[PATCH 0/2] covoar: Trailing white space and Tab Removal fixes
    Joel Sherrill
    joel at rtems.org
    Tue Apr  6 21:47:17 UTC 2021
On Tue, Apr 6, 2021, 4:43 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Joel,
> I think this is fine for you to push, since it will only cause
> headaches for you and Alex if there are whitespace-induced merge
> conflicts ;)
If only one of the cats were in my lap so I could stroke it while making an
evil laugh. :)
--joel
> Gedare
> On Tue, Apr 6, 2021 at 2:43 PM Joel Sherrill <joel at rtems.org> wrote:
> > Hi
> > In committing a patch from Alex, I noticed that git complained about
> white
> > space at the end of the line. I checked and there were ~225 lines that
> applied
> > to. Then I looked for tabs. As I looked for tabs, I tried to control
> myself
> > as there were some places I was itching to clean up but resisted.
> > + patch 1 - white space at EOL removed
> > + patch 2 - tabs replaced and some clean up to fix formatting.
> > Patch 1 shows no differences git "git diff -b"
> > Patch 2 shows a few changes line a line deleted here or there.
> > Joel Sherrill (2):
> >   covoar: Remove training white spaces
> >   covoar: Eliminate tabs
> >  tester/covoar/ConfigFile.cc          |   4 +-
> >  tester/covoar/ConfigFile.h           |   8 +-
> >  tester/covoar/CoverageMap.h          |   4 +-
> >  tester/covoar/CoverageRanges.cc      |   2 +-
> >  tester/covoar/CoverageRanges.h       |  16 +-
> >  tester/covoar/CoverageReaderBase.h   |   4 +-
> >  tester/covoar/CoverageReaderTSIM.cc  |  16 +-
> >  tester/covoar/CoverageReaderTSIM.h   |   4 +-
> >  tester/covoar/CoverageWriterBase.h   |   4 +-
> >  tester/covoar/CoverageWriterRTEMS.h  |   6 +-
> >  tester/covoar/CoverageWriterSkyeye.h |   6 +-
> >  tester/covoar/CoverageWriterTSIM.cc  |   4 +-
> >  tester/covoar/CoverageWriterTSIM.h   |   6 +-
> >  tester/covoar/Explanations.h         |   6 +-
> >  tester/covoar/GcovData.cc            | 719
> >  tester/covoar/GcovData.h             |  86 ++---
> >  tester/covoar/GcovFunctionData.cc    |  43 ++-
> >  tester/covoar/GcovFunctionData.h     | 113 +++---
> >  tester/covoar/Makefile               |   2 +-
> >  tester/covoar/ReportsBase.h          |  26 +-
> >  tester/covoar/ReportsHtml.cc         |   6 +-
> >  tester/covoar/ReportsHtml.h          |  62 +--
> >  tester/covoar/ReportsText.cc         |  18 +-
> >  tester/covoar/ReportsText.h          |  34 +-
> >  tester/covoar/SymbolTable.cc         |   6 +-
> >  tester/covoar/SymbolTable.h          |   6 +-
> >  tester/covoar/TargetBase.h           |   4 +-
> >  tester/covoar/Target_arm.h           |   2 +-
> >  tester/covoar/Target_i386.cc         |   4 +-
> >  tester/covoar/Target_i386.h          |   2 +-
> >  tester/covoar/Target_lm32.cc         |   4 +-
> >  tester/covoar/Target_lm32.h          |   2 +-
> >  tester/covoar/Target_m68k.h          |   2 +-
> >  tester/covoar/Target_powerpc.h       |   2 +-
> >  tester/covoar/Target_riscv.h         |   8 +-
> >  tester/covoar/Target_sparc.cc        |  12 +-
> >  tester/covoar/Target_sparc.h         |   2 +-
> >  tester/covoar/TraceList.cc           |  12 +-
> >  tester/covoar/TraceList.h            |   6 +-
> >  tester/covoar/TraceReaderBase.h      |   4 +-
> >  tester/covoar/TraceReaderLogQEMU.h   |   4 +-
> >  tester/covoar/TraceWriterBase.h      |   4 +-
> >  tester/covoar/TraceWriterQEMU.h      |   4 +-
> >  tester/covoar/configFile.txt         |   8 +-
> >  tester/covoar/configfile_test.cc     |   2 +-
> >  tester/covoar/coverage_converter.cc  |   8 +-
> >  tester/covoar/covmerge.cc            |  32 +-
> >  tester/covoar/covoar.css             |  10 +-
> >  tester/covoar/mkExplanation          |  10 +-
> >  tester/covoar/qemu-dump-trace.c      |   4 +-
> >  tester/covoar/table.js               |  68 ++--
> >  51 files changed, 718 insertions(+), 713 deletions(-)
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210406/8d53337b/attachment.html>
