[PATCH 1/2] covoar: Split symbols by symbol set
Alex White alex.white at oarcorp.com
Tue Apr 6 16:30:54 UTC 2021
On Tue, Apr 6, 2021 at 10:56 AM Gedare Bloom <gedare at rtems.org> wrote:
> looks ok, it's a lot to try to process though.
> In a future patch it would be good to provide more useful names, I
> don't know what 'ha' and 'la' mean, if anything. at least 'a' I
> understand to be an address.
> Also, the typedef with appending _t at the end should be removed, _t
> is reserved by POSIX.
Agreed. I'll file tickets.
> And I don't know why the _m is being appended, I guess it is denoted
> member variables? I'm used to seeing it as a prefix rather than a
> suffix, if it gets used at all. A few more C++ issues to add to the
> backlog.
As far as I can tell, yes. I've seen it done both ways in the past.
This codebase will need a lot of work to get its code style consistent.
Thanks,
Alex
