#3860 - GSoC enquiries
Wed Apr 7 16:27:19 UTC 2021
On Wed, Apr 7, 2021 at 10:11 AM Ida Delphine <idadelm at gmail.com> wrote:
> Hello,
> In case I succeed with this project will I be required to do some documentation on how it works?
Yes, in general we expect students to produce documentation while they
work on also creating code.
I think the direction we're heading right now is toward using
clang-format, perhaps with an update to a common coding style. In this
case, we solve our problem by policy rather than technical solution,
and your work should focus on tool integration and automation without
concern about the coding style itself.
> On Wed, Apr 7, 2021 at 9:51 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 07/04/2021 09:03, Chris Johns wrote:
>> > Would it be pragmatic to review these cases and change the standard?
>> I sent a patch to review the format changes done by clang-format recently:
>> https://lists.rtems.org/pipermail/devel/2021-April/066311.html
>> It doesn't look that bad from my point of view. Fixing the alignment
>> issue would make it even better:
>> https://reviews.llvm.org/D27651
>> > I understand the long history but as you point out we either invest in the tools
>> > to support the format, we change what we have or we manage it manually.
>> I would prefer to change the style and use a widely used formatting
>> tool. I think we spend to much time on the coding style in reviews. This
>> is quite bad since we are all busy with all sorts of things and our time
>> is better spent on more important tasks. A consistently formatted source
>> code is very important, but enforcing this style manually is a waste of
>> time.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax:   +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
