[PATCH rtems-net-legacy] nfsclient: Build nfsclient from the top level netlegacy script
Tue Apr 6 21:40:46 UTC 2021
On Tue, Apr 6, 2021 at 2:24 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 4 Apr 2021, at 11:06 am, Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > netlegacy.py      | 18 +++++++++++++++++-
> > nfsclient/wscript |  1 +
> > wscript           |  2 +-
> > 3 files changed, 19 insertions(+), 2 deletions(-)
> > diff --git a/netlegacy.py b/netlegacy.py
> > index 89176e6..f470da2 100644
> > --- a/netlegacy.py
> > +++ b/netlegacy.py
> > @@ -55,6 +55,13 @@ def build(bld):
> >                    for s in os.listdir('./pppd') if s[-2:] == '.c']
> >     telnetd_source = [os.path.join('./telnetd', s)
> >                       for s in os.listdir('telnetd') if s[-2:] == '.c']
> > +    nfs_source = []
> > +    for root, dirs, files in os.walk('./nfsclient'):
> The `./` seems wrong to me. It may work on Windows if the path parsing can handle / and \.
> > +        for name in files:
> > +            ext = os.path.splitext(name)[1]
> > +            if ext == '.c':
> > +                src_root = os.path.split(root)[1]
> > +                nfs_source.append(os.path.join('./nfsclient', src_root, name))
> And here where join() handles the separator but you have one embedded in the path.
> >     bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> > @@ -67,6 +74,7 @@ def build(bld):
> >                          './bsps/include'])
> >     arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> >                                             bld.env.RTEMS_ARCH_BSP)
> > +    lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> >     include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
> >                                                      arch_lib_path)))
> > @@ -74,6 +82,8 @@ def build(bld):
> >                                                      'include')))
> >     include_path.append('./bsps/include/libchip')
> Oh and here!
> > +    bld.read_stlib('rtemsbsp', paths=[lib_path])
> >     if bsp in bsp_dirs:
> >         include_path.extend(bsp_dirs[bsp])
> > @@ -108,8 +118,14 @@ def build(bld):
> >               use='networking',
> >               source=telnetd_source)
> > +    bld.stlib(target='nfs',
> > +              features='c',
> > +              includes=ip,
> > +              use=['rtemsbsp', 'networking'],
> > +              source=nfs_source)
> >     bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> > -                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> > +                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> >     bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> >                                    'include', 'libchip'),
> >                       [os.path.join('./bsps/include/libchip/', f)
> You may need a wrapper or something else ...
> I think we touched on this once before when I suggested the waf Node support (I think?). This is a hole you can end up heading down when you manage paths explicitly. I suggest you step back and decide on a way to handle this for all platforms.
Yes, thanks. I asked him to test on Windows, but he's getting bit the
gdb tool won't build. We'll need to get this all sorted out before
release hits...
> Chris
> devel mailing list
> devel at rtems.org
