[PATCH v2] coverage.py: Call covoar once
Gedare Bloom
gedare at rtems.org
Tue Apr 6 16:14:20 UTC 2021
Pythonic! Looks good to me.
On Tue, Apr 6, 2021 at 10:12 AM Alex White <alex.white at oarcorp.com> wrote:
> Updates #4374
> tester/rt/coverage.py | 60 +++++++++++++++++++++----------------------
> 1 file changed, 30 insertions(+), 30 deletions(-)
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> index 29ed60b..beda207 100644
> --- a/tester/rt/coverage.py
> +++ b/tester/rt/coverage.py
> @@ -304,22 +304,26 @@ class symbol_parser(object):
> except:
> raise error.general('Symbol set parsing failed for %s' % (sset))
> - def write_ini(self, symbol_set):
> + def write_ini(self, symbol_sets):
> config = configparser.ConfigParser()
> - try:
> - sset = symbol_set
> - config.add_section('symbol-sets')
> - config.set('symbol-sets', 'sets', sset)
> - config.add_section(sset)
> - object_files = [o for o in path.listdir(self.symbol_sets[sset]) if o[-1] == 'o']
> - object_paths = []
> - for o in object_files:
> - object_paths.append(path.join(self.symbol_sets[sset], o))
> - config.set(sset, 'libraries', ','.join(object_paths))
> - with open(self.symbol_select_file, 'w') as conf:
> - config.write(conf)
> - except:
> - raise error.general('symbol parser write failed for %s' % (sset))
> + config.add_section('symbol-sets')
> + for sset in symbol_sets:
> + try:
> + config.add_section(sset)
> + object_paths = [
> + path.join(self.symbol_sets[sset], o)
> + for o in path.listdir(self.symbol_sets[sset])
> + if path.splitext(o)[1] == '.o'
> + config.set(sset, 'libraries', ','.join(object_paths))
> + except:
> + raise error.general('symbol parser write failed for %s' % (sset))
> + config.set('symbol-sets', 'sets', ','.join(symbol_sets))
> + with open(self.symbol_select_file, 'w') as conf:
> + config.write(conf)
> class covoar(object):
> @@ -352,23 +356,20 @@ class covoar(object):
> return exe
> raise error.general('coverage: %s not found'% (covoar_exe))
> - def run(self, set_name, symbol_file):
> - covoar_result_dir = path.join(self.base_result_dir, set_name)
> - if not path.exists(covoar_result_dir):
> - path.mkdir(covoar_result_dir)
> + def run(self, symbol_file):
> if not path.exists(symbol_file):
> raise error.general('coverage: no symbol set file: %s'% (symbol_file))
> exe = self._find_covoar()
> # The order of these arguments matters. Command line options must come
> # before the executable path arguments because covoar uses getopt() to
> # process the command line options.
> - command = exe + ' -O ' + covoar_result_dir + \
> + command = exe + ' -O ' + self.base_result_dir + \
> ' -p ' + self.project_name + \
> ' ' + self.covoar_cmd + ' '
> command += self.executables
> log.notice()
> - log.notice('Running coverage analysis: %s (%s)' % (set_name, covoar_result_dir))
> + log.notice('Running coverage analysis (%s)' % (self.base_result_dir))
> start_time = datetime.datetime.now()
> executor = execute.execute(verbose = self.trace, output = self.output_handler)
> exit_code = executor.shell(command, cwd=os.getcwd())
> @@ -424,15 +425,14 @@ class coverage_run(object):
> self.bsp_name,
> self.target)
> symbol_sets = parser.parse()
> - for sset in symbol_sets:
> - parser.write_ini(sset)
> - covoar_runner = covoar(self.test_dir,
> - self.symbol_select_path,
> - self.executables,
> - self.trace,
> - self.prefix,
> - self.covoar_cmd)
> - covoar_runner.run(sset, self.symbol_select_path)
> + parser.write_ini(symbol_sets)
> + covoar_runner = covoar(self.test_dir,
> + self.symbol_select_path,
> + self.executables,
> + self.trace,
> + self.prefix,
> + self.covoar_cmd)
> + covoar_runner.run(self.symbol_select_path)
> self._generate_reports(symbol_sets);
> self._summarize();
> finally:
> 2.27.0
> devel mailing list
> devel at rtems.org
