[PATCH rtems-net-legacy] nfsclient: Build nfsclient from the top level netlegacy script
Chris Johns
chrisj at rtems.org
Tue Apr 6 20:23:39 UTC 2021
> On 4 Apr 2021, at 11:06 am, Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> netlegacy.py | 18 +++++++++++++++++-
> nfsclient/wscript | 1 +
> wscript | 2 +-
> 3 files changed, 19 insertions(+), 2 deletions(-)
> diff --git a/netlegacy.py b/netlegacy.py
> index 89176e6..f470da2 100644
> --- a/netlegacy.py
> +++ b/netlegacy.py
> @@ -55,6 +55,13 @@ def build(bld):
> for s in os.listdir('./pppd') if s[-2:] == '.c']
> telnetd_source = [os.path.join('./telnetd', s)
> for s in os.listdir('telnetd') if s[-2:] == '.c']
> + nfs_source = []
> + for root, dirs, files in os.walk('./nfsclient'):
The `./` seems wrong to me. It may work on Windows if the path parsing can handle / and \.
> + for name in files:
> + ext = os.path.splitext(name)[1]
> + if ext == '.c':
> + src_root = os.path.split(root)[1]
> + nfs_source.append(os.path.join('./nfsclient', src_root, name))
And here where join() handles the separator but you have one embedded in the path.
> bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> @@ -67,6 +74,7 @@ def build(bld):
> './bsps/include'])
> arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> bld.env.RTEMS_ARCH_BSP)
> + lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
> arch_lib_path)))
> @@ -74,6 +82,8 @@ def build(bld):
> 'include')))
> include_path.append('./bsps/include/libchip')
Oh and here!
> + bld.read_stlib('rtemsbsp', paths=[lib_path])
> if bsp in bsp_dirs:
> include_path.extend(bsp_dirs[bsp])
> @@ -108,8 +118,14 @@ def build(bld):
> use='networking',
> source=telnetd_source)
> + bld.stlib(target='nfs',
> + features='c',
> + includes=ip,
> + use=['rtemsbsp', 'networking'],
> + source=nfs_source)
> bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> - ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> + ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> 'include', 'libchip'),
> [os.path.join('./bsps/include/libchip/', f)
You may need a wrapper or something else ...
I think we touched on this once before when I suggested the waf Node support (I think?). This is a hole you can end up heading down when you manage paths explicitly. I suggest you step back and decide on a way to handle this for all platforms.
