#3860 - GSoC enquiries
Gedare Bloom
gedare at rtems.org
Tue Apr 6 21:38:44 UTC 2021
On Tue, Apr 6, 2021 at 2:20 PM Ida Delphine <idadelm at gmail.com> wrote:
> Does this mean I won't have to work with uncrustify anymore?
It seems like there is encouragement to consider working with clang. I
think it is a good idea to work with clang anyway. There are other
possible projects that you might be able to consider building from
that skill set.
I think that there is a tricky problem in clang how to handle the
alignment of * when there are multiple * in the same declaration. You
might dig into that problem in your proposal, and identify a solution?
The stack overflow link was posted before, if you an find it.
> On Tue, 6 Apr 2021, 5:12 pm Gedare Bloom, <gedare at rtems.org> wrote:
>> On Mon, Apr 5, 2021 at 10:37 PM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > On 04/04/2021 22:18, Joel Sherrill wrote:
>> > > On Sun, Apr 4, 2021 at 2:25 PM Ida Delphine <idadelm at gmail.com
>> > > <mailto:idadelm at gmail.com>> wrote:
>> > > Hello,
>> > > Please who are the possible mentors for this project?
>> > > IMO this is a project which has a larger potential potential set of
>> > > mentors than
>> > > one focused on say a single board.
>> > > On Sun, 4 Apr 2021, 3:32 am Ida Delphine, <idadelm at gmail.com
>> > > Regarding adding a script similar to linux/checkpatch.pl
>> > > <http://checkpatch.pl> the criteria whether patches should
>> > > need changes before being applied will be based on the output
>> > > from running uncrustify right?
>> > > Yes. Assuming we find a combination of uncrustify settings combined
>> > > with changes to the RTEMS style and changes to uncrustify that put us
>> > > in a place where we trust that the output wth the right settings
>> > > matches our style.
>> > > That is your goal. Find changes to the settlngs, uncrustify, and RTEMS
>> > > code style where automated checking is possible. When you find a place
>> > > where the coding style requires something uncrustify cannot currently
>> > > do, the question is uncrustify changed or our coding style?
>> > > Sebastian may have a list of some of those from his effort to create
>> > > that configuration. But addressing the list of where the tooling and
>> > > style guide do not align is a key part of your project.
>> > I am not sure if tinkering code formatting tools to somehow produce the
>> > RTEMS style is a suitable GSoC project. What has this to do with coding?
>> > Also this task lingers around for years. Would it be a feasible task for
>> > a student?
>> Setting the configuration is not a good task, but since we apparently
>> can't find an out-of-the-box configuration, then there must be some
>> coding that is required to make those style formatters able to support
>> our style. (If not, then we should change our style later.)
>> > embedded brains GmbH
>> > Herr Sebastian HUBER
>> > Dornierstr. 4
>> > 82178 Puchheim
>> > Germany
>> > email: sebastian.huber at embedded-brains.de
>> > phone: +49-89-18 94 741 - 16
>> > fax: +49-89-18 94 741 - 08
>> > Registergericht: Amtsgericht München
>> > Registernummer: HRB 157899
>> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> > Unsere Datenschutzerklärung finden Sie hier:
>> > https://embedded-brains.de/datenschutzerklaerung/
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
