[PATCH rtems-net-legacy] netlegacy: Use os.path instead of hardcoded Unix like path
Vijay Kumar Banerjee vijay at rtems.org
Wed Apr 7 16:52:42 UTC 2021
 netlegacy.py | 16 ++++++++--------
 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/netlegacy.py b/netlegacy.py
index 05cb78a..ddd1db3 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -37,7 +37,7 @@ exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
 for root, dirs, files in os.walk("."):
     [dirs.remove(d) for d in list(dirs) if d in exclude_dirs]
-    dirs.append('./bsps/shared/net')
+    dirs.append(os.path.join('bsps', 'shared', 'net'))
     include_files[root[2:]] = []
     for name in files:
         ext = os.path.splitext(name)[1]
@@ -59,9 +59,9 @@ def build(bld):
     include_path = []
     ip = ''
     bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
-    pppd_source = [os.path.join('./pppd', s)
-                   for s in os.listdir('./pppd') if s[-2:] == '.c']
-    telnetd_source = [os.path.join('./telnetd', s)
+    pppd_source = [os.path.join('pppd', s)
+                   for s in os.listdir('pppd') if s[-2:] == '.c']
+    telnetd_source = [os.path.join('telnetd', s)
                       for s in os.listdir('telnetd') if s[-2:] == '.c']
     nfs_source = []
     for root, dirs, files in os.walk('nfsclient'):
@@ -74,12 +74,12 @@ def build(bld):
     bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
     include_path.extend(['.',
-                         './include',
+                         'include',
                          os.path.relpath(bld.env.PREFIX),
-                         './testsuites/include',
+                         os.path.join('testsuites', 'include'),
                          os.path.relpath(os.path.join(bld.env.PREFIX,
                                                       'include')),
-                         './bsps/include'])
+                         os.path.join('bsps', 'include')])
     arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
                                             bld.env.RTEMS_ARCH_BSP)
     lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
@@ -138,7 +138,7 @@ def build(bld):
                                    'include', 'libchip'),
                       install_file_list('bsps', 'include', 'libchip'))
     for i in include_files:
-        if 'include' in i.split('/'):
+        if 'include' in os.path.split(i):
             bld.install_files(os.path.join('${PREFIX}',
                                            arch_lib_path, i),
                               include_files[i])
2.26.2
