[PATCH v2] coverage.py: Call covoar once
Alex White
alex.white at oarcorp.com
Tue Apr 6 16:12:14 UTC 2021
Updates #4374
tester/rt/coverage.py | 60 +++++++++++++++++++++----------------------
1 file changed, 30 insertions(+), 30 deletions(-)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index 29ed60b..beda207 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -304,22 +304,26 @@ class symbol_parser(object):
except:
raise error.general('Symbol set parsing failed for %s' % (sset))
- def write_ini(self, symbol_set):
+ def write_ini(self, symbol_sets):
config = configparser.ConfigParser()
- try:
- sset = symbol_set
- config.add_section('symbol-sets')
- config.set('symbol-sets', 'sets', sset)
- config.add_section(sset)
- object_files = [o for o in path.listdir(self.symbol_sets[sset]) if o[-1] == 'o']
- object_paths = []
- for o in object_files:
- object_paths.append(path.join(self.symbol_sets[sset], o))
- config.set(sset, 'libraries', ','.join(object_paths))
- with open(self.symbol_select_file, 'w') as conf:
- config.write(conf)
- except:
- raise error.general('symbol parser write failed for %s' % (sset))
+ config.add_section('symbol-sets')
+ for sset in symbol_sets:
+ try:
+ config.add_section(sset)
+ object_paths = [
+ path.join(self.symbol_sets[sset], o)
+ for o in path.listdir(self.symbol_sets[sset])
+ if path.splitext(o)[1] == '.o'
+ config.set(sset, 'libraries', ','.join(object_paths))
+ except:
+ raise error.general('symbol parser write failed for %s' % (sset))
+ config.set('symbol-sets', 'sets', ','.join(symbol_sets))
+ with open(self.symbol_select_file, 'w') as conf:
+ config.write(conf)
class covoar(object):
@@ -352,23 +356,20 @@ class covoar(object):
return exe
raise error.general('coverage: %s not found'% (covoar_exe))
- def run(self, set_name, symbol_file):
- covoar_result_dir = path.join(self.base_result_dir, set_name)
- if not path.exists(covoar_result_dir):
- path.mkdir(covoar_result_dir)
+ def run(self, symbol_file):
if not path.exists(symbol_file):
raise error.general('coverage: no symbol set file: %s'% (symbol_file))
exe = self._find_covoar()
# The order of these arguments matters. Command line options must come
# before the executable path arguments because covoar uses getopt() to
# process the command line options.
- command = exe + ' -O ' + covoar_result_dir + \
+ command = exe + ' -O ' + self.base_result_dir + \
' -p ' + self.project_name + \
' ' + self.covoar_cmd + ' '
command += self.executables
log.notice()
- log.notice('Running coverage analysis: %s (%s)' % (set_name, covoar_result_dir))
+ log.notice('Running coverage analysis (%s)' % (self.base_result_dir))
start_time = datetime.datetime.now()
executor = execute.execute(verbose = self.trace, output = self.output_handler)
exit_code = executor.shell(command, cwd=os.getcwd())
@@ -424,15 +425,14 @@ class coverage_run(object):
self.bsp_name,
self.target)
symbol_sets = parser.parse()
- for sset in symbol_sets:
- parser.write_ini(sset)
- covoar_runner = covoar(self.test_dir,
- self.symbol_select_path,
- self.executables,
- self.trace,
- self.prefix,
- self.covoar_cmd)
- covoar_runner.run(sset, self.symbol_select_path)
+ parser.write_ini(symbol_sets)
+ covoar_runner = covoar(self.test_dir,
+ self.symbol_select_path,
+ self.executables,
+ self.trace,
+ self.prefix,
+ self.covoar_cmd)
+ covoar_runner.run(self.symbol_select_path)
self._generate_reports(symbol_sets);
self._summarize();
finally:
2.27.0
