#3860 - GSoC enquiries
Tue Apr 6 16:12:00 UTC 2021
On Mon, Apr 5, 2021 at 10:37 PM Sebastian Huber
> On 04/04/2021 22:18, Joel Sherrill wrote:
> > On Sun, Apr 4, 2021 at 2:25 PM Ida Delphine <idadelm at gmail.com
> > <mailto:idadelm at gmail.com>> wrote:
> >     Hello,
> >     Please who are the possible mentors for this project?
> > IMO this is a project which has a larger potential potential set of
> > mentors than
> > one focused on say a single board.
> >     On Sun, 4 Apr 2021, 3:32 am Ida Delphine, <idadelm at gmail.com
> >         Regarding adding a script similar to linux/checkpatch.pl
> >         <http://checkpatch.pl> the criteria whether patches should
> >         need changes before being applied will be based on the output
> >         from running uncrustify right?
> > Yes. Assuming we find a combination of uncrustify settings combined
> > with changes to the RTEMS style and changes to uncrustify that put us
> > in a place where we trust that the output wth the right settings
> > matches our style.
> > That is your goal. Find changes to the settlngs, uncrustify, and RTEMS
> > code style where automated checking is possible. When you find a place
> > where the coding style requires something uncrustify cannot currently
> > do, the question is uncrustify changed or our coding style?
> > Sebastian may have a list of some of those from his effort to create
> > that configuration. But addressing the list of where the tooling and
> > style guide do not align is a key part of your project.
> I am not sure if tinkering code formatting tools to somehow produce the
> RTEMS style is a suitable GSoC project. What has this to do with coding?
> Also this task lingers around for years. Would it be a feasible task for
> a student?
Setting the configuration is not a good task, but since we apparently
can't find an out-of-the-box configuration, then there must be some
coding that is required to make those style formatters able to support
our style. (If not, then we should change our style later.)
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
