at 1:28 PM Ida Delphine <idadelm at gmail.com>
>> wrote:
>> >> >> > Yes I have. But wondering how to run it with the given
>> configuration I saw in this thread(
>> https://lists.rtems.org/pipermail/devel/2020-October/062770.html).
>> >> >> If you download/copy the configuration into a cfg file, then you can
>> >> >> use the examples from
>> >> >> https://github.com/uncrustify/uncrustify#running-the-program and
>> >> >> attempt to run it on some files within rtems.git/cpukit/score/src
>> >> >> would be my suggestion.
>> >> >> > On Mon, Mar 29, 2021 at 3:37 PM Gedare Bloom <gedare at rtems.org>
>> wrote:
>> >> >> >> Hi Ida,
>> >> >> >> On Mon, Mar 29, 2021 at 7:36 AM Ida Delphine <idadelm at gmail.com>
>> wrote:
>> >> >> >> > Hello,
>> >> >> >> > Please do you mind telling me how to run uncrustify with the
>> given configuration with any sample file?
>> >> >> >> What have you tried? Any directions followed/attempted or notes
>> that
>> >> >> >> you have taken would be helpful.
>> >> >> >> I guess all the info that you should need is in Uncrustify's
>> readme
>> >> >> >> file. https://github.com/uncrustify/uncrustify
>> >> >> >> Did you successfully compile uncrustify tool?
>> >> >> >> > I'm a bit stuck.
>> >> >> >> > Thanks,
>> >> >> >> > Ida.
>> >> >> >> > On Wed, Mar 17, 2021 at 10:34 PM Gedare Bloom <
>> >> >> >> >> On Wed, Mar 17, 2021 at 2:28 PM Ida Delphine <
>> >> >> >> >> > Hello,
>> >> >> >> >> > So I have gone through this configuration file and I think
>> I'm getting it. However I'm a bit lost in the reading the messages in the
>> thread. Do you mind explaining? Or we can start talking about a way forward.
>> >> >> >> >> > Also can you help me with some steps on how to test this by
>> myself if possible?
>> >> >> >> >> It may be easier if you go "up" a level to see the full thread
>> >> >> >> >> context:
>> https://lists.rtems.org/pipermail/devel/2020-October/thread.html#62769
>> >> >> >> >> Then you can go through the messages non-linearly. Right now,
>> the
>> >> >> >> >> basic idea is to follow the steps outlined in the open
>> project ticket.
>> >> >> >> >> I think Christian has summarized it nicely in his recent
>> email [1]: "I
>> >> >> >> >> think the contributions from this project that would add
>> value would
>> >> >> >> >> be:
>> >> >> >> >> 1. Finding a tool and a configuration that can do an RTEMS
>> style or an
>> >> >> >> >> acceptable close one.
>> >> >> >> >> 2. Adding a "check-style" target to our build system.
>> >> >> >> >> 3. Maybe add some kind of script similar to Linux "
>> checkpatch.pl" that
>> >> >> >> >> could check whether patches would need changes _before_ they
>> are
>> >> >> >> >> applied.
>> >> >> >> >> The proposal preparation phase should work through
>> identifying the
>> >> >> >> >> options and pros/cons for different tools while preparing a
>> plan for
>> >> >> >> >> how to integrate style checks in 2, 3 and thinking through
>> the coding
>> >> >> >> >> tasks for the summer.
>> >> >> >> >> Getting the style checking tool's configuration to match with
>> the
>> >> >> >> >> RTEMS style will be some effort, and testing it out and
>> submitting
>> >> >> >> >> some patches based on it could be a good proposal activity
>> also to
>> >> >> >> >> build some confidence about the tools that will be used.
>> >> >> >> >> We also have some Python style guidelines that might be worth
>> >> >> >> >> addressing. Those are harder maybe, since the style
>> refactoring might
>> >> >> >> >> be challenging to review for correctness.
>> >> >> >> >> For getting started, I would recommend that you try running
>> uncrustify
>> >> >> >> >> with the given configuration on some files in RTEMS, see what
>> it
>> >> >> >> >> results in. Play around.
>> >> >> >> >> [1]
>> https://lists.rtems.org/pipermail/devel/2021-March/065547.html
>> >> >> >> >> -Gedare
>> >> >> >> >> > Thanks,
>> >> >> >> >> > Ida
>> >> >> >> >> > On Mon, Mar 15, 2021 at 9:39 PM Gedare Bloom <
>> >> >> >> >> >> See the related thread, and we'll have to discuss how to
>> move forward.
>> >> >> >> >> >> The existing approach provides an uncrustify script:
>> https://lists.rtems.org/pipermail/devel/2020-October/062769.html
>> >> >> >> >> >> On Sun, Mar 14, 2021 at 9:47 PM Ida Delphine <
>> >> >> >> >> >> > Hello everyone,
>> >> >> >> >> >> > This ticket(https://devel.rtems.org/ticket/3860) was
>> proposed to me and I'm interested in it for GSoC.
>> >> >> >> >> >> > The first task there is to find a code checker or
>> formater that can produce results that match the RTEMS coding conventions.
>> It also made mention some tools have been discussed in the past. Please I
>> will love suggestions on possible tools I could use to achieve this.
>> >> >> >> >> >> > Cheers,
>> >> >> >> >> >> > Ida.
>> >> >> >> >> >> > _______________________________________________
>> >> >> >> >> >> > devel mailing list
>> >> >> >> >> >> > devel at rtems.org
>> >> >> >> >> >> > http://lists.rtems.org/mailman/listinfo/devel
>> >> devel mailing list
>> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210404/c0ace49d/attachment-0001.html>
