[PATCH 1/2] covoar: Split symbols by symbol set
Joel Sherrill
joel at rtems.org
Tue Apr 6 16:31:42 UTC 2021
On Tue, Apr 6, 2021 at 10:56 AM Gedare Bloom <gedare at rtems.org> wrote:
> looks ok, it's a lot to try to process though.
> In a future patch it would be good to provide more useful names, I
> don't know what 'ha' and 'la' mean, if anything. at least 'a' I
> understand to be an address.
high and low address which probably is my fault from 10+ years ago.
> Also, the typedef with appending _t at the end should be removed, _t
> is reserved by POSIX.
Good catch although I do like _t. :(
> And I don't know why the _m is being appended, I guess it is denoted
> member variables? I'm used to seeing it as a prefix rather than a
> suffix, if it gets used at all. A few more C++ issues to add to the
> backlog.
This is also from the earliest days of this code. Looks like it didn't
catch on.
I do tend to prefer suffixes over prefixes but if it isn't common, OK.
Probably easy enough to do a grep and then search and replace them all
in one pass. Should not change spacing and should be harmless.
--joel
> On Mon, Apr 5, 2021 at 1:25 PM Alex White <alex.white at oarcorp.com> wrote:
> > This changes the way covoar organizes the symbols. Instead of treating
> > all symbols as one set, covoar is now aware of multiple symbol sets and
> > tracks statistics for each set. It now also generates reports for each
> > symbol set.
> > This change relieves the caller of covoar of the reponsibility of
> > managing the symbol sets. As a result, covoar can minimize the work
> > done for each symbol set, yielding a significant speedup.
> > Updates #4374
> > tester/covoar/DesiredSymbols.cc | 465 +++++++++++++++++---------------
> > tester/covoar/DesiredSymbols.h | 98 +++++--
> > tester/covoar/ReportsBase.cc | 181 +++++++------
> > tester/covoar/ReportsBase.h | 40 ++-
> > tester/covoar/ReportsHtml.cc | 62 +++--
> > tester/covoar/ReportsHtml.h | 13 +-
> > tester/covoar/ReportsText.cc | 66 ++---
> > tester/covoar/ReportsText.h | 13 +-
> > tester/covoar/covoar.cc | 6 +-
> > 9 files changed, 542 insertions(+), 402 deletions(-)
> > diff --git a/tester/covoar/DesiredSymbols.cc
> b/tester/covoar/DesiredSymbols.cc
> > index ffc4f86..2866dbe 100644
> > --- a/tester/covoar/DesiredSymbols.cc
> > +++ b/tester/covoar/DesiredSymbols.cc
> > @@ -37,6 +37,11 @@ namespace Coverage {
> > + const DesiredSymbols::symbolSet_t& DesiredSymbols::allSymbols() const
> > + return set;
> > void DesiredSymbols::load(
> > const std::string& symbolsSet,
> > const std::string& buildTarget,
> > @@ -44,8 +49,6 @@ namespace Coverage {
> > bool verbose
> > - rld::files::cache cache;
> > // Load the INI file looking for a top level:
> > @@ -60,61 +63,61 @@ namespace Coverage {
> > // [B]
> > // libraries = @BUILD-PREFIX@/c/@BSP@/B/libB.a
> > - try {
> > - cache.open();
> > + rld::config::config config;
> > - rld::config::config config;
> > + if (verbose)
> > + std::cerr << "Loading symbol sets: " << symbolsSet << std::endl;
> > - if (verbose)
> > - std::cerr << "Loading symbol sets: " << symbolsSet << std::endl;
> > + config.load (symbolsSet);
> > - config.load (symbolsSet);
> > + const rld::config::section& sym_section =
> config.get_section("symbol-sets");
> > - const rld::config::section& sym_section =
> > + rld::strings sets;
> > + rld::config::parse_items (sym_section, "sets", sets, true);
> > - rld::strings sets;
> > - rld::config::parse_items (sym_section, "sets", sets, true);
> > + // Load the symbols for each set specified in the config file.
> > + for (const auto& setName : sets) {
> > + rld::files::cache cache;
> > + cache.open();
> > - for (const std::string set : sets) {
> > + if (verbose)
> > + std::cerr << "Loading symbols for set: " << setName <<
> std::endl;
> > + const rld::config::section& set_section =
> config.get_section(setName);
> > + rld::strings libs;
> > + rld::config::parse_items (set_section, "libraries", libs, true);
> > + for (std::string lib : libs) {
> > + lib = rld::find_replace(lib, "@BUILD-TARGET@", buildTarget);
> > + lib = rld::find_replace(lib, "@BSP@", buildBSP);
> > if (verbose)
> > - std::cerr << " Symbol set: " << set << std::endl;
> > - const rld::config::section& set_section =
> config.get_section(set);
> > - rld::strings libs;
> > - rld::config::parse_items (set_section, "libraries", libs, true);
> > - for (std::string lib : libs) {
> > - lib = rld::find_replace(lib, "@BUILD-TARGET@", buildTarget);
> > - lib = rld::find_replace(lib, "@BSP@", buildBSP);
> > - if (verbose)
> > - std::cerr << " Loading library: " << lib << std::endl;
> > - cache.add(lib);
> > + std::cerr << " Loading library: " << lib << std::endl;
> > + cache.add(lib);
> > rld::symbols::table symbols;
> > cache.load_symbols (symbols, true);
> > + // Populate the symbol maps with all global symbols.
> > for (auto& kv : symbols.globals()) {
> > const rld::symbols::symbol& sym = *(kv.second);
> > - if (sym.type() == sym.st_func)
> > + if (sym.type() == sym.st_func) {
> > set[sym.name()] = *(new SymbolInformation);
> > + setNamesToSymbols[setName].push_back(sym.name());
> > + // Populate the symbol maps with all weak symbols.
> > for (auto& kv : symbols.weaks()) {
> > - } catch (...) {
> > - cache.close();
> > - throw;
> > - cache.close();
> > void DesiredSymbols::preprocess( void )
> > // Look at each symbol.
> > for (auto& s : SymbolsToAnalyze->set) {
> > // If the unified coverage map does not exist, the symbol was
> > @@ -135,48 +138,52 @@ namespace Coverage {
> > void DesiredSymbols::calculateStatistics( void )
> > - // Look at each symbol.
> > - for (auto& s : SymbolsToAnalyze->set) {
> > - // If the unified coverage map does not exist, the symbol was
> > - // never referenced by any executable. Just skip it.
> > - CoverageMapBase* theCoverageMap = s.second.unifiedCoverageMap;
> > - if (theCoverageMap)
> > - // Increment the total sizeInBytes by the bytes in the symbol
> > - stats.sizeInBytes += s.second.stats.sizeInBytes;
> > - // Now scan through the coverage map of this symbol.
> > - uint32_t endAddress = s.second.stats.sizeInBytes - 1;
> > - for (uint32_t a = 0; a <= endAddress; ++a) {
> > - // If we are at the start of instruction increment
> > - // instruction type counters as needed.
> > - if ( theCoverageMap->isStartOfInstruction( a ) ) {
> > - stats.sizeInInstructions++;
> > - s.second.stats.sizeInInstructions++;
> > - if (!theCoverageMap->wasExecuted( a ) ) {
> > - stats.uncoveredInstructions++;
> > - s.second.stats.uncoveredInstructions++;
> > - if ( theCoverageMap->isBranch( a )) {
> > - stats.branchesNotExecuted++;
> > - s.second.stats.branchesNotExecuted++;
> > + // Look at each symbol set.
> > + for (const auto& kv : setNamesToSymbols) {
> > + // Look at each symbol.
> > + for (const auto& symbol : kv.second) {
> > + SymbolInformation& info = set.at(symbol);
> > + // If the unified coverage map does not exist, the symbol was
> > + // never referenced by any executable. Just skip it.
> > + CoverageMapBase* theCoverageMap = info.unifiedCoverageMap;
> > + if (theCoverageMap) {
> > + // Increment the total sizeInBytes by the bytes in the symbol
> > + stats[kv.first].sizeInBytes += info.stats.sizeInBytes;
> > + // Now scan through the coverage map of this symbol.
> > + uint32_t endAddress = info.stats.sizeInBytes - 1;
> > + for (uint32_t a = 0; a <= endAddress; ++a) {
> > + // If we are at the start of instruction increment
> > + // instruction type counters as needed.
> > + if ( theCoverageMap->isStartOfInstruction( a ) ) {
> > + stats[kv.first].sizeInInstructions++;
> > + info.stats.sizeInInstructions++;
> > + if (!theCoverageMap->wasExecuted( a ) ) {
> > + stats[kv.first].uncoveredInstructions++;
> > + info.stats.uncoveredInstructions++;
> > + if ( theCoverageMap->isBranch( a )) {
> > + stats[kv.first].branchesNotExecuted++;
> > + info.stats.branchesNotExecuted++;
> > + } else if (theCoverageMap->isBranch( a )) {
> > + stats[kv.first].branchesExecuted++;
> > + info.stats.branchesExecuted++;
> > - } else if (theCoverageMap->isBranch( a )) {
> > - stats.branchesExecuted++;
> > - s.second.stats.branchesExecuted++;
> > - if (!theCoverageMap->wasExecuted( a )) {
> > - stats.uncoveredBytes++;
> > - s.second.stats.uncoveredBytes++;
> > + if (!theCoverageMap->wasExecuted( a )) {
> > + stats[kv.first].uncoveredBytes++;
> > + info.stats.uncoveredBytes++;
> > + } else {
> > + stats[kv.first].unreferencedSymbols++;
> > - } else {
> > - stats.unreferencedSymbols++;
> > @@ -184,152 +191,155 @@ namespace Coverage {
> > void DesiredSymbols::computeUncovered( void )
> > - // Create containers for the symbol's uncovered ranges and
> branches.
> > - CoverageRanges* theRanges = new CoverageRanges();
> > - s.second.uncoveredRanges = theRanges;
> > - CoverageRanges* theBranches = new CoverageRanges();
> > - s.second.uncoveredBranches = theBranches;
> > - uint32_t a;
> > - uint32_t la;
> > - uint32_t ha;
> > - uint32_t endAddress;
> > - uint32_t count;
> > - // Mark NOPs as executed
> > - a = s.second.stats.sizeInBytes - 1;
> > - count = 0;
> > - while (a > 0) {
> > - if (theCoverageMap->isStartOfInstruction( a )) {
> > - break;
> > - count++;
> > - if (theCoverageMap->isNop( a )) {
> > - for (la = a; la < (a + count); la++) {
> > - theCoverageMap->setWasExecuted( la );
> > + // Create containers for the symbol's uncovered ranges and
> branches.
> > + CoverageRanges* theRanges = new CoverageRanges();
> > + info.uncoveredRanges = theRanges;
> > + CoverageRanges* theBranches = new CoverageRanges();
> > + info.uncoveredBranches = theBranches;
> > + uint32_t a;
> > + uint32_t la;
> > + uint32_t ha;
> > + uint32_t endAddress;
> > + uint32_t count;
> > + // Mark NOPs as executed
> > + a = info.stats.sizeInBytes - 1;
> > + count = 0;
> > + while (a > 0) {
> > + if (theCoverageMap->isStartOfInstruction( a )) {
> > + break;
> > - count = 0;
> > + count++;
> > - a--;
> > + if (theCoverageMap->isNop( a )) {
> > + for (la = a; la < (a + count); la++) {
> > + theCoverageMap->setWasExecuted( la );
> > - endAddress = s.second.stats.sizeInBytes - 1;
> > - a = 0;
> > - while (a < endAddress) {
> > - a++;
> > - continue;
> > + count = 0;
> > - for (ha=a+1;
> > - ha <= endAddress &&
> !theCoverageMap->isStartOfInstruction( ha );
> > - ha++)
> > - if ( ha >= endAddress )
> > - break;
> > - if (theCoverageMap->isNop( ha ))
> > - do {
> > - theCoverageMap->setWasExecuted( ha );
> > - ha++;
> > - break;
> > - } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
> > - theCoverageMap->isNop( ha ) );
> > - a = ha;
> > + a--;
> > - endAddress = s.second.stats.sizeInBytesWithoutNops - 1;
> > - a = 0;
> > - while (a <= endAddress) {
> > - // If an address was NOT executed, find consecutive unexecuted
> > - // addresses and add them to the uncovered ranges.
> > - la = a;
> > - count = 1;
> > - for (ha = a + 1;
> > - ha <= endAddress && !theCoverageMap->wasExecuted( ha );
> > - ha++)
> > - if ( theCoverageMap->isStartOfInstruction( ha ) )
> > - count++;
> > + endAddress = info.stats.sizeInBytes - 1;
> > + a = 0;
> > + while (a < endAddress) {
> > + a++;
> > + continue;
> > - ha--;
> > - stats.uncoveredRanges++;
> > - s.second.stats.uncoveredRanges++;
> > - theRanges->add(
> > - s.second.baseAddress + la,
> > - s.second.baseAddress + ha,
> > - CoverageRanges::UNCOVERED_REASON_NOT_EXECUTED,
> > - count
> > - a = ha + 1;
> > - // If an address is a branch instruction, add any uncovered
> branches
> > - // to the uncoverd branches.
> > - else if (theCoverageMap->isBranch( a )) {
> > - la = a;
> > - for (ha = a + 1;
> > - ha++)
> > + for (ha=a+1;
> > + ha <= endAddress &&
> > + ha++)
> > - ha--;
> > - if (theCoverageMap->wasAlwaysTaken( la )) {
> > - stats.branchesAlwaysTaken++;
> > - s.second.stats.branchesAlwaysTaken++;
> > - theBranches->add(
> > - CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN,
> > - 1
> > + if ( ha >= endAddress )
> > + break;
> > + if (theCoverageMap->isNop( ha ))
> > + do {
> > + theCoverageMap->setWasExecuted( ha );
> > + ha++;
> > + break;
> > + } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
> > + theCoverageMap->isNop( ha ) );
> > + a = ha;
> > + endAddress = info.stats.sizeInBytesWithoutNops - 1;
> > + a = 0;
> > + while (a <= endAddress) {
> > + // If an address was NOT executed, find consecutive
> unexecuted
> > + // addresses and add them to the uncovered ranges.
> > + la = a;
> > + count = 1;
> > + for (ha = a + 1;
> > + ha <= endAddress && !theCoverageMap->wasExecuted( ha
> > + ha++)
> > + if ( theCoverageMap->isStartOfInstruction( ha ) )
> > + count++;
> > + ha--;
> > + stats[kv.first].uncoveredRanges++;
> > + info.stats.uncoveredRanges++;
> > + theRanges->add(
> > + info.baseAddress + la,
> > + info.baseAddress + ha,
> > + CoverageRanges::UNCOVERED_REASON_NOT_EXECUTED,
> > + count
> > - if (Verbose)
> > - std::cerr << "Branch always taken found in" << s.first
> > - << std::hex
> > - << " (0x" << s.second.baseAddress + la
> > - << " - 0x" << s.second.baseAddress + ha
> > - << std::dec
> > - << std::endl;
> > + a = ha + 1;
> > - else if (theCoverageMap->wasNeverTaken( la )) {
> > - stats.branchesNeverTaken++;
> > - s.second.stats.branchesNeverTaken++;
> > - theBranches->add(
> > - CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN,
> > - 1
> > + // If an address is a branch instruction, add any uncovered
> branches
> > + // to the uncoverd branches.
> > + else if (theCoverageMap->isBranch( a )) {
> > + la = a;
> > + for (ha = a + 1;
> > + ha++)
> > + ha--;
> > + if (theCoverageMap->wasAlwaysTaken( la )) {
> > + stats[kv.first].branchesAlwaysTaken++;
> > + info.stats.branchesAlwaysTaken++;
> > + theBranches->add(
> > + CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN,
> > + 1
> > - if (Verbose)
> > - std::cerr << "Branch never taken found in " << s.first
> > - << std::hex
> > - << std::dec
> > - << std::endl;
> > + if (Verbose)
> > + std::cerr << "Branch always taken found in" << symbol
> > + << std::hex
> > + << " (0x" << info.baseAddress + la
> > + << " - 0x" << info.baseAddress + ha
> > + << std::dec
> > + << std::endl;
> > + else if (theCoverageMap->wasNeverTaken( la )) {
> > + stats[kv.first].branchesNeverTaken++;
> > + info.stats.branchesNeverTaken++;
> > + theBranches->add(
> > + CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN,
> > + 1
> > + if (Verbose)
> > + std::cerr << "Branch never taken found in " << symbol
> > + << std::hex
> > + << std::dec
> > + << std::endl;
> > + a = ha + 1;
> > - a = ha + 1;
> > + else
> > + a++;
> > - else
> > - a++;
> > @@ -460,30 +470,61 @@ namespace Coverage {
> > - uint32_t DesiredSymbols::getNumberBranchesAlwaysTaken( void ) const {
> > - return stats.branchesAlwaysTaken;
> > + uint32_t DesiredSymbols::getNumberBranchesAlwaysTaken(
> > + const std::string& symbolSetName
> > + ) const {
> > + return stats.at(symbolSetName).branchesAlwaysTaken;
> > - uint32_t DesiredSymbols::getNumberBranchesFound( void ) const {
> > - return (stats.branchesNotExecuted + stats.branchesExecuted);
> > + uint32_t DesiredSymbols::getNumberBranchesFound(
> > + ) const {
> > + return (
> > + stats.at(symbolSetName).branchesNotExecuted +
> > + stats.at(symbolSetName).branchesExecuted
> > - uint32_t DesiredSymbols::getNumberBranchesNeverTaken( void ) const {
> > - return stats.branchesNeverTaken;
> > + uint32_t DesiredSymbols::getNumberBranchesNeverTaken(
> > + ) const {
> > + return stats.at(symbolSetName).branchesNeverTaken;
> > - uint32_t DesiredSymbols::getNumberBranchesNotExecuted( void ) const {
> > - return stats.branchesNotExecuted;
> > + uint32_t DesiredSymbols::getNumberBranchesNotExecuted(
> > + ) const {
> > + return stats.at(symbolSetName).branchesNotExecuted;
> > - uint32_t DesiredSymbols::getNumberUncoveredRanges( void ) const {
> > - return stats.uncoveredRanges;
> > + uint32_t DesiredSymbols::getNumberUncoveredRanges(
> > + ) const {
> > + return stats.at(symbolSetName).uncoveredRanges;
> > - uint32_t DesiredSymbols::getNumberUnreferencedSymbols( void ) const {
> > - return stats.unreferencedSymbols;
> > + uint32_t DesiredSymbols::getNumberUnreferencedSymbols(
> > + ) const {
> > + return stats.at(symbolSetName).unreferencedSymbols;
> > + std::vector<std::string> DesiredSymbols::getSetNames( void ) const {
> > + std::vector<std::string> setNames;
> > + for (const auto &kv : setNamesToSymbols) {
> > + setNames.push_back(kv.first);
> > + return setNames;
> > + const std::vector<std::string>& DesiredSymbols::getSymbolsForSet(
> > + ) const
> > + return setNamesToSymbols.at(symbolSetName);
> > bool DesiredSymbols::isDesired (
> > const std::string& symbolName
> > ) const
> > diff --git a/tester/covoar/DesiredSymbols.h
> b/tester/covoar/DesiredSymbols.h
> > index 5cf96e9..5280d50 100644
> > --- a/tester/covoar/DesiredSymbols.h
> > +++ b/tester/covoar/DesiredSymbols.h
> > @@ -197,12 +197,6 @@ namespace Coverage {
> > typedef std::map<std::string, SymbolInformation> symbolSet_t;
> > - * This variable contains a map of symbol sets for each
> > - * symbol in the system keyed on the symbol name.
> > - symbolSet_t set;
> > * This method constructs a DesiredSymbols instance.
> > @@ -213,6 +207,11 @@ namespace Coverage {
> > ~DesiredSymbols();
> > + * The set of all symbols.
> > + const symbolSet_t& allSymbols() const;
> > * This method loops through the coverage map and
> > * calculates the statistics that have not already
> > @@ -262,51 +261,93 @@ namespace Coverage {
> > * This method returns the total number of branches always taken
> > - * for all analyzed symbols.
> > + * for all analyzed symbols in a given set.
> > + * @param[in] symbolSetName specifies the symbol set of interest
> > * @return Returns the total number of branches always taken
> > - uint32_t getNumberBranchesAlwaysTaken( void ) const;
> > + uint32_t getNumberBranchesAlwaysTaken(
> > + ) const;
> > * This method returns the total number of branches found for
> > - * all analyzed symbols.
> > + * all analyzed symbols in a given set.
> > * @return Returns the total number of branches found
> > - uint32_t getNumberBranchesFound( void ) const;
> > + uint32_t getNumberBranchesFound(
> > + ) const;
> > * This method returns the total number of branches never taken
> > * @return Returns the total number of branches never taken
> > - uint32_t getNumberBranchesNeverTaken( void ) const;
> > + uint32_t getNumberBranchesNeverTaken(
> > + ) const;
> > * This method returns the total number of branches not executed
> > * @return Returns the total number of branches not executed
> > - uint32_t getNumberBranchesNotExecuted( void ) const;
> > + uint32_t getNumberBranchesNotExecuted(
> > + ) const;
> > * This method returns the total number of uncovered ranges
> > * @return Returns the total number of uncovered ranges
> > - uint32_t getNumberUncoveredRanges( void ) const;
> > + uint32_t getNumberUncoveredRanges(
> > + ) const;
> > * This method returns the total number of unreferenced symbols
> > * @return Returns the total number of unreferenced symbols
> > - uint32_t getNumberUnreferencedSymbols( void ) const;
> > + uint32_t getNumberUnreferencedSymbols(
> > + ) const;
> > + * This method returns all symbol set names.
> > + * @return Returns all symbol set names
> > + std::vector<std::string> getSetNames( void ) const;
> > + * This method returns all symbols for a given set.
> > + * @return Returns all symbols for the given set
> > + const std::vector<std::string>& getSymbolsForSet(
> > + ) const;
> > * This method returns an indication of whether or not the
> specified
> > @@ -353,11 +394,6 @@ namespace Coverage {
> > void preprocess( void );
> > - * This member contains the statistics kept on each symbol.
> > - Statistics stats;
> > private:
> > @@ -369,6 +405,22 @@ namespace Coverage {
> > ExecutableInfo* const theExecutable
> > + * This variable contains a map of symbol sets for each
> > + * symbol in the system keyed on the symbol name.
> > + symbolSet_t set;
> > + * This variable contains a map of symbol set names to symbol name
> lists.
> > + std::map<std::string, std::vector<std::string>> setNamesToSymbols;
> > + * This member contains a map of symbol set names to statistics.
> > + std::map<std::string, Statistics> stats;
> > diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
> > index 40ed209..fea776c 100644
> > --- a/tester/covoar/ReportsBase.cc
> > +++ b/tester/covoar/ReportsBase.cc
> > @@ -20,8 +20,9 @@
> > -ReportsBase::ReportsBase( time_t timestamp ):
> > +ReportsBase::ReportsBase( time_t timestamp, std::string symbolSetName ):
> > reportExtension_m(""),
> > + symbolSetName_m(symbolSetName),
> > timestamp_m( timestamp )
> > @@ -31,27 +32,38 @@ ReportsBase::~ReportsBase()
> > FILE* ReportsBase::OpenFile(
> > - const char* const fileName
> > + const char* const fileName,
> > + const char* const symbolSetName
> > int sc;
> > FILE *aFile;
> > std::string file;
> > + std::string symbolSetOutputDirectory;
> > + rld::path::path_join(
> > + outputDirectory,
> > + symbolSetName,
> > + symbolSetOutputDirectory
> > // Create the output directory if it does not already exist
> > #ifdef _WIN32
> > - sc = _mkdir( outputDirectory );
> > + sc = _mkdir( symbolSetOutputDirectory );
> > #else
> > - sc = mkdir( outputDirectory,0755 );
> > + sc = mkdir( symbolSetOutputDirectory.c_str(),0755 );
> > #endif
> > if ( (sc == -1) && (errno != EEXIST) ) {
> > - fprintf(stderr, "Unable to create output directory %s\n",
> outputDirectory);
> > + fprintf(
> > + stderr,
> > + "Unable to create output directory %s\n",
> > + symbolSetOutputDirectory.c_str()
> > return NULL;
> > - file = outputDirectory;
> > - file += "/";
> > - file += fileName;
> > + file = symbolSetOutputDirectory;
> > + rld::path::path_join(file, fileName, file);
> > // Open the file.
> > aFile = fopen( file.c_str(), "w" );
> > @@ -71,7 +83,7 @@ FILE* ReportsBase::OpenAnnotatedFile(
> > - return OpenFile(fileName);
> > + return OpenFile(fileName, symbolSetName_m.c_str());
> > FILE* ReportsBase::OpenBranchFile(
> > @@ -79,21 +91,21 @@ FILE* ReportsBase::OpenBranchFile(
> > bool hasBranches
> > FILE* ReportsBase::OpenCoverageFile(
> > FILE* ReportsBase::OpenNoRangeFile(
> > @@ -101,14 +113,14 @@ FILE* ReportsBase::OpenSizeFile(
> > FILE* ReportsBase::OpenSymbolSummaryFile(
> > void ReportsBase::CloseFile(
> > @@ -186,41 +198,42 @@ void ReportsBase::WriteAnnotatedReport(
> > FILE* aFile
> = NULL;
> > - Coverage::DesiredSymbols::symbolSet_t::iterator ditr;
> > Coverage::CoverageRanges*
> theBranches;
> theRanges;
> > Coverage::CoverageMapBase*
> theCoverageMap = NULL;
> > uint32_t
> bAddress = 0;
> > AnnotatedLineState_t state;
> > - std::list<Coverage::ObjdumpProcessor::objdumpLine_t>*
> theInstructions;
> > - std::list<Coverage::ObjdumpProcessor::objdumpLine_t>::iterator itr;
> > + const std::list<Coverage::ObjdumpProcessor::objdumpLine_t>*
> theInstructions;
> > + std::list<
> > + Coverage::ObjdumpProcessor::objdumpLine_t>::const_iterator itr;
> > aFile = OpenAnnotatedFile(fileName);
> > if (!aFile)
> > return;
> > // Process uncovered branches for each symbol.
> > - for (ditr = SymbolsToAnalyze->set.begin();
> > - ditr != SymbolsToAnalyze->set.end();
> > - ditr++) {
> > + const std::vector<std::string>& symbols =
> SymbolsToAnalyze->getSymbolsForSet(symbolSetName_m);
> > + for (const auto& symbol : symbols) {
> > + const SymbolInformation& info =
> SymbolsToAnalyze->allSymbols().at(symbol);
> > // If uncoveredRanges and uncoveredBranches don't exist, then the
> > // symbol was never referenced by any executable. Just skip it.
> > - if ((ditr->second.uncoveredRanges == NULL) &&
> > - (ditr->second.uncoveredBranches == NULL))
> > + if ((info.uncoveredRanges == NULL) &&
> > + (info.uncoveredBranches == NULL))
> > continue;
> > // If uncoveredRanges and uncoveredBranches are empty, then
> everything
> > // must have been covered for this symbol. Just skip it.
> > - if ((ditr->second.uncoveredRanges->set.empty()) &&
> > - (ditr->second.uncoveredBranches->set.empty()))
> > + if ((info.uncoveredRanges->set.empty()) &&
> > + (info.uncoveredBranches->set.empty()))
> > continue;
> > - theCoverageMap = ditr->second.unifiedCoverageMap;
> > - bAddress = ditr->second.baseAddress;
> > - theInstructions = &(ditr->second.instructions);
> > - theRanges = ditr->second.uncoveredRanges;
> > - theBranches = ditr->second.uncoveredBranches;
> > + theCoverageMap = info.unifiedCoverageMap;
> > + bAddress = info.baseAddress;
> > + theInstructions = &(info.instructions);
> > + theRanges = info.uncoveredRanges;
> > + theBranches = info.uncoveredBranches;
> > // Add annotations to each line where necessary
> > AnnotatedStart( aFile );
> > @@ -274,14 +287,13 @@ void ReportsBase::WriteAnnotatedReport(
> > void ReportsBase::WriteBranchReport(
> > FILE* report = NULL;
> > Coverage::CoverageRanges::ranges_t::iterator ritr;
> > Coverage::CoverageRanges* theBranches;
> > unsigned int count;
> > bool hasBranches = true;
> > - if ((SymbolsToAnalyze->getNumberBranchesFound() == 0) ||
> > + if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) == 0)
> > (BranchInfoAvailable == false) )
> > hasBranches = false;
> > @@ -291,15 +303,16 @@ void ReportsBase::WriteBranchReport(
> > return;
> > // If no branches were found then branch coverage is not supported
> > - if ((SymbolsToAnalyze->getNumberBranchesFound() != 0) &&
> > + if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0)
> > (BranchInfoAvailable == true) ) {
> > - // Process uncovered branches for each symbol.
> > + // Process uncovered branches for each symbol in the set.
> > count = 0;
> > - ditr++) {
> > if (theBranches && !theBranches->set.empty()) {
> > @@ -307,7 +320,7 @@ void ReportsBase::WriteBranchReport(
> > ritr != theBranches->set.end() ;
> > ritr++ ) {
> > count++;
> > - PutBranchEntry( report, count, ditr, ritr );
> > + PutBranchEntry( report, count, symbol, info, ritr );
> > @@ -323,7 +336,6 @@ void ReportsBase::WriteCoverageReport(
> > FILE* report;
> > Coverage::CoverageRanges* theRanges;
> > @@ -346,26 +358,27 @@ void ReportsBase::WriteCoverageReport(
> > // Process uncovered ranges for each symbol.
> > count = 0;
> > - ditr++) {
> > // If uncoveredRanges doesn't exist, then the symbol was never
> > // referenced by any executable. There may be a problem with the
> > // desired symbols list or with the executables so put something
> > // in the report.
> > if (theRanges == NULL) {
> > - putCoverageNoRange( report, NoRangeFile, count, ditr->first );
> > + putCoverageNoRange( report, NoRangeFile, count, symbol );
> > count++;
> > } else if (!theRanges->set.empty()) {
> > for (ritr = theRanges->set.begin() ;
> > ritr != theRanges->set.end() ;
> > ritr++ ) {
> > - PutCoverageLine( report, count, ditr, ritr );
> > + PutCoverageLine( report, count, symbol, info, ritr );
> > count++;
> > @@ -383,7 +396,6 @@ void ReportsBase::WriteSizeReport(
> > FILE* report;
> > @@ -396,19 +408,20 @@ void ReportsBase::WriteSizeReport(
> > count = 0;
> > - ditr++) {
> > if (theRanges && !theRanges->set.empty()) {
> > ritr++ ) {
> > - PutSizeLine( report, count, ditr, ritr );
> > + PutSizeLine( report, count, symbol, ritr );
> > count++;
> > @@ -421,7 +434,6 @@ void ReportsBase::WriteSymbolSummaryReport(
> > FILE* report;
> > unsigned int count;
> > @@ -432,12 +444,13 @@ void ReportsBase::WriteSymbolSummaryReport(
> > // Process each symbol.
> > count = 0;
> > - ditr++) {
> > - PutSymbolSummaryLine( report, count, ditr );
> > + PutSymbolSummaryLine( report, count, symbol, info );
> > count++;
> > @@ -445,13 +458,13 @@ void ReportsBase::WriteSymbolSummaryReport(
> > void ReportsBase::WriteSummaryReport(
> > // Calculate coverage statistics and output results.
> > uint32_t a;
> > - Coverage::DesiredSymbols::symbolSet_t::iterator itr;
> > uint32_t notExecuted = 0;
> > double percentage;
> > double percentageBranches;
> > @@ -460,22 +473,23 @@ void ReportsBase::WriteSummaryReport(
> > FILE* report;
> > // Open the report file.
> > - report = OpenFile( fileName );
> > + report = OpenFile( fileName, symbolSetName );
> > if ( !report ) {
> > return;
> > - for (itr = SymbolsToAnalyze->set.begin();
> > - itr != SymbolsToAnalyze->set.end();
> > - itr++) {
> SymbolsToAnalyze->getSymbolsForSet(symbolSetName);
> > + SymbolInformation info = SymbolsToAnalyze->allSymbols().at(symbol);
> > // If the symbol's unified coverage map exists, scan through it
> > // and count bytes.
> > - theCoverageMap = itr->second.unifiedCoverageMap;
> > - endAddress = itr->second.stats.sizeInBytes - 1;
> > for (a = 0; a <= endAddress; a++) {
> > totalBytes++;
> > @@ -490,11 +504,12 @@ void ReportsBase::WriteSummaryReport(
> > percentage *= 100.0;
> > percentageBranches = (double) (
> > - SymbolsToAnalyze->getNumberBranchesAlwaysTaken() +
> > - SymbolsToAnalyze->getNumberBranchesNeverTaken() +
> > - (SymbolsToAnalyze->getNumberBranchesNotExecuted() * 2)
> > + SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
> > + SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName) +
> > + (SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) *
> 2)
> > - percentageBranches /= (double)
> SymbolsToAnalyze->getNumberBranchesFound() * 2;
> > + percentageBranches /=
> > + (double) SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) *
> 2;
> > percentageBranches *= 100.0;
> > fprintf( report, "Bytes Analyzed : %d\n",
> totalBytes );
> > @@ -504,48 +519,48 @@ void ReportsBase::WriteSummaryReport(
> > fprintf(
> > report,
> > "Unreferenced Symbols : %d\n",
> > - SymbolsToAnalyze->getNumberUnreferencedSymbols()
> > + SymbolsToAnalyze->getNumberUnreferencedSymbols(symbolSetName)
> > fprintf(
> > report,
> > "Uncovered ranges found : %d\n\n",
> > - SymbolsToAnalyze->getNumberUncoveredRanges()
> > + SymbolsToAnalyze->getNumberUncoveredRanges(symbolSetName)
> > + if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) == 0) ||
> > (BranchInfoAvailable == false) ) {
> > fprintf( report, "No branch information available\n" );
> > } else {
> > fprintf(
> > report,
> > "Total conditional branches found : %d\n",
> > - SymbolsToAnalyze->getNumberBranchesFound()
> > + SymbolsToAnalyze->getNumberBranchesFound(symbolSetName)
> > fprintf(
> > report,
> > "Total branch paths found : %d\n",
> > - SymbolsToAnalyze->getNumberBranchesFound() * 2
> > + SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2
> > fprintf(
> > report,
> > "Uncovered branch paths found : %d\n",
> 2)
> > fprintf(
> > report,
> > " %d branches always taken\n",
> > fprintf(
> > report,
> > " %d branches never taken\n",
> > fprintf(
> > report,
> > " %d branch paths not executed\n",
> > - SymbolsToAnalyze->getNumberBranchesNotExecuted() * 2
> > + SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2
> > fprintf(
> > report,
> > @@ -555,7 +570,7 @@ void ReportsBase::WriteSummaryReport(
> > -void GenerateReports()
> > +void GenerateReports(const std::string& symbolSetName)
> > typedef std::list<ReportsBase *> reportList_t;
> > @@ -568,9 +583,9 @@ void GenerateReports()
> > timestamp = time(NULL); /* get current cal time */
> > - reports = new ReportsText(timestamp);
> > + reports = new ReportsText(timestamp, symbolSetName);
> > reportList.push_back(reports);
> > - reports = new ReportsHtml(timestamp);
> > + reports = new ReportsHtml(timestamp, symbolSetName);
> > for (ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
> > @@ -624,7 +639,7 @@ void GenerateReports()
> > delete reports;
> > - ReportsBase::WriteSummaryReport( "summary.txt" );
> > + ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName.c_str()
> > diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
> > index 7e28fd8..e7b1fb3 100644
> > --- a/tester/covoar/ReportsBase.h
> > +++ b/tester/covoar/ReportsBase.h
> > @@ -24,7 +24,7 @@ namespace Coverage {
> > class ReportsBase {
> > public:
> > - ReportsBase( time_t timestamp );
> > + ReportsBase( time_t timestamp, std::string symbolSetName );
> > virtual ~ReportsBase();
> > @@ -90,7 +90,8 @@ class ReportsBase {
> > * This method produces a sumary report for the overall test run.
> > static void WriteSummaryReport(
> > @@ -118,6 +119,11 @@ class ReportsBase {
> > std::string reportExtension_m;
> > + * This member variable contains the name of the symbol set for
> the report.
> > + std::string symbolSetName_m;
> > * This member variable contains the timestamp for the report.
> > @@ -128,9 +134,11 @@ class ReportsBase {
> > * correctly. Upon failure NULL is returned.
> > * @param[in] fileName identifies the report file name
> > + * @param[in] symbolSetName identifies the name of the report's
> symbol set
> > static FILE* OpenFile(
> > @@ -318,13 +326,15 @@ class ReportsBase {
> > * @param[in] report identifies the report file name
> > * @param[in] number identifies the line number.
> > - * @param[in] symbolPtr is a pointer to the symbol information
> > + * @param[in] symbolName is the symbol's name.
> > + * @param[in] symbolInfo is the symbol's information.
> > * @param[in] rangePtr is a pointer to the range information.
> > virtual bool PutBranchEntry(
> > FILE* report,
> > unsigned int number,
> > - Coverage::DesiredSymbols::symbolSet_t::iterator symbolPtr,
> > + const std::string& symbolName,
> > + const SymbolInformation& symbolInfo,
> > Coverage::CoverageRanges::ranges_t::iterator rangePtr
> > )=0;
> > @@ -348,13 +358,15 @@ class ReportsBase {
> > - * @param[in] ditr is a iterator to the symbol information
> > * @param[in] ritr is a iterator to the range information.
> > virtual bool PutCoverageLine(
> > FILE* report,
> > - Coverage::DesiredSymbols::symbolSet_t::iterator ditr,
> > )=0;
> > @@ -363,13 +375,13 @@ class ReportsBase {
> > * @param[in] report identifies the size report file name
> > - * @param[in] symbol is a pointer to the symbol information
> > * @param[in] range is a iterator to the range information.
> > virtual bool PutSizeLine(
> > FILE* report,
> > - Coverage::DesiredSymbols::symbolSet_t::iterator symbol,
> > )=0;
> > @@ -378,20 +390,24 @@ class ReportsBase {
> > virtual bool PutSymbolSummaryLine(
> > FILE* report,
> > )=0;
> > * This method iterates over all report set types and generates
> > * all reports.
> > + * @param[in] symbolSetName is the name of the symbol set to report on.
> > -void GenerateReports();
> > +void GenerateReports(const std::string& symbolSetName);
> > diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
> > index 6406a48..7137016 100644
> > --- a/tester/covoar/ReportsHtml.cc
> > +++ b/tester/covoar/ReportsHtml.cc
> > @@ -31,8 +31,8 @@
> > - ReportsHtml::ReportsHtml( time_t timestamp ):
> > - ReportsBase( timestamp )
> > + ReportsHtml::ReportsHtml( time_t timestamp, std::string symbolSetName
> > + ReportsBase( timestamp, symbolSetName )
> > reportExtension_m = ".html";
> > @@ -113,7 +113,7 @@ namespace Coverage {
> > FILE* aFile;
> > // Open the file
> > - aFile = ReportsBase::OpenFile( fileName );
> > + aFile = ReportsBase::OpenFile( fileName, symbolSetName_m.c_str() );
> > // Put Header information on the file
> > fprintf(
> > @@ -488,7 +488,8 @@ namespace Coverage {
> > FILE* report
> > - if (BranchInfoAvailable &&
> > + if (BranchInfoAvailable &&
> > + SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0)
> > fprintf( report, "All branch paths taken.\n" );
> > else
> > fprintf( report, "No branch information found.\n" );
> > @@ -498,7 +499,8 @@ namespace Coverage {
> > bool ReportsHtml::PutBranchEntry(
> > FILE* report,
> > unsigned int count,
> > @@ -519,7 +521,7 @@ namespace Coverage {
> > fprintf(
> > report,
> > "<td class=\"covoar-td\" align=\"center\">%s</td>\n",
> > - symbolPtr->first.c_str()
> > + symbolName.c_str()
> > // line
> > @@ -562,8 +564,8 @@ namespace Coverage {
> > // Taken / Not taken counts
> > lowAddress = rangePtr->lowAddress;
> > - bAddress = symbolPtr->second.baseAddress;
> > - theCoverageMap = symbolPtr->second.unifiedCoverageMap;
> > + bAddress = symbolInfo.baseAddress;
> > + theCoverageMap = symbolInfo.unifiedCoverageMap;
> > fprintf(
> > report,
> > "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
> > @@ -703,7 +705,8 @@ namespace Coverage {
> > bool ReportsHtml::PutCoverageLine(
> > FILE* report,
> > unsigned int count,
> > @@ -721,7 +724,7 @@ namespace Coverage {
> > fprintf(
> > report,
> > // Range
> > @@ -790,7 +793,7 @@ namespace Coverage {
> > bool ReportsHtml::PutSizeLine(
> > FILE* report,
> > unsigned int count,
> > @@ -814,7 +817,7 @@ namespace Coverage {
> > fprintf(
> > report,
> > - symbol->first.c_str()
> > // line
> > @@ -842,7 +845,8 @@ namespace Coverage {
> > bool ReportsHtml::PutSymbolSummaryLine(
> > FILE* report,
> > unsigned int count,
> > @@ -856,10 +860,10 @@ namespace Coverage {
> > fprintf(
> > report,
> > - if (symbol->second.stats.sizeInBytes == 0) {
> > + if (symbolInfo.stats.sizeInBytes == 0) {
> > // The symbol has never been seen. Write "unknown" for all
> columns.
> > fprintf(
> > report,
> > @@ -879,60 +883,60 @@ namespace Coverage {
> > fprintf(
> > report,
> > - symbol->second.stats.sizeInBytes
> > + symbolInfo.stats.sizeInBytes
> > // Total Size in Instructions
> > fprintf(
> > report,
> > - symbol->second.stats.sizeInInstructions
> > + symbolInfo.stats.sizeInInstructions
> > // Total Uncovered Ranges
> > fprintf(
> > report,
> > - symbol->second.stats.uncoveredRanges
> > + symbolInfo.stats.uncoveredRanges
> > // Uncovered Size in Bytes
> > fprintf(
> > report,
> > - symbol->second.stats.uncoveredBytes
> > + symbolInfo.stats.uncoveredBytes
> > // Uncovered Size in Instructions
> > fprintf(
> > report,
> > - symbol->second.stats.uncoveredInstructions
> > + symbolInfo.stats.uncoveredInstructions
> > // Total number of branches
> > fprintf(
> > report,
> > - symbol->second.stats.branchesNotExecuted +
> symbol->second.stats.branchesExecuted
> > + symbolInfo.stats.branchesNotExecuted +
> symbolInfo.stats.branchesExecuted
> > // Total Always Taken
> > fprintf(
> > report,
> > - symbol->second.stats.branchesAlwaysTaken
> > + symbolInfo.stats.branchesAlwaysTaken
> > // Total Never Taken
> > fprintf(
> > report,
> > - symbol->second.stats.branchesNeverTaken
> > + symbolInfo.stats.branchesNeverTaken
> > // % Uncovered Instructions
> > - if ( symbol->second.stats.sizeInInstructions == 0 )
> > + if ( symbolInfo.stats.sizeInInstructions == 0 )
> > fprintf(
> > report,
> > "<td class=\"covoar-td\" align=\"center\">100.00</td>\n"
> > @@ -941,12 +945,12 @@ namespace Coverage {
> > fprintf(
> > report,
> > "<td class=\"covoar-td\" align=\"center\">%.2f</td>\n",
> > - (symbol->second.stats.uncoveredInstructions*100.0)/
> > + (symbolInfo.stats.uncoveredInstructions*100.0)/
> > // % Uncovered Bytes
> > - if ( symbol->second.stats.sizeInBytes == 0 )
> > + if ( symbolInfo.stats.sizeInBytes == 0 )
> > fprintf(
> > report,
> > @@ -955,8 +959,8 @@ namespace Coverage {
> > fprintf(
> > report,
> > - (symbol->second.stats.uncoveredBytes*100.0)/
> > + (symbolInfo.stats.uncoveredBytes*100.0)/
> > diff --git a/tester/covoar/ReportsHtml.h b/tester/covoar/ReportsHtml.h
> > index 34193da..7972ce1 100644
> > --- a/tester/covoar/ReportsHtml.h
> > +++ b/tester/covoar/ReportsHtml.h
> > @@ -22,7 +22,7 @@ namespace Coverage {
> > class ReportsHtml: public ReportsBase {
> > public:
> > - ReportsHtml( time_t timestamp );
> > + ReportsHtml( time_t timestamp, std::string symbolSetName );
> > ~ReportsHtml();
> > @@ -163,7 +163,8 @@ class ReportsHtml: public ReportsBase {
> > FILE* report,
> > @@ -179,7 +180,8 @@ class ReportsHtml: public ReportsBase {
> > FILE* report,
> > @@ -187,7 +189,7 @@ class ReportsHtml: public ReportsBase {
> > FILE* report,
> > @@ -195,7 +197,8 @@ class ReportsHtml: public ReportsBase {
> > FILE* report,
> > /* Inherit documentation from base class. */
> > diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
> > index a3923e6..f552cdd 100644
> > --- a/tester/covoar/ReportsText.cc
> > +++ b/tester/covoar/ReportsText.cc
> > @@ -11,8 +11,8 @@
> > -ReportsText::ReportsText( time_t timestamp ):
> > +ReportsText::ReportsText( time_t timestamp, std::string symbolSetName ):
> > reportExtension_m = ".txt";
> > @@ -52,7 +52,8 @@ bool ReportsText::PutNoBranchInfo(
> > FILE* report
> > - if ( BranchInfoAvailable &&
> SymbolsToAnalyze->getNumberBranchesFound() != 0 )
> > + if ( BranchInfoAvailable &&
> > + SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0 )
> > else
> > @@ -61,9 +62,10 @@ bool ReportsText::PutNoBranchInfo(
> > bool ReportsText::PutBranchEntry(
> > - FILE* report,
> > + FILE* report,
> > @@ -76,8 +78,8 @@ bool ReportsText::PutBranchEntry(
> > "Symbol : %s (0x%x)\n"
> > "Line : %s (0x%x)\n"
> > "Size in Bytes : %d\n",
> > - symbolPtr->first.c_str(),
> > - symbolPtr->second.baseAddress,
> > + symbolName.c_str(),
> > + symbolInfo.baseAddress,
> > rangePtr->lowSourceLine.c_str(),
> > rangePtr->lowAddress,
> > rangePtr->highAddress - rangePtr->lowAddress + 1
> > @@ -153,9 +155,10 @@ void ReportsText::putCoverageNoRange(
> > bool ReportsText::PutCoverageLine(
> > - FILE* report,
> > - unsigned int number,
> > + FILE* report,
> > + unsigned int number,
> > @@ -171,8 +174,8 @@ bool ReportsText::PutCoverageLine(
> > "Size in Instructions : %d\n\n",
> > ritr->id,
> > - ditr->first.c_str(),
> > - ditr->second.baseAddress,
> > ritr->lowSourceLine.c_str(),
> > ritr->lowAddress,
> > ritr->highSourceLine.c_str(),
> > @@ -210,9 +213,9 @@ bool ReportsText::PutCoverageLine(
> > bool ReportsText::PutSizeLine(
> > - FILE* report,
> > + FILE* report,
> > @@ -220,7 +223,7 @@ bool ReportsText::PutSizeLine(
> > report,
> > "%d\t%s\t%s\n",
> > range->highAddress - range->lowAddress + 1,
> > - symbol->first.c_str(),
> > range->lowSourceLine.c_str()
> > return true;
> > @@ -229,13 +232,14 @@ bool ReportsText::PutSizeLine(
> > bool ReportsText::PutSymbolSummaryLine(
> > FILE* report,
> > float uncoveredBytes;
> > float uncoveredInstructions;
> > fprintf(
> > report,
> > "============================================\n"
> > @@ -245,20 +249,20 @@ bool ReportsText::PutSymbolSummaryLine(
> > "Therefore there is no size or disassembly for this symbol.\n"
> > "This could be due to symbol misspelling or lack of a test for\n"
> > "this symbol.\n",
> > } else {
> > uncoveredInstructions = 0;
> > else
> > - uncoveredInstructions =
> > - symbol->second.stats.sizeInInstructions;
> > + uncoveredInstructions =
> > + symbolInfo.stats.sizeInInstructions;
> > uncoveredBytes = 0;
> > else
> > - uncoveredBytes = (symbol->second.stats.uncoveredBytes*100.0)/
> > - symbol->second.stats.sizeInBytes;
> > + uncoveredBytes = (symbolInfo.stats.uncoveredBytes*100.0)/
> > + symbolInfo.stats.sizeInBytes;
> > fprintf(
> > report,
> > @@ -271,12 +275,12 @@ bool ReportsText::PutSymbolSummaryLine(
> > "Total Never Taken : %d\n"
> > "Percentage Uncovered Instructions : %.2f\n"
> > "Percentage Uncovered Bytes : %.2f\n",
> > - symbol->second.stats.sizeInBytes,
> > - symbol->second.stats.sizeInInstructions,
> symbol->second.stats.branchesExecuted,
> > - symbol->second.stats.branchesAlwaysTaken,
> > - symbol->second.stats.branchesNeverTaken,
> > + symbolInfo.stats.sizeInBytes,
> > + symbolInfo.stats.sizeInInstructions,
> symbolInfo.stats.branchesExecuted,
> > + symbolInfo.stats.branchesAlwaysTaken,
> > + symbolInfo.stats.branchesNeverTaken,
> > uncoveredInstructions,
> > uncoveredBytes
> > diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
> > index 9ae87d4..cf8a813 100644
> > --- a/tester/covoar/ReportsText.h
> > +++ b/tester/covoar/ReportsText.h
> > @@ -21,7 +21,7 @@ namespace Coverage {
> > class ReportsText: public ReportsBase {
> > public:
> > - ReportsText( time_t timestamp );
> > + ReportsText( time_t timestamp, std::string symbolSetName );
> > virtual ~ReportsText();
> > @@ -83,7 +83,8 @@ class ReportsText: public ReportsBase {
> > FILE* report,
> > @@ -99,7 +100,8 @@ class ReportsText: public ReportsBase {
> > FILE* report,
> > @@ -107,7 +109,7 @@ class ReportsText: public ReportsBase {
> > FILE* report,
> > @@ -115,7 +117,8 @@ class ReportsText: public ReportsBase {
> > FILE* report,
> > diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
> > index 84d883a..8d63132 100644
> > --- a/tester/covoar/covoar.cc
> > +++ b/tester/covoar/covoar.cc
> > @@ -350,7 +350,7 @@ int covoar(
> > throw rld::error( "executables and coverage name size mismatch",
> "covoar" );
> > if ( Verbose )
> > - std::cerr << "Analyzing " << SymbolsToAnalyze->set.size()
> > + std::cerr << "Analyzing " << SymbolsToAnalyze->allSymbols().size()
> > << " symbols" << std::endl;
> > // Create explanations.
> > @@ -473,7 +473,9 @@ int covoar(
> > if (Verbose)
> > std::cerr << "Generate Reports" << std::endl;
> > - Coverage::GenerateReports();
> > + for (const auto& setName : SymbolsToAnalyze->getSetNames()) {
> > + Coverage::GenerateReports(setName);
> > // Write explanations that were not found.
> > if ( explanations ) {
> > 2.27.0
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210406/d30877ee/attachment-0001.html>
