GSoC 2021 Student Applications Open and Deadline
Gedare Bloom
gedare at rtems.org
Mon Apr 5 17:13:24 UTC 2021
As I recall, students can submit their 'final' PDF proposals multiple
times, so unless a student is not certain about submitting a proposal
to RTEMS, they should feel free to submit their drafts as final once
they have the bulk of it done. Probably should confirm that however.
Gedare
On Mon, Apr 5, 2021 at 7:19 AM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I wanted to make sure all the students interested in GSoC 2021 with RTEMS were aware that the application period is open and that the deadline for applications is April 13 18:00 UTC.
> This means you really need to get your proposal together soon to allow potential mentors to review it and provide guidance.
> I have made suggestions to multiple students that it is important to do what you can to de-risk your project. For example, if you are porting software to RTEMS, make sure it works and you know how to use it before starting the port. It will make your life easier. This is really good advice but at this point you need to work on your proposals.
> Please do drafts in Google Docs and let mentors have access by name to at least comment.
> Also do NOT want until the last minute to submit to Google. There are no deadlines and the site can get overloaded. You should be able to update your proposal on their site until the application period closes.
> Thanks and good luck.
> --joel
> devel mailing list
> devel at rtems.org
