[PATCH 1/2] covoar: Split symbols by symbol set
Gedare Bloom
gedare at rtems.org
Tue Apr 6 15:56:29 UTC 2021
looks ok, it's a lot to try to process though.
In a future patch it would be good to provide more useful names, I
don't know what 'ha' and 'la' mean, if anything. at least 'a' I
understand to be an address.
Also, the typedef with appending _t at the end should be removed, _t
is reserved by POSIX.
And I don't know why the _m is being appended, I guess it is denoted
member variables? I'm used to seeing it as a prefix rather than a
suffix, if it gets used at all. A few more C++ issues to add to the
backlog.
On Mon, Apr 5, 2021 at 1:25 PM Alex White <alex.white at oarcorp.com> wrote:
> This changes the way covoar organizes the symbols. Instead of treating
> all symbols as one set, covoar is now aware of multiple symbol sets and
> tracks statistics for each set. It now also generates reports for each
> symbol set.
> This change relieves the caller of covoar of the reponsibility of
> managing the symbol sets. As a result, covoar can minimize the work
> done for each symbol set, yielding a significant speedup.
> Updates #4374
> tester/covoar/DesiredSymbols.cc | 465 +++++++++++++++++---------------
> tester/covoar/DesiredSymbols.h | 98 +++++--
> tester/covoar/ReportsBase.cc | 181 +++++++------
> tester/covoar/ReportsBase.h | 40 ++-
> tester/covoar/ReportsHtml.cc | 62 +++--
> tester/covoar/ReportsHtml.h | 13 +-
> tester/covoar/ReportsText.cc | 66 ++---
> tester/covoar/ReportsText.h | 13 +-
> tester/covoar/covoar.cc | 6 +-
> 9 files changed, 542 insertions(+), 402 deletions(-)
> diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
> index ffc4f86..2866dbe 100644
> --- a/tester/covoar/DesiredSymbols.cc
> +++ b/tester/covoar/DesiredSymbols.cc
> @@ -37,6 +37,11 @@ namespace Coverage {
> + const DesiredSymbols::symbolSet_t& DesiredSymbols::allSymbols() const
> + return set;
> void DesiredSymbols::load(
> const std::string& symbolsSet,
> const std::string& buildTarget,
> @@ -44,8 +49,6 @@ namespace Coverage {
> bool verbose
> - rld::files::cache cache;
> // Load the INI file looking for a top level:
> @@ -60,61 +63,61 @@ namespace Coverage {
> // [B]
> // libraries = @BUILD-PREFIX@/c/@BSP@/B/libB.a
> - try {
> - cache.open();
> + rld::config::config config;
> - rld::config::config config;
> + if (verbose)
> + std::cerr << "Loading symbol sets: " << symbolsSet << std::endl;
> - if (verbose)
> - std::cerr << "Loading symbol sets: " << symbolsSet << std::endl;
> + config.load (symbolsSet);
> - config.load (symbolsSet);
> + const rld::config::section& sym_section = config.get_section("symbol-sets");
> - const rld::config::section& sym_section = config.get_section("symbol-sets");
> + rld::strings sets;
> + rld::config::parse_items (sym_section, "sets", sets, true);
> - rld::strings sets;
> - rld::config::parse_items (sym_section, "sets", sets, true);
> + // Load the symbols for each set specified in the config file.
> + for (const auto& setName : sets) {
> + rld::files::cache cache;
> + cache.open();
> - for (const std::string set : sets) {
> + if (verbose)
> + std::cerr << "Loading symbols for set: " << setName << std::endl;
> + const rld::config::section& set_section = config.get_section(setName);
> + rld::strings libs;
> + rld::config::parse_items (set_section, "libraries", libs, true);
> + for (std::string lib : libs) {
> + lib = rld::find_replace(lib, "@BUILD-TARGET@", buildTarget);
> + lib = rld::find_replace(lib, "@BSP@", buildBSP);
> if (verbose)
> - std::cerr << " Symbol set: " << set << std::endl;
> - const rld::config::section& set_section = config.get_section(set);
> - rld::strings libs;
> - rld::config::parse_items (set_section, "libraries", libs, true);
> - for (std::string lib : libs) {
> - lib = rld::find_replace(lib, "@BUILD-TARGET@", buildTarget);
> - lib = rld::find_replace(lib, "@BSP@", buildBSP);
> - if (verbose)
> - std::cerr << " Loading library: " << lib << std::endl;
> - cache.add(lib);
> + std::cerr << " Loading library: " << lib << std::endl;
> + cache.add(lib);
> rld::symbols::table symbols;
> cache.load_symbols (symbols, true);
> + // Populate the symbol maps with all global symbols.
> for (auto& kv : symbols.globals()) {
> const rld::symbols::symbol& sym = *(kv.second);
> - if (sym.type() == sym.st_func)
> + if (sym.type() == sym.st_func) {
> set[sym.name()] = *(new SymbolInformation);
> + setNamesToSymbols[setName].push_back(sym.name());
> + // Populate the symbol maps with all weak symbols.
> for (auto& kv : symbols.weaks()) {
> - } catch (...) {
> - cache.close();
> - throw;
> - cache.close();
> void DesiredSymbols::preprocess( void )
> // Look at each symbol.
> for (auto& s : SymbolsToAnalyze->set) {
> // If the unified coverage map does not exist, the symbol was
> @@ -135,48 +138,52 @@ namespace Coverage {
> void DesiredSymbols::calculateStatistics( void )
> - // Look at each symbol.
> - for (auto& s : SymbolsToAnalyze->set) {
> - // If the unified coverage map does not exist, the symbol was
> - // never referenced by any executable. Just skip it.
> - CoverageMapBase* theCoverageMap = s.second.unifiedCoverageMap;
> - if (theCoverageMap)
> - // Increment the total sizeInBytes by the bytes in the symbol
> - stats.sizeInBytes += s.second.stats.sizeInBytes;
> - // Now scan through the coverage map of this symbol.
> - uint32_t endAddress = s.second.stats.sizeInBytes - 1;
> - for (uint32_t a = 0; a <= endAddress; ++a) {
> - // If we are at the start of instruction increment
> - // instruction type counters as needed.
> - if ( theCoverageMap->isStartOfInstruction( a ) ) {
> - stats.sizeInInstructions++;
> - s.second.stats.sizeInInstructions++;
> - if (!theCoverageMap->wasExecuted( a ) ) {
> - stats.uncoveredInstructions++;
> - s.second.stats.uncoveredInstructions++;
> - if ( theCoverageMap->isBranch( a )) {
> - stats.branchesNotExecuted++;
> - s.second.stats.branchesNotExecuted++;
> + // Look at each symbol set.
> + for (const auto& kv : setNamesToSymbols) {
> + // Look at each symbol.
> + for (const auto& symbol : kv.second) {
> + SymbolInformation& info = set.at(symbol);
> + // If the unified coverage map does not exist, the symbol was
> + // never referenced by any executable. Just skip it.
> + CoverageMapBase* theCoverageMap = info.unifiedCoverageMap;
> + if (theCoverageMap) {
> + // Increment the total sizeInBytes by the bytes in the symbol
> + stats[kv.first].sizeInBytes += info.stats.sizeInBytes;
> + // Now scan through the coverage map of this symbol.
> + uint32_t endAddress = info.stats.sizeInBytes - 1;
> + for (uint32_t a = 0; a <= endAddress; ++a) {
> + // If we are at the start of instruction increment
> + // instruction type counters as needed.
> + if ( theCoverageMap->isStartOfInstruction( a ) ) {
> + stats[kv.first].sizeInInstructions++;
> + info.stats.sizeInInstructions++;
> + if (!theCoverageMap->wasExecuted( a ) ) {
> + stats[kv.first].uncoveredInstructions++;
> + info.stats.uncoveredInstructions++;
> + if ( theCoverageMap->isBranch( a )) {
> + stats[kv.first].branchesNotExecuted++;
> + info.stats.branchesNotExecuted++;
> + } else if (theCoverageMap->isBranch( a )) {
> + stats[kv.first].branchesExecuted++;
> + info.stats.branchesExecuted++;
> - } else if (theCoverageMap->isBranch( a )) {
> - stats.branchesExecuted++;
> - s.second.stats.branchesExecuted++;
> - if (!theCoverageMap->wasExecuted( a )) {
> - stats.uncoveredBytes++;
> - s.second.stats.uncoveredBytes++;
> + if (!theCoverageMap->wasExecuted( a )) {
> + stats[kv.first].uncoveredBytes++;
> + info.stats.uncoveredBytes++;
> + } else {
> + stats[kv.first].unreferencedSymbols++;
> - } else {
> - stats.unreferencedSymbols++;
> @@ -184,152 +191,155 @@ namespace Coverage {
> void DesiredSymbols::computeUncovered( void )
> - // Create containers for the symbol's uncovered ranges and branches.
> - CoverageRanges* theRanges = new CoverageRanges();
> - s.second.uncoveredRanges = theRanges;
> - CoverageRanges* theBranches = new CoverageRanges();
> - s.second.uncoveredBranches = theBranches;
> - uint32_t a;
> - uint32_t la;
> - uint32_t ha;
> - uint32_t endAddress;
> - uint32_t count;
> - // Mark NOPs as executed
> - a = s.second.stats.sizeInBytes - 1;
> - count = 0;
> - while (a > 0) {
> - if (theCoverageMap->isStartOfInstruction( a )) {
> - break;
> - count++;
> - if (theCoverageMap->isNop( a )) {
> - for (la = a; la < (a + count); la++) {
> - theCoverageMap->setWasExecuted( la );
> + // Create containers for the symbol's uncovered ranges and branches.
> + CoverageRanges* theRanges = new CoverageRanges();
> + info.uncoveredRanges = theRanges;
> + CoverageRanges* theBranches = new CoverageRanges();
> + info.uncoveredBranches = theBranches;
> + uint32_t a;
> + uint32_t la;
> + uint32_t ha;
> + uint32_t endAddress;
> + uint32_t count;
> + // Mark NOPs as executed
> + a = info.stats.sizeInBytes - 1;
> + count = 0;
> + while (a > 0) {
> + if (theCoverageMap->isStartOfInstruction( a )) {
> + break;
> - count = 0;
> + count++;
> - a--;
> + if (theCoverageMap->isNop( a )) {
> + for (la = a; la < (a + count); la++) {
> + theCoverageMap->setWasExecuted( la );
> - endAddress = s.second.stats.sizeInBytes - 1;
> - a = 0;
> - while (a < endAddress) {
> - a++;
> - continue;
> + count = 0;
> - for (ha=a+1;
> - ha <= endAddress && !theCoverageMap->isStartOfInstruction( ha );
> - ha++)
> - if ( ha >= endAddress )
> - break;
> - if (theCoverageMap->isNop( ha ))
> - do {
> - theCoverageMap->setWasExecuted( ha );
> - ha++;
> - break;
> - } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
> - theCoverageMap->isNop( ha ) );
> - a = ha;
> + a--;
> - endAddress = s.second.stats.sizeInBytesWithoutNops - 1;
> - a = 0;
> - while (a <= endAddress) {
> - // If an address was NOT executed, find consecutive unexecuted
> - // addresses and add them to the uncovered ranges.
> - la = a;
> - count = 1;
> - for (ha = a + 1;
> - ha <= endAddress && !theCoverageMap->wasExecuted( ha );
> - ha++)
> - if ( theCoverageMap->isStartOfInstruction( ha ) )
> - count++;
> + endAddress = info.stats.sizeInBytes - 1;
> + a = 0;
> + while (a < endAddress) {
> + a++;
> + continue;
> - ha--;
> - stats.uncoveredRanges++;
> - s.second.stats.uncoveredRanges++;
> - theRanges->add(
> - s.second.baseAddress + la,
> - s.second.baseAddress + ha,
> - CoverageRanges::UNCOVERED_REASON_NOT_EXECUTED,
> - count
> - a = ha + 1;
> - // If an address is a branch instruction, add any uncovered branches
> - // to the uncoverd branches.
> - else if (theCoverageMap->isBranch( a )) {
> - la = a;
> - for (ha = a + 1;
> - ha++)
> + for (ha=a+1;
> + ha <= endAddress && !theCoverageMap->isStartOfInstruction( ha );
> + ha++)
> - ha--;
> - if (theCoverageMap->wasAlwaysTaken( la )) {
> - stats.branchesAlwaysTaken++;
> - s.second.stats.branchesAlwaysTaken++;
> - theBranches->add(
> - CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN,
> - 1
> + if ( ha >= endAddress )
> + break;
> + if (theCoverageMap->isNop( ha ))
> + do {
> + theCoverageMap->setWasExecuted( ha );
> + ha++;
> + break;
> + } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
> + theCoverageMap->isNop( ha ) );
> + a = ha;
> + endAddress = info.stats.sizeInBytesWithoutNops - 1;
> + a = 0;
> + while (a <= endAddress) {
> + // If an address was NOT executed, find consecutive unexecuted
> + // addresses and add them to the uncovered ranges.
> + la = a;
> + count = 1;
> + for (ha = a + 1;
> + ha <= endAddress && !theCoverageMap->wasExecuted( ha );
> + ha++)
> + if ( theCoverageMap->isStartOfInstruction( ha ) )
> + count++;
> + ha--;
> + stats[kv.first].uncoveredRanges++;
> + info.stats.uncoveredRanges++;
> + theRanges->add(
> + info.baseAddress + la,
> + info.baseAddress + ha,
> + CoverageRanges::UNCOVERED_REASON_NOT_EXECUTED,
> + count
> - if (Verbose)
> - std::cerr << "Branch always taken found in" << s.first
> - << std::hex
> - << " (0x" << s.second.baseAddress + la
> - << " - 0x" << s.second.baseAddress + ha
> - << std::dec
> - << std::endl;
> + a = ha + 1;
> - else if (theCoverageMap->wasNeverTaken( la )) {
> - stats.branchesNeverTaken++;
> - s.second.stats.branchesNeverTaken++;
> - theBranches->add(
> - CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN,
> - 1
> + // If an address is a branch instruction, add any uncovered branches
> + // to the uncoverd branches.
> + else if (theCoverageMap->isBranch( a )) {
> + la = a;
> + for (ha = a + 1;
> + ha++)
> + ha--;
> + if (theCoverageMap->wasAlwaysTaken( la )) {
> + stats[kv.first].branchesAlwaysTaken++;
> + info.stats.branchesAlwaysTaken++;
> + theBranches->add(
> + CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN,
> + 1
> - if (Verbose)
> - std::cerr << "Branch never taken found in " << s.first
> - << std::hex
> - << std::dec
> - << std::endl;
> + if (Verbose)
> + std::cerr << "Branch always taken found in" << symbol
> + << std::hex
> + << " (0x" << info.baseAddress + la
> + << " - 0x" << info.baseAddress + ha
> + << std::dec
> + << std::endl;
> + else if (theCoverageMap->wasNeverTaken( la )) {
> + stats[kv.first].branchesNeverTaken++;
> + info.stats.branchesNeverTaken++;
> + theBranches->add(
> + CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN,
> + 1
> + if (Verbose)
> + std::cerr << "Branch never taken found in " << symbol
> + << std::hex
> + << std::dec
> + << std::endl;
> + a = ha + 1;
> - a = ha + 1;
> + else
> + a++;
> - else
> - a++;
> @@ -460,30 +470,61 @@ namespace Coverage {
> - uint32_t DesiredSymbols::getNumberBranchesAlwaysTaken( void ) const {
> - return stats.branchesAlwaysTaken;
> + uint32_t DesiredSymbols::getNumberBranchesAlwaysTaken(
> + const std::string& symbolSetName
> + ) const {
> + return stats.at(symbolSetName).branchesAlwaysTaken;
> - uint32_t DesiredSymbols::getNumberBranchesFound( void ) const {
> - return (stats.branchesNotExecuted + stats.branchesExecuted);
> + uint32_t DesiredSymbols::getNumberBranchesFound(
> + ) const {
> + return (
> + stats.at(symbolSetName).branchesNotExecuted +
> + stats.at(symbolSetName).branchesExecuted
> - uint32_t DesiredSymbols::getNumberBranchesNeverTaken( void ) const {
> - return stats.branchesNeverTaken;
> + uint32_t DesiredSymbols::getNumberBranchesNeverTaken(
> + ) const {
> + return stats.at(symbolSetName).branchesNeverTaken;
> - uint32_t DesiredSymbols::getNumberBranchesNotExecuted( void ) const {
> - return stats.branchesNotExecuted;
> + uint32_t DesiredSymbols::getNumberBranchesNotExecuted(
> + ) const {
> + return stats.at(symbolSetName).branchesNotExecuted;
> - uint32_t DesiredSymbols::getNumberUncoveredRanges( void ) const {
> - return stats.uncoveredRanges;
> + uint32_t DesiredSymbols::getNumberUncoveredRanges(
> + ) const {
> + return stats.at(symbolSetName).uncoveredRanges;
> - uint32_t DesiredSymbols::getNumberUnreferencedSymbols( void ) const {
> - return stats.unreferencedSymbols;
> + uint32_t DesiredSymbols::getNumberUnreferencedSymbols(
> + ) const {
> + return stats.at(symbolSetName).unreferencedSymbols;
> + std::vector<std::string> DesiredSymbols::getSetNames( void ) const {
> + std::vector<std::string> setNames;
> + for (const auto &kv : setNamesToSymbols) {
> + setNames.push_back(kv.first);
> + return setNames;
> + const std::vector<std::string>& DesiredSymbols::getSymbolsForSet(
> + ) const
> + return setNamesToSymbols.at(symbolSetName);
> bool DesiredSymbols::isDesired (
> const std::string& symbolName
> ) const
> diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
> index 5cf96e9..5280d50 100644
> --- a/tester/covoar/DesiredSymbols.h
> +++ b/tester/covoar/DesiredSymbols.h
> @@ -197,12 +197,6 @@ namespace Coverage {
> typedef std::map<std::string, SymbolInformation> symbolSet_t;
> - * This variable contains a map of symbol sets for each
> - * symbol in the system keyed on the symbol name.
> - symbolSet_t set;
> * This method constructs a DesiredSymbols instance.
> @@ -213,6 +207,11 @@ namespace Coverage {
> ~DesiredSymbols();
> + * The set of all symbols.
> + const symbolSet_t& allSymbols() const;
> * This method loops through the coverage map and
> * calculates the statistics that have not already
> @@ -262,51 +261,93 @@ namespace Coverage {
> * This method returns the total number of branches always taken
> - * for all analyzed symbols.
> + * for all analyzed symbols in a given set.
> + * @param[in] symbolSetName specifies the symbol set of interest
> * @return Returns the total number of branches always taken
> - uint32_t getNumberBranchesAlwaysTaken( void ) const;
> + uint32_t getNumberBranchesAlwaysTaken(
> + ) const;
> * This method returns the total number of branches found for
> - * all analyzed symbols.
> + * all analyzed symbols in a given set.
> * @return Returns the total number of branches found
> - uint32_t getNumberBranchesFound( void ) const;
> + uint32_t getNumberBranchesFound(
> + ) const;
> * This method returns the total number of branches never taken
> * @return Returns the total number of branches never taken
> - uint32_t getNumberBranchesNeverTaken( void ) const;
> + uint32_t getNumberBranchesNeverTaken(
> + ) const;
> * This method returns the total number of branches not executed
> * @return Returns the total number of branches not executed
> - uint32_t getNumberBranchesNotExecuted( void ) const;
> + uint32_t getNumberBranchesNotExecuted(
> + ) const;
> * This method returns the total number of uncovered ranges
> * @return Returns the total number of uncovered ranges
> - uint32_t getNumberUncoveredRanges( void ) const;
> + uint32_t getNumberUncoveredRanges(
> + ) const;
> * This method returns the total number of unreferenced symbols
> * @return Returns the total number of unreferenced symbols
> - uint32_t getNumberUnreferencedSymbols( void ) const;
> + uint32_t getNumberUnreferencedSymbols(
> + ) const;
> + * This method returns all symbol set names.
> + * @return Returns all symbol set names
> + std::vector<std::string> getSetNames( void ) const;
> + * This method returns all symbols for a given set.
> + * @return Returns all symbols for the given set
> + const std::vector<std::string>& getSymbolsForSet(
> + ) const;
> * This method returns an indication of whether or not the specified
> @@ -353,11 +394,6 @@ namespace Coverage {
> void preprocess( void );
> - * This member contains the statistics kept on each symbol.
> - Statistics stats;
> private:
> @@ -369,6 +405,22 @@ namespace Coverage {
> ExecutableInfo* const theExecutable
> + * This variable contains a map of symbol sets for each
> + * symbol in the system keyed on the symbol name.
> + symbolSet_t set;
> + * This variable contains a map of symbol set names to symbol name lists.
> + std::map<std::string, std::vector<std::string>> setNamesToSymbols;
> + * This member contains a map of symbol set names to statistics.
> + std::map<std::string, Statistics> stats;
> diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
> index 40ed209..fea776c 100644
> --- a/tester/covoar/ReportsBase.cc
> +++ b/tester/covoar/ReportsBase.cc
> @@ -20,8 +20,9 @@
> -ReportsBase::ReportsBase( time_t timestamp ):
> +ReportsBase::ReportsBase( time_t timestamp, std::string symbolSetName ):
> reportExtension_m(""),
> + symbolSetName_m(symbolSetName),
> timestamp_m( timestamp )
> @@ -31,27 +32,38 @@ ReportsBase::~ReportsBase()
> FILE* ReportsBase::OpenFile(
> - const char* const fileName
> + const char* const fileName,
> + const char* const symbolSetName
> int sc;
> FILE *aFile;
> std::string file;
> + std::string symbolSetOutputDirectory;
> + rld::path::path_join(
> + outputDirectory,
> + symbolSetName,
> + symbolSetOutputDirectory
> // Create the output directory if it does not already exist
> #ifdef _WIN32
> - sc = _mkdir( outputDirectory );
> + sc = _mkdir( symbolSetOutputDirectory );
> #else
> - sc = mkdir( outputDirectory,0755 );
> + sc = mkdir( symbolSetOutputDirectory.c_str(),0755 );
> #endif
> if ( (sc == -1) && (errno != EEXIST) ) {
> - fprintf(stderr, "Unable to create output directory %s\n", outputDirectory);
> + fprintf(
> + stderr,
> + "Unable to create output directory %s\n",
> + symbolSetOutputDirectory.c_str()
> return NULL;
> - file = outputDirectory;
> - file += "/";
> - file += fileName;
> + file = symbolSetOutputDirectory;
> + rld::path::path_join(file, fileName, file);
> // Open the file.
> aFile = fopen( file.c_str(), "w" );
> @@ -71,7 +83,7 @@ FILE* ReportsBase::OpenAnnotatedFile(
> - return OpenFile(fileName);
> + return OpenFile(fileName, symbolSetName_m.c_str());
> FILE* ReportsBase::OpenBranchFile(
> @@ -79,21 +91,21 @@ FILE* ReportsBase::OpenBranchFile(
> bool hasBranches
> FILE* ReportsBase::OpenCoverageFile(
> FILE* ReportsBase::OpenNoRangeFile(
> @@ -101,14 +113,14 @@ FILE* ReportsBase::OpenSizeFile(
> FILE* ReportsBase::OpenSymbolSummaryFile(
> void ReportsBase::CloseFile(
> @@ -186,41 +198,42 @@ void ReportsBase::WriteAnnotatedReport(
> FILE* aFile = NULL;
> - Coverage::DesiredSymbols::symbolSet_t::iterator ditr;
> Coverage::CoverageRanges* theBranches;
> Coverage::CoverageRanges* theRanges;
> Coverage::CoverageMapBase* theCoverageMap = NULL;
> uint32_t bAddress = 0;
> AnnotatedLineState_t state;
> - std::list<Coverage::ObjdumpProcessor::objdumpLine_t>* theInstructions;
> - std::list<Coverage::ObjdumpProcessor::objdumpLine_t>::iterator itr;
> + const std::list<Coverage::ObjdumpProcessor::objdumpLine_t>* theInstructions;
> + std::list<
> + Coverage::ObjdumpProcessor::objdumpLine_t>::const_iterator itr;
> aFile = OpenAnnotatedFile(fileName);
> if (!aFile)
> return;
> // Process uncovered branches for each symbol.
> - for (ditr = SymbolsToAnalyze->set.begin();
> - ditr != SymbolsToAnalyze->set.end();
> - ditr++) {
> + const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName_m);
> + for (const auto& symbol : symbols) {
> + const SymbolInformation& info = SymbolsToAnalyze->allSymbols().at(symbol);
> // If uncoveredRanges and uncoveredBranches don't exist, then the
> // symbol was never referenced by any executable. Just skip it.
> - if ((ditr->second.uncoveredRanges == NULL) &&
> - (ditr->second.uncoveredBranches == NULL))
> + if ((info.uncoveredRanges == NULL) &&
> + (info.uncoveredBranches == NULL))
> continue;
> // If uncoveredRanges and uncoveredBranches are empty, then everything
> // must have been covered for this symbol. Just skip it.
> - if ((ditr->second.uncoveredRanges->set.empty()) &&
> - (ditr->second.uncoveredBranches->set.empty()))
> + if ((info.uncoveredRanges->set.empty()) &&
> + (info.uncoveredBranches->set.empty()))
> continue;
> - theCoverageMap = ditr->second.unifiedCoverageMap;
> - bAddress = ditr->second.baseAddress;
> - theInstructions = &(ditr->second.instructions);
> - theRanges = ditr->second.uncoveredRanges;
> - theBranches = ditr->second.uncoveredBranches;
> + theCoverageMap = info.unifiedCoverageMap;
> + bAddress = info.baseAddress;
> + theInstructions = &(info.instructions);
> + theRanges = info.uncoveredRanges;
> + theBranches = info.uncoveredBranches;
> // Add annotations to each line where necessary
> AnnotatedStart( aFile );
> @@ -274,14 +287,13 @@ void ReportsBase::WriteAnnotatedReport(
> void ReportsBase::WriteBranchReport(
> FILE* report = NULL;
> Coverage::CoverageRanges::ranges_t::iterator ritr;
> unsigned int count;
> bool hasBranches = true;
> - if ((SymbolsToAnalyze->getNumberBranchesFound() == 0) ||
> + if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) == 0) ||
> (BranchInfoAvailable == false) )
> hasBranches = false;
> @@ -291,15 +303,16 @@ void ReportsBase::WriteBranchReport(
> return;
> // If no branches were found then branch coverage is not supported
> - if ((SymbolsToAnalyze->getNumberBranchesFound() != 0) &&
> + if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0) &&
> (BranchInfoAvailable == true) ) {
> - // Process uncovered branches for each symbol.
> + // Process uncovered branches for each symbol in the set.
> count = 0;
> - ditr++) {
> if (theBranches && !theBranches->set.empty()) {
> @@ -307,7 +320,7 @@ void ReportsBase::WriteBranchReport(
> ritr != theBranches->set.end() ;
> ritr++ ) {
> count++;
> - PutBranchEntry( report, count, ditr, ritr );
> + PutBranchEntry( report, count, symbol, info, ritr );
> @@ -323,7 +336,6 @@ void ReportsBase::WriteCoverageReport(
> FILE* report;
> @@ -346,26 +358,27 @@ void ReportsBase::WriteCoverageReport(
> // Process uncovered ranges for each symbol.
> count = 0;
> - ditr++) {
> // If uncoveredRanges doesn't exist, then the symbol was never
> // referenced by any executable. There may be a problem with the
> // desired symbols list or with the executables so put something
> // in the report.
> if (theRanges == NULL) {
> - putCoverageNoRange( report, NoRangeFile, count, ditr->first );
> + putCoverageNoRange( report, NoRangeFile, count, symbol );
> count++;
> } else if (!theRanges->set.empty()) {
> for (ritr = theRanges->set.begin() ;
> ritr != theRanges->set.end() ;
> ritr++ ) {
> - PutCoverageLine( report, count, ditr, ritr );
> + PutCoverageLine( report, count, symbol, info, ritr );
> count++;
> @@ -383,7 +396,6 @@ void ReportsBase::WriteSizeReport(
> FILE* report;
> @@ -396,19 +408,20 @@ void ReportsBase::WriteSizeReport(
> count = 0;
> - ditr++) {
> if (theRanges && !theRanges->set.empty()) {
> ritr++ ) {
> - PutSizeLine( report, count, ditr, ritr );
> + PutSizeLine( report, count, symbol, ritr );
> count++;
> @@ -421,7 +434,6 @@ void ReportsBase::WriteSymbolSummaryReport(
> FILE* report;
> unsigned int count;
> @@ -432,12 +444,13 @@ void ReportsBase::WriteSymbolSummaryReport(
> // Process each symbol.
> count = 0;
> - ditr++) {
> - PutSymbolSummaryLine( report, count, ditr );
> + PutSymbolSummaryLine( report, count, symbol, info );
> count++;
> @@ -445,13 +458,13 @@ void ReportsBase::WriteSymbolSummaryReport(
> void ReportsBase::WriteSummaryReport(
> // Calculate coverage statistics and output results.
> uint32_t a;
> - Coverage::DesiredSymbols::symbolSet_t::iterator itr;
> uint32_t notExecuted = 0;
> double percentage;
> double percentageBranches;
> @@ -460,22 +473,23 @@ void ReportsBase::WriteSummaryReport(
> FILE* report;
> // Open the report file.
> - report = OpenFile( fileName );
> + report = OpenFile( fileName, symbolSetName );
> if ( !report ) {
> return;
> - for (itr = SymbolsToAnalyze->set.begin();
> - itr != SymbolsToAnalyze->set.end();
> - itr++) {
> + const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName);
> + SymbolInformation info = SymbolsToAnalyze->allSymbols().at(symbol);
> // If the symbol's unified coverage map exists, scan through it
> // and count bytes.
> - theCoverageMap = itr->second.unifiedCoverageMap;
> - endAddress = itr->second.stats.sizeInBytes - 1;
> for (a = 0; a <= endAddress; a++) {
> totalBytes++;
> @@ -490,11 +504,12 @@ void ReportsBase::WriteSummaryReport(
> percentage *= 100.0;
> percentageBranches = (double) (
> - SymbolsToAnalyze->getNumberBranchesAlwaysTaken() +
> - SymbolsToAnalyze->getNumberBranchesNeverTaken() +
> - (SymbolsToAnalyze->getNumberBranchesNotExecuted() * 2)
> + SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
> + SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName) +
> + (SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2)
> - percentageBranches /= (double) SymbolsToAnalyze->getNumberBranchesFound() * 2;
> + percentageBranches /=
> + (double) SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2;
> percentageBranches *= 100.0;
> fprintf( report, "Bytes Analyzed : %d\n", totalBytes );
> @@ -504,48 +519,48 @@ void ReportsBase::WriteSummaryReport(
> fprintf(
> report,
> "Unreferenced Symbols : %d\n",
> - SymbolsToAnalyze->getNumberUnreferencedSymbols()
> + SymbolsToAnalyze->getNumberUnreferencedSymbols(symbolSetName)
> fprintf(
> report,
> "Uncovered ranges found : %d\n\n",
> - SymbolsToAnalyze->getNumberUncoveredRanges()
> + SymbolsToAnalyze->getNumberUncoveredRanges(symbolSetName)
> + if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) == 0) ||
> (BranchInfoAvailable == false) ) {
> fprintf( report, "No branch information available\n" );
> } else {
> fprintf(
> report,
> "Total conditional branches found : %d\n",
> - SymbolsToAnalyze->getNumberBranchesFound()
> + SymbolsToAnalyze->getNumberBranchesFound(symbolSetName)
> fprintf(
> report,
> "Total branch paths found : %d\n",
> - SymbolsToAnalyze->getNumberBranchesFound() * 2
> + SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2
> fprintf(
> report,
> "Uncovered branch paths found : %d\n",
> fprintf(
> report,
> " %d branches always taken\n",
> fprintf(
> report,
> " %d branches never taken\n",
> fprintf(
> report,
> " %d branch paths not executed\n",
> - SymbolsToAnalyze->getNumberBranchesNotExecuted() * 2
> + SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2
> fprintf(
> report,
> @@ -555,7 +570,7 @@ void ReportsBase::WriteSummaryReport(
> -void GenerateReports()
> +void GenerateReports(const std::string& symbolSetName)
> typedef std::list<ReportsBase *> reportList_t;
> @@ -568,9 +583,9 @@ void GenerateReports()
> timestamp = time(NULL); /* get current cal time */
> - reports = new ReportsText(timestamp);
> + reports = new ReportsText(timestamp, symbolSetName);
> reportList.push_back(reports);
> - reports = new ReportsHtml(timestamp);
> + reports = new ReportsHtml(timestamp, symbolSetName);
> for (ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
> @@ -624,7 +639,7 @@ void GenerateReports()
> delete reports;
> - ReportsBase::WriteSummaryReport( "summary.txt" );
> + ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName.c_str() );
> diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
> index 7e28fd8..e7b1fb3 100644
> --- a/tester/covoar/ReportsBase.h
> +++ b/tester/covoar/ReportsBase.h
> @@ -24,7 +24,7 @@ namespace Coverage {
> class ReportsBase {
> public:
> - ReportsBase( time_t timestamp );
> + ReportsBase( time_t timestamp, std::string symbolSetName );
> virtual ~ReportsBase();
> @@ -90,7 +90,8 @@ class ReportsBase {
> * This method produces a sumary report for the overall test run.
> static void WriteSummaryReport(
> @@ -118,6 +119,11 @@ class ReportsBase {
> std::string reportExtension_m;
> + * This member variable contains the name of the symbol set for the report.
> + std::string symbolSetName_m;
> * This member variable contains the timestamp for the report.
> @@ -128,9 +134,11 @@ class ReportsBase {
> * correctly. Upon failure NULL is returned.
> * @param[in] fileName identifies the report file name
> + * @param[in] symbolSetName identifies the name of the report's symbol set
> static FILE* OpenFile(
> @@ -318,13 +326,15 @@ class ReportsBase {
> * @param[in] report identifies the report file name
> * @param[in] number identifies the line number.
> - * @param[in] symbolPtr is a pointer to the symbol information
> + * @param[in] symbolName is the symbol's name.
> + * @param[in] symbolInfo is the symbol's information.
> * @param[in] rangePtr is a pointer to the range information.
> virtual bool PutBranchEntry(
> FILE* report,
> unsigned int number,
> - Coverage::DesiredSymbols::symbolSet_t::iterator symbolPtr,
> + const std::string& symbolName,
> + const SymbolInformation& symbolInfo,
> Coverage::CoverageRanges::ranges_t::iterator rangePtr
> )=0;
> @@ -348,13 +358,15 @@ class ReportsBase {
> - * @param[in] ditr is a iterator to the symbol information
> * @param[in] ritr is a iterator to the range information.
> virtual bool PutCoverageLine(
> FILE* report,
> - Coverage::DesiredSymbols::symbolSet_t::iterator ditr,
> )=0;
> @@ -363,13 +375,13 @@ class ReportsBase {
> * @param[in] report identifies the size report file name
> - * @param[in] symbol is a pointer to the symbol information
> * @param[in] range is a iterator to the range information.
> virtual bool PutSizeLine(
> FILE* report,
> - Coverage::DesiredSymbols::symbolSet_t::iterator symbol,
> )=0;
> @@ -378,20 +390,24 @@ class ReportsBase {
> virtual bool PutSymbolSummaryLine(
> FILE* report,
> )=0;
> * This method iterates over all report set types and generates
> * all reports.
> + * @param[in] symbolSetName is the name of the symbol set to report on.
> -void GenerateReports();
> +void GenerateReports(const std::string& symbolSetName);
> diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
> index 6406a48..7137016 100644
> --- a/tester/covoar/ReportsHtml.cc
> +++ b/tester/covoar/ReportsHtml.cc
> @@ -31,8 +31,8 @@
> - ReportsHtml::ReportsHtml( time_t timestamp ):
> - ReportsBase( timestamp )
> + ReportsHtml::ReportsHtml( time_t timestamp, std::string symbolSetName ):
> + ReportsBase( timestamp, symbolSetName )
> reportExtension_m = ".html";
> @@ -113,7 +113,7 @@ namespace Coverage {
> FILE* aFile;
> // Open the file
> - aFile = ReportsBase::OpenFile( fileName );
> + aFile = ReportsBase::OpenFile( fileName, symbolSetName_m.c_str() );
> // Put Header information on the file
> fprintf(
> @@ -488,7 +488,8 @@ namespace Coverage {
> FILE* report
> - if (BranchInfoAvailable && SymbolsToAnalyze->getNumberBranchesFound() != 0)
> + if (BranchInfoAvailable &&
> + SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0)
> fprintf( report, "All branch paths taken.\n" );
> else
> fprintf( report, "No branch information found.\n" );
> @@ -498,7 +499,8 @@ namespace Coverage {
> bool ReportsHtml::PutBranchEntry(
> FILE* report,
> unsigned int count,
> @@ -519,7 +521,7 @@ namespace Coverage {
> fprintf(
> report,
> "<td class=\"covoar-td\" align=\"center\">%s</td>\n",
> - symbolPtr->first.c_str()
> + symbolName.c_str()
> // line
> @@ -562,8 +564,8 @@ namespace Coverage {
> // Taken / Not taken counts
> lowAddress = rangePtr->lowAddress;
> - bAddress = symbolPtr->second.baseAddress;
> - theCoverageMap = symbolPtr->second.unifiedCoverageMap;
> + bAddress = symbolInfo.baseAddress;
> + theCoverageMap = symbolInfo.unifiedCoverageMap;
> fprintf(
> report,
> "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
> @@ -703,7 +705,8 @@ namespace Coverage {
> bool ReportsHtml::PutCoverageLine(
> FILE* report,
> unsigned int count,
> @@ -721,7 +724,7 @@ namespace Coverage {
> fprintf(
> report,
> // Range
> @@ -790,7 +793,7 @@ namespace Coverage {
> bool ReportsHtml::PutSizeLine(
> FILE* report,
> unsigned int count,
> @@ -814,7 +817,7 @@ namespace Coverage {
> fprintf(
> report,
> - symbol->first.c_str()
> // line
> @@ -842,7 +845,8 @@ namespace Coverage {
> bool ReportsHtml::PutSymbolSummaryLine(
> FILE* report,
> unsigned int count,
> @@ -856,10 +860,10 @@ namespace Coverage {
> fprintf(
> report,
> - if (symbol->second.stats.sizeInBytes == 0) {
> + if (symbolInfo.stats.sizeInBytes == 0) {
> // The symbol has never been seen. Write "unknown" for all columns.
> fprintf(
> report,
> @@ -879,60 +883,60 @@ namespace Coverage {
> fprintf(
> report,
> - symbol->second.stats.sizeInBytes
> + symbolInfo.stats.sizeInBytes
> // Total Size in Instructions
> fprintf(
> report,
> - symbol->second.stats.sizeInInstructions
> + symbolInfo.stats.sizeInInstructions
> // Total Uncovered Ranges
> fprintf(
> report,
> - symbol->second.stats.uncoveredRanges
> + symbolInfo.stats.uncoveredRanges
> // Uncovered Size in Bytes
> fprintf(
> report,
> - symbol->second.stats.uncoveredBytes
> + symbolInfo.stats.uncoveredBytes
> // Uncovered Size in Instructions
> fprintf(
> report,
> - symbol->second.stats.uncoveredInstructions
> + symbolInfo.stats.uncoveredInstructions
> // Total number of branches
> fprintf(
> report,
> - symbol->second.stats.branchesNotExecuted + symbol->second.stats.branchesExecuted
> + symbolInfo.stats.branchesNotExecuted + symbolInfo.stats.branchesExecuted
> // Total Always Taken
> fprintf(
> report,
> - symbol->second.stats.branchesAlwaysTaken
> + symbolInfo.stats.branchesAlwaysTaken
> // Total Never Taken
> fprintf(
> report,
> - symbol->second.stats.branchesNeverTaken
> + symbolInfo.stats.branchesNeverTaken
> // % Uncovered Instructions
> - if ( symbol->second.stats.sizeInInstructions == 0 )
> + if ( symbolInfo.stats.sizeInInstructions == 0 )
> fprintf(
> report,
> "<td class=\"covoar-td\" align=\"center\">100.00</td>\n"
> @@ -941,12 +945,12 @@ namespace Coverage {
> fprintf(
> report,
> "<td class=\"covoar-td\" align=\"center\">%.2f</td>\n",
> - (symbol->second.stats.uncoveredInstructions*100.0)/
> + (symbolInfo.stats.uncoveredInstructions*100.0)/
> // % Uncovered Bytes
> - if ( symbol->second.stats.sizeInBytes == 0 )
> + if ( symbolInfo.stats.sizeInBytes == 0 )
> fprintf(
> report,
> @@ -955,8 +959,8 @@ namespace Coverage {
> fprintf(
> report,
> - (symbol->second.stats.uncoveredBytes*100.0)/
> + (symbolInfo.stats.uncoveredBytes*100.0)/
> diff --git a/tester/covoar/ReportsHtml.h b/tester/covoar/ReportsHtml.h
> index 34193da..7972ce1 100644
> --- a/tester/covoar/ReportsHtml.h
> +++ b/tester/covoar/ReportsHtml.h
> @@ -22,7 +22,7 @@ namespace Coverage {
> class ReportsHtml: public ReportsBase {
> public:
> - ReportsHtml( time_t timestamp );
> + ReportsHtml( time_t timestamp, std::string symbolSetName );
> ~ReportsHtml();
> @@ -163,7 +163,8 @@ class ReportsHtml: public ReportsBase {
> FILE* report,
> @@ -179,7 +180,8 @@ class ReportsHtml: public ReportsBase {
> FILE* report,
> @@ -187,7 +189,7 @@ class ReportsHtml: public ReportsBase {
> FILE* report,
> @@ -195,7 +197,8 @@ class ReportsHtml: public ReportsBase {
> FILE* report,
> /* Inherit documentation from base class. */
> diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
> index a3923e6..f552cdd 100644
> --- a/tester/covoar/ReportsText.cc
> +++ b/tester/covoar/ReportsText.cc
> @@ -11,8 +11,8 @@
> -ReportsText::ReportsText( time_t timestamp ):
> +ReportsText::ReportsText( time_t timestamp, std::string symbolSetName ):
> reportExtension_m = ".txt";
> @@ -52,7 +52,8 @@ bool ReportsText::PutNoBranchInfo(
> FILE* report
> - if ( BranchInfoAvailable && SymbolsToAnalyze->getNumberBranchesFound() != 0 )
> + if ( BranchInfoAvailable &&
> + SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0 )
> else
> @@ -61,9 +62,10 @@ bool ReportsText::PutNoBranchInfo(
> bool ReportsText::PutBranchEntry(
> - FILE* report,
> + FILE* report,
> @@ -76,8 +78,8 @@ bool ReportsText::PutBranchEntry(
> "Symbol : %s (0x%x)\n"
> "Line : %s (0x%x)\n"
> "Size in Bytes : %d\n",
> - symbolPtr->first.c_str(),
> - symbolPtr->second.baseAddress,
> + symbolName.c_str(),
> + symbolInfo.baseAddress,
> rangePtr->lowSourceLine.c_str(),
> rangePtr->lowAddress,
> rangePtr->highAddress - rangePtr->lowAddress + 1
> @@ -153,9 +155,10 @@ void ReportsText::putCoverageNoRange(
> bool ReportsText::PutCoverageLine(
> - FILE* report,
> - unsigned int number,
> + FILE* report,
> + unsigned int number,
> @@ -171,8 +174,8 @@ bool ReportsText::PutCoverageLine(
> "Size in Instructions : %d\n\n",
> ritr->id,
> - ditr->first.c_str(),
> - ditr->second.baseAddress,
> ritr->lowSourceLine.c_str(),
> ritr->lowAddress,
> ritr->highSourceLine.c_str(),
> @@ -210,9 +213,9 @@ bool ReportsText::PutCoverageLine(
> bool ReportsText::PutSizeLine(
> - FILE* report,
> + FILE* report,
> @@ -220,7 +223,7 @@ bool ReportsText::PutSizeLine(
> report,
> "%d\t%s\t%s\n",
> range->highAddress - range->lowAddress + 1,
> - symbol->first.c_str(),
> range->lowSourceLine.c_str()
> return true;
> @@ -229,13 +232,14 @@ bool ReportsText::PutSizeLine(
> bool ReportsText::PutSymbolSummaryLine(
> FILE* report,
> float uncoveredBytes;
> float uncoveredInstructions;
> fprintf(
> report,
> "============================================\n"
> @@ -245,20 +249,20 @@ bool ReportsText::PutSymbolSummaryLine(
> "Therefore there is no size or disassembly for this symbol.\n"
> "This could be due to symbol misspelling or lack of a test for\n"
> "this symbol.\n",
> } else {
> uncoveredInstructions = 0;
> else
> - uncoveredInstructions = (symbol->second.stats.uncoveredInstructions*100.0)/
> - symbol->second.stats.sizeInInstructions;
> + uncoveredInstructions = (symbolInfo.stats.uncoveredInstructions*100.0)/
> + symbolInfo.stats.sizeInInstructions;
> uncoveredBytes = 0;
> else
> - uncoveredBytes = (symbol->second.stats.uncoveredBytes*100.0)/
> - symbol->second.stats.sizeInBytes;
> + uncoveredBytes = (symbolInfo.stats.uncoveredBytes*100.0)/
> + symbolInfo.stats.sizeInBytes;
> fprintf(
> report,
> @@ -271,12 +275,12 @@ bool ReportsText::PutSymbolSummaryLine(
> "Total Never Taken : %d\n"
> "Percentage Uncovered Instructions : %.2f\n"
> "Percentage Uncovered Bytes : %.2f\n",
> - symbol->second.stats.sizeInBytes,
> - symbol->second.stats.sizeInInstructions,
> - symbol->second.stats.branchesNotExecuted + symbol->second.stats.branchesExecuted,
> - symbol->second.stats.branchesAlwaysTaken,
> - symbol->second.stats.branchesNeverTaken,
> + symbolInfo.stats.sizeInBytes,
> + symbolInfo.stats.sizeInInstructions,
> + symbolInfo.stats.branchesNotExecuted + symbolInfo.stats.branchesExecuted,
> + symbolInfo.stats.branchesAlwaysTaken,
> + symbolInfo.stats.branchesNeverTaken,
> uncoveredInstructions,
> uncoveredBytes
> diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
> index 9ae87d4..cf8a813 100644
> --- a/tester/covoar/ReportsText.h
> +++ b/tester/covoar/ReportsText.h
> @@ -21,7 +21,7 @@ namespace Coverage {
> class ReportsText: public ReportsBase {
> public:
> - ReportsText( time_t timestamp );
> + ReportsText( time_t timestamp, std::string symbolSetName );
> virtual ~ReportsText();
> @@ -83,7 +83,8 @@ class ReportsText: public ReportsBase {
> FILE* report,
> @@ -99,7 +100,8 @@ class ReportsText: public ReportsBase {
> FILE* report,
> @@ -107,7 +109,7 @@ class ReportsText: public ReportsBase {
> FILE* report,
> @@ -115,7 +117,8 @@ class ReportsText: public ReportsBase {
> FILE* report,
> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
> index 84d883a..8d63132 100644
> --- a/tester/covoar/covoar.cc
> +++ b/tester/covoar/covoar.cc
> @@ -350,7 +350,7 @@ int covoar(
> throw rld::error( "executables and coverage name size mismatch", "covoar" );
> if ( Verbose )
> - std::cerr << "Analyzing " << SymbolsToAnalyze->set.size()
> + std::cerr << "Analyzing " << SymbolsToAnalyze->allSymbols().size()
> << " symbols" << std::endl;
> // Create explanations.
> @@ -473,7 +473,9 @@ int covoar(
> if (Verbose)
> std::cerr << "Generate Reports" << std::endl;
> - Coverage::GenerateReports();
> + for (const auto& setName : SymbolsToAnalyze->getSetNames()) {
> + Coverage::GenerateReports(setName);
> // Write explanations that were not found.
> if ( explanations ) {
> 2.27.0
> devel mailing list
> devel at rtems.org
