#3860 - GSoC enquiries
Ida Delphine
idadelm at gmail.com
Thu Apr 8 05:51:03 UTC 2021
Hello everyone,
Here is the link to my GSoC proposal. Will love if you leave comments on
ways I could make it better or any corrections (Especially the *Proposesd
Schedule* section so that I will be sure about my project deliverables when
inputting them).
https://docs.google.com/document/d/1VADJh3_kIhs578IEmBJ98rjR6p5E1XcksUkq1Ms4jRA/edit?usp=sharing
I will also love to know about any future improvements to this project.
Cheers,
Ida.
On Wed, Apr 7, 2021 at 5:27 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Apr 7, 2021 at 10:11 AM Ida Delphine <idadelm at gmail.com> wrote:
> > Hello,
> > In case I succeed with this project will I be required to do some
> documentation on how it works?
> Yes, in general we expect students to produce documentation while they
> work on also creating code.
> I think the direction we're heading right now is toward using
> clang-format, perhaps with an update to a common coding style. In this
> case, we solve our problem by policy rather than technical solution,
> and your work should focus on tool integration and automation without
> concern about the coding style itself.
> > On Wed, Apr 7, 2021 at 9:51 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >> On 07/04/2021 09:03, Chris Johns wrote:
> >> > Would it be pragmatic to review these cases and change the standard?
> >> I sent a patch to review the format changes done by clang-format
> recently:
> >> https://lists.rtems.org/pipermail/devel/2021-April/066311.html
> >> It doesn't look that bad from my point of view. Fixing the alignment
> >> issue would make it even better:
> >> https://reviews.llvm.org/D27651
> >> > I understand the long history but as you point out we either invest
> in the tools
> >> > to support the format, we change what we have or we manage it
> manually.
> >> I would prefer to change the style and use a widely used formatting
> >> tool. I think we spend to much time on the coding style in reviews. This
> >> is quite bad since we are all busy with all sorts of things and our time
> >> is better spent on more important tasks. A consistently formatted source
> >> code is very important, but enforcing this style manually is a waste of
> >> time.
> >> embedded brains GmbH
> >> Herr Sebastian HUBER
> >> Dornierstr. 4
> >> 82178 Puchheim
> >> Germany
> >> email: sebastian.huber at embedded-brains.de
> >> phone: +49-89-18 94 741 - 16
> >> fax: +49-89-18 94 741 - 08
> >> Registergericht: Amtsgericht München
> >> Registernummer: HRB 157899
> >> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> >> Unsere Datenschutzerklärung finden Sie hier:
> >> https://embedded-brains.de/datenschutzerklaerung/
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210408/a4c56d9b/attachment-0001.html>
