#3860 - GSoC enquiries
Ida Delphine idadelm at gmail.com
Thu Apr 8 06:19:54 UTC 2021
I just did.
On Thu, 8 Apr 2021, 7:11 am Gedare Bloom, <gedare at rtems.org> wrote:
> Please enable commenting
> On Wed, Apr 7, 2021 at 11:51 PM Ida Delphine <idadelm at gmail.com> wrote:
> > Hello everyone,
> > Here is the link to my GSoC proposal. Will love if you leave comments on
> ways I could make it better or any corrections (Especially the Proposesd
> Schedule section so that I will be sure about my project deliverables when
> inputting them).
> https://docs.google.com/document/d/1VADJh3_kIhs578IEmBJ98rjR6p5E1XcksUkq1Ms4jRA/edit?usp=sharing
> > I will also love to know about any future improvements to this project.
> > Cheers,
> > Ida.
> > On Wed, Apr 7, 2021 at 5:27 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Wed, Apr 7, 2021 at 10:11 AM Ida Delphine <idadelm at gmail.com> wrote:
> >> > Hello,
> >> > In case I succeed with this project will I be required to do some
> documentation on how it works?
> >> Yes, in general we expect students to produce documentation while they
> >> work on also creating code.
> >> I think the direction we're heading right now is toward using
> >> clang-format, perhaps with an update to a common coding style. In this
> >> case, we solve our problem by policy rather than technical solution,
> >> and your work should focus on tool integration and automation without
> >> concern about the coding style itself.
> >> > On Wed, Apr 7, 2021 at 9:51 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >> >> On 07/04/2021 09:03, Chris Johns wrote:
> >> >> > Would it be pragmatic to review these cases and change the
> standard?
> >> >> I sent a patch to review the format changes done by clang-format
> recently:
> >> >> https://lists.rtems.org/pipermail/devel/2021-April/066311.html
> >> >> It doesn't look that bad from my point of view. Fixing the alignment
> >> >> issue would make it even better:
> >> >> https://reviews.llvm.org/D27651
> >> >> > I understand the long history but as you point out we either
> invest in the tools
> >> >> > to support the format, we change what we have or we manage it
> manually.
> >> >> I would prefer to change the style and use a widely used formatting
> >> >> tool. I think we spend to much time on the coding style in reviews.
> This
> >> >> is quite bad since we are all busy with all sorts of things and our
> time
> >> >> is better spent on more important tasks. A consistently formatted
> source
> >> >> code is very important, but enforcing this style manually is a waste
> of
> >> >> time.
> >> >> embedded brains GmbH
> >> >> Herr Sebastian HUBER
> >> >> Dornierstr. 4
> >> >> 82178 Puchheim
> >> >> Germany
> >> >> email: sebastian.huber at embedded-brains.de
> >> >> phone: +49-89-18 94 741 - 16
> >> >> fax:   +49-89-18 94 741 - 08
> >> >> Registergericht: Amtsgericht München
> >> >> Registernummer: HRB 157899
> >> >> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> >> >> Unsere Datenschutzerklärung finden Sie hier:
> >> >> https://embedded-brains.de/datenschutzerklaerung/
> >> >> _______________________________________________
> >> >> devel mailing list
> >> >> devel at rtems.org
> >> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210408/31b4787f/attachment.html>
