[PATCH rtems-net-legacy v3] nfsclient: Build nfsclient from the top level netlegacy script
Vijay Kumar Banerjee vijay at rtems.org
Thu Apr 15 17:57:58 UTC 2021
On Wed, Apr 14, 2021 at 12:20 AM Gedare Bloom <gedare at rtems.org> wrote:
> looks good, other than the comment I made on the other patch about '${PREFIX}'
Pushed, thanks.
> On Wed, Apr 14, 2021 at 12:01 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > Ping :)
> > On Wed, Apr 7, 2021 at 10:51 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > >  netlegacy.py      | 31 ++++++++++++++++++++++----
> > >  nfsclient/wscript | 56 -----------------------------------------------
> > >  wscript           |  2 +-
> > >  3 files changed, 28 insertions(+), 61 deletions(-)
> > >  delete mode 100644 nfsclient/wscript
> > > diff --git a/netlegacy.py b/netlegacy.py
> > > index 89176e6..05cb78a 100644
> > > --- a/netlegacy.py
> > > +++ b/netlegacy.py
> > > @@ -46,6 +46,14 @@ for root, dirs, files in os.walk("."):
> > >          if ext == '.h' and name not in exclude_headers:
> > >              include_files[root[2:]].append(os.path.join(root, name))
> > > +def find_node(bld, *paths):
> > > +    path = os.path.join(*paths)
> > > +    return os.path.relpath(str(bld.path.find_node(path)))
> > > +def install_file_list(*paths):
> > > +    file_list = [os.path.join(path, f) for f in os.listdir(path)]
> > > +    return file_list
> > >  def build(bld):
> > >      include_path = []
> > > @@ -55,6 +63,13 @@ def build(bld):
> > >                     for s in os.listdir('./pppd') if s[-2:] == '.c']
> > >      telnetd_source = [os.path.join('./telnetd', s)
> > >                        for s in os.listdir('telnetd') if s[-2:] == '.c']
> > > +    nfs_source = []
> > > +    for root, dirs, files in os.walk('nfsclient'):
> > > +        for name in files:
> > > +            ext = os.path.splitext(name)[1]
> > > +            if ext == '.c':
> > > +                src_root = os.path.split(root)
> > > +                nfs_source.append(os.path.join(src_root[0], src_root[1], name))
> > >      bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> > > @@ -67,12 +82,15 @@ def build(bld):
> > >                           './bsps/include'])
> > >      arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> > >                                              bld.env.RTEMS_ARCH_BSP)
> > > +    lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> > >      include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
> > >                                                       arch_lib_path)))
> > >                                                       arch_lib_path,
> > >                                                       'include')))
> > > -    include_path.append('./bsps/include/libchip')
> > > +    include_path.append(find_node(bld, 'bsps', 'include', 'libchip'))
> > > +    bld.read_stlib('rtemsbsp', paths=[lib_path])
> > >      if bsp in bsp_dirs:
> > >          include_path.extend(bsp_dirs[bsp])
> > > @@ -108,12 +126,17 @@ def build(bld):
> > >                use='networking',
> > >                source=telnetd_source)
> > > +    bld.stlib(target='nfs',
> > > +              features='c',
> > > +              includes=ip,
> > > +              use=['rtemsbsp', 'networking'],
> > > +              source=nfs_source)
> > >      bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> > > -                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> > > +                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> > >      bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> > >                                     'include', 'libchip'),
> > > -                      [os.path.join('./bsps/include/libchip/', f)
> > > -                      for f in os.listdir('./bsps/include/libchip/')])
> > > +                      install_file_list('bsps', 'include', 'libchip'))
> > >      for i in include_files:
> > >          if 'include' in i.split('/'):
> > > diff --git a/nfsclient/wscript b/nfsclient/wscript
> > > deleted file mode 100644
> > > index bc2f994..0000000
> > > --- a/nfsclient/wscript
> > > +++ /dev/null
> > > @@ -1,56 +0,0 @@
> > > -# RTEMS Project (https://www.rtems.org/)
> > > -# Copyright (c) 2021 Vijay Kumar Banerjee <vijay at rtems.org>.
> > > -# All rights reserved.
> > > -#  Redistribution and use in source and binary forms, with or without
> > > -#  modification, are permitted provided that the following conditions
> > > -#  are met:
> > > -#  1. Redistributions of source code must retain the above copyright
> > > -#     notice, this list of conditions and the following disclaimer.
> > > -#  2. Redistributions in binary form must reproduce the above copyright
> > > -#     notice, this list of conditions and the following disclaimer in the
> > > -#     documentation and/or other materials provided with the distribution.
> > > -#  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> > > -#  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> > > -#  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
> > > -#  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
> > > -#  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> > > -#  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
> > > -#  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
> > > -#  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
> > > -#  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
> > > -#  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
> > > -#  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> > > -from rtems_waf import rtems
> > > -import os
> > > -def init(ctx):
> > > -    pass
> > > -def configure(conf):
> > > -    pass
> > > -def build(bld):
> > > -    source_files = []
> > > -    include_path = ['./', '../', os.path.relpath(bld.env.PREFIX)]
> > > -    arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> > > -                                            bld.env.RTEMS_ARCH_BSP)
> > > -    for root, dirs, files in os.walk('./nfsclient'):
> > > -        for name in files:
> > > -            if name[-2:] == '.c':
> > > -                src_root = root.split('/')[2]
> > > -                source_files.append(os.path.join(src_root, name))
> > > -    bld.stlib(target='nfs',
> > > -              features='c',
> > > -              cflags=['-O2', '-g'],
> > > -              includes=include_path,
> > > -              source=source_files)
> > > -    bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
> > > diff --git a/wscript b/wscript
> > > index 07f774d..7af317d 100644
> > > --- a/wscript
> > > +++ b/wscript
> > > @@ -33,7 +33,7 @@ import sys
> > >  top = '.'
> > >  rtems_version = "6"
> > > -subdirs = ['nfsclient', 'testsuites']
> > > +subdirs = ['testsuites']
> > >  try:
> > >      import rtems_waf.rtems as rtems
> > > 2.26.2
