#3860 - GSoC enquiries
Thu Apr 8 06:11:10 UTC 2021
Please enable commenting
On Wed, Apr 7, 2021 at 11:51 PM Ida Delphine <idadelm at gmail.com> wrote:
> Hello everyone,
> Here is the link to my GSoC proposal. Will love if you leave comments on ways I could make it better or any corrections (Especially the Proposesd Schedule section so that I will be sure about my project deliverables when inputting them).
> https://docs.google.com/document/d/1VADJh3_kIhs578IEmBJ98rjR6p5E1XcksUkq1Ms4jRA/edit?usp=sharing
> I will also love to know about any future improvements to this project.
> Cheers,
> Ida.
> On Wed, Apr 7, 2021 at 5:27 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, Apr 7, 2021 at 10:11 AM Ida Delphine <idadelm at gmail.com> wrote:
>> > Hello,
>> > In case I succeed with this project will I be required to do some documentation on how it works?
>> Yes, in general we expect students to produce documentation while they
>> work on also creating code.
>> I think the direction we're heading right now is toward using
>> clang-format, perhaps with an update to a common coding style. In this
>> case, we solve our problem by policy rather than technical solution,
>> and your work should focus on tool integration and automation without
>> concern about the coding style itself.
>> > On Wed, Apr 7, 2021 at 9:51 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> >> On 07/04/2021 09:03, Chris Johns wrote:
>> >> > Would it be pragmatic to review these cases and change the standard?
>> >> I sent a patch to review the format changes done by clang-format recently:
>> >> https://lists.rtems.org/pipermail/devel/2021-April/066311.html
>> >> It doesn't look that bad from my point of view. Fixing the alignment
>> >> issue would make it even better:
>> >> https://reviews.llvm.org/D27651
>> >> > I understand the long history but as you point out we either invest in the tools
>> >> > to support the format, we change what we have or we manage it manually.
>> >> I would prefer to change the style and use a widely used formatting
>> >> tool. I think we spend to much time on the coding style in reviews. This
>> >> is quite bad since we are all busy with all sorts of things and our time
>> >> is better spent on more important tasks. A consistently formatted source
>> >> code is very important, but enforcing this style manually is a waste of
>> >> time.
>> >> embedded brains GmbH
>> >> Herr Sebastian HUBER
>> >> Dornierstr. 4
>> >> 82178 Puchheim
>> >> Germany
>> >> email: sebastian.huber at embedded-brains.de
>> >> phone: +49-89-18 94 741 - 16
>> >> fax:   +49-89-18 94 741 - 08
>> >> Registergericht: Amtsgericht München
>> >> Registernummer: HRB 157899
>> >> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> >> Unsere Datenschutzerklärung finden Sie hier:
>> >> https://embedded-brains.de/datenschutzerklaerung/
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
