#3860 - GSoC enquiries
Ida Delphine
idadelm at gmail.com
Tue Apr 6 20:20:15 UTC 2021
Does this mean I won't have to work with uncrustify anymore?
On Tue, 6 Apr 2021, 5:12 pm Gedare Bloom, <gedare at rtems.org> wrote:
> On Mon, Apr 5, 2021 at 10:37 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 04/04/2021 22:18, Joel Sherrill wrote:
> > > On Sun, Apr 4, 2021 at 2:25 PM Ida Delphine <idadelm at gmail.com
> > > <mailto:idadelm at gmail.com>> wrote:
> > > Hello,
> > > Please who are the possible mentors for this project?
> > > IMO this is a project which has a larger potential potential set of
> > > mentors than
> > > one focused on say a single board.
> > > On Sun, 4 Apr 2021, 3:32 am Ida Delphine, <idadelm at gmail.com
> > > Regarding adding a script similar to linux/checkpatch.pl
> > > <http://checkpatch.pl> the criteria whether patches should
> > > need changes before being applied will be based on the output
> > > from running uncrustify right?
> > > Yes. Assuming we find a combination of uncrustify settings combined
> > > with changes to the RTEMS style and changes to uncrustify that put us
> > > in a place where we trust that the output wth the right settings
> > > matches our style.
> > > That is your goal. Find changes to the settlngs, uncrustify, and RTEMS
> > > code style where automated checking is possible. When you find a place
> > > where the coding style requires something uncrustify cannot currently
> > > do, the question is uncrustify changed or our coding style?
> > > Sebastian may have a list of some of those from his effort to create
> > > that configuration. But addressing the list of where the tooling and
> > > style guide do not align is a key part of your project.
> > I am not sure if tinkering code formatting tools to somehow produce the
> > RTEMS style is a suitable GSoC project. What has this to do with coding?
> > Also this task lingers around for years. Would it be a feasible task for
> > a student?
> Setting the configuration is not a good task, but since we apparently
> can't find an out-of-the-box configuration, then there must be some
> coding that is required to make those style formatters able to support
> our style. (If not, then we should change our style later.)
> > embedded brains GmbH
> > Herr Sebastian HUBER
> > Dornierstr. 4
> > 82178 Puchheim
> > Germany
> > email: sebastian.huber at embedded-brains.de
> > phone: +49-89-18 94 741 - 16
> > fax: +49-89-18 94 741 - 08
> > Registergericht: Amtsgericht München
> > Registernummer: HRB 157899
> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> > Unsere Datenschutzerklärung finden Sie hier:
> > https://embedded-brains.de/datenschutzerklaerung/
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210406/d7ba6d07/attachment.html>
