GSoC 2021 Student Applications Open and Deadline
Mon Apr 5 17:26:08 UTC 2021
On Mon, Apr 5, 2021 at 12:13 PM Gedare Bloom <gedare at rtems.org> wrote:
> As I recall, students can submit their 'final' PDF proposals multiple
> times, so unless a student is not certain about submitting a proposal
> to RTEMS, they should feel free to submit their drafts as final once
> they have the bulk of it done. Probably should confirm that however.
Agreed. But they need to write proposals, get them reviewed and into
the GSoC application system.
--joel
> Gedare
> On Mon, Apr 5, 2021 at 7:19 AM Joel Sherrill <joel at rtems.org> wrote:
> > Hi
> > I wanted to make sure all the students interested in GSoC 2021 with
> RTEMS were aware that the application period is open and that the deadline
> for applications is April 13 18:00 UTC.
> > This means you really need to get your proposal together soon to allow
> potential mentors to review it and provide guidance.
> > I have made suggestions to multiple students that it is important to do
> what you can to de-risk your project. For example, if you are porting
> software to RTEMS, make sure it works and you know how to use it before
> starting the port. It will make your life easier. This is really good
> advice but at this point you need to work on  your proposals.
> > Please do drafts in Google Docs and let mentors have access by name to
> at least comment.
> > Also do NOT want until the last minute to submit to Google. There are no
> deadlines and the site can get overloaded. You should be able to update
> your proposal on their site until the application period closes.
> > Thanks and good luck.
> > --joel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210405/934c260b/attachment.html>
