[PATCH 0/2] covoar: Trailing white space and Tab Removal fixes
Gedare Bloom
gedare at rtems.org
Tue Apr 6 21:43:01 UTC 2021
Hi Joel,
I think this is fine for you to push, since it will only cause
headaches for you and Alex if there are whitespace-induced merge
conflicts ;)
Gedare
On Tue, Apr 6, 2021 at 2:43 PM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> In committing a patch from Alex, I noticed that git complained about white
> space at the end of the line. I checked and there were ~225 lines that applied
> to. Then I looked for tabs. As I looked for tabs, I tried to control myself
> as there were some places I was itching to clean up but resisted.
> + patch 1 - white space at EOL removed
> + patch 2 - tabs replaced and some clean up to fix formatting.
> Patch 1 shows no differences git "git diff -b"
> Patch 2 shows a few changes line a line deleted here or there.
> Joel Sherrill (2):
> covoar: Remove training white spaces
> covoar: Eliminate tabs
> tester/covoar/ConfigFile.cc | 4 +-
> tester/covoar/ConfigFile.h | 8 +-
> tester/covoar/CoverageMap.h | 4 +-
> tester/covoar/CoverageRanges.cc | 2 +-
> tester/covoar/CoverageRanges.h | 16 +-
> tester/covoar/CoverageReaderBase.h | 4 +-
> tester/covoar/CoverageReaderTSIM.cc | 16 +-
> tester/covoar/CoverageReaderTSIM.h | 4 +-
> tester/covoar/CoverageWriterBase.h | 4 +-
> tester/covoar/CoverageWriterRTEMS.h | 6 +-
> tester/covoar/CoverageWriterSkyeye.h | 6 +-
> tester/covoar/CoverageWriterTSIM.cc | 4 +-
> tester/covoar/CoverageWriterTSIM.h | 6 +-
> tester/covoar/Explanations.h | 6 +-
> tester/covoar/GcovData.cc | 719 ++++++++++++++++++-----------------
> tester/covoar/GcovData.h | 86 ++---
> tester/covoar/GcovFunctionData.cc | 43 ++-
> tester/covoar/GcovFunctionData.h | 113 +++---
> tester/covoar/Makefile | 2 +-
> tester/covoar/ReportsBase.h | 26 +-
> tester/covoar/ReportsHtml.cc | 6 +-
> tester/covoar/ReportsHtml.h | 62 +--
> tester/covoar/ReportsText.cc | 18 +-
> tester/covoar/ReportsText.h | 34 +-
> tester/covoar/SymbolTable.cc | 6 +-
> tester/covoar/SymbolTable.h | 6 +-
> tester/covoar/TargetBase.h | 4 +-
> tester/covoar/Target_arm.h | 2 +-
> tester/covoar/Target_i386.cc | 4 +-
> tester/covoar/Target_i386.h | 2 +-
> tester/covoar/Target_lm32.cc | 4 +-
> tester/covoar/Target_lm32.h | 2 +-
> tester/covoar/Target_m68k.h | 2 +-
> tester/covoar/Target_powerpc.h | 2 +-
> tester/covoar/Target_riscv.h | 8 +-
> tester/covoar/Target_sparc.cc | 12 +-
> tester/covoar/Target_sparc.h | 2 +-
> tester/covoar/TraceList.cc | 12 +-
> tester/covoar/TraceList.h | 6 +-
> tester/covoar/TraceReaderBase.h | 4 +-
> tester/covoar/TraceReaderLogQEMU.h | 4 +-
> tester/covoar/TraceWriterBase.h | 4 +-
> tester/covoar/TraceWriterQEMU.h | 4 +-
> tester/covoar/configFile.txt | 8 +-
> tester/covoar/configfile_test.cc | 2 +-
> tester/covoar/coverage_converter.cc | 8 +-
> tester/covoar/covmerge.cc | 32 +-
> tester/covoar/covoar.css | 10 +-
> tester/covoar/mkExplanation | 10 +-
> tester/covoar/qemu-dump-trace.c | 4 +-
> tester/covoar/table.js | 68 ++--
> 51 files changed, 718 insertions(+), 713 deletions(-)
> 1.8.3.1
> devel mailing list
> devel at rtems.org
