[PATCH] covoar/TargetBase.h: Remove unused member variables
Joel Sherrill
joel at rtems.org
Sat Apr 10 23:55:53 UTC 2021
Both flagged by CID #1399638.
tester/covoar/TargetBase.h | 13 -------------
1 file changed, 13 deletions(-)
diff --git a/tester/covoar/TargetBase.h b/tester/covoar/TargetBase.h
index d13216d..6db08f2 100644
--- a/tester/covoar/TargetBase.h
+++ b/tester/covoar/TargetBase.h
@@ -122,19 +122,6 @@ namespace Target {
std::string targetName_m;
- * This member variable indicates either the column that the instruction
- * starts in the object dump file, when the objdump has no tabs; or the
- * number of tabs to find the instruction.
- int objdumpInstructionLocation;
- * This member variable indicates whether or not the objdump has
- * tabs as delemeters.
- bool objdumpHasTabs;
* This member variable is an array of all conditional branch instructions
* for this target.
1.8.3.1
