[PATCH 0/2] covoar: Handle symbol sets
Alex White
alex.white at oarcorp.com
Mon Apr 5 19:46:23 UTC 2021
On Mon, Apr 5, 2021 at 2:25 PM Alex White <alex.white at oarcorp.com> wrote:
> This patch set changes the way covoar is invoked so that its run time
> is greatly reduced. For instance, a full coverage run for the
> xilinx_zynq_a9_qemu took 58 minutes before these changes. After making
> these changes, that same coverage run takes 3 minutes 15 seconds.
> Care has been taken to limit the amount of formatting and C++
> modernization changes so that patch review is easier. A follow-up patch
> will clean up some of the methods that were touched as part of the
> covoar patch.
> Details can be found here:
> https://devel.rtems.org/ticket/4374
To help with review:
Most changes just cascade from the fact that the data structures in
`DesiredSymbols` have changed. Instead of just having a set of all
symbols, there is now also a mapping of symbol set names to lists of
symbol names. Additionally, the statistics are now stored in a map
which is keyed on the symbol set names.
A large number of changes in the covoar patch follow the same pattern
of changing a loop from iterating over the master set to now iterating
over all symbols in a given symbol set and doing a lookup in the master
set.
Before:
loop over symbolName-info pairs in master set
do something with info
After:
loop over setName-symbolNames pairs
loop over symbolName in symbolNames
look up info in master set by symbolName
> Alex White (2):
> covoar: Split symbols by symbol set
> coverage.py: Call covoar once
> tester/covoar/DesiredSymbols.cc | 465 +++++++++++++++++---------------
> tester/covoar/DesiredSymbols.h | 98 +++++--
> tester/covoar/ReportsBase.cc | 181 +++++++------
> tester/covoar/ReportsBase.h | 40 ++-
> tester/covoar/ReportsHtml.cc | 62 +++--
> tester/covoar/ReportsHtml.h | 13 +-
> tester/covoar/ReportsText.cc | 66 ++---
> tester/covoar/ReportsText.h | 13 +-
> tester/covoar/covoar.cc | 6 +-
> tester/rt/coverage.py | 59 ++--
> 10 files changed, 571 insertions(+), 432 deletions(-)
> 2.27.0
> devel mailing list
> devel at rtems.org
