[PATCH] covoar/TargetBase.h: Remove unused member variables
Mon Apr 12 18:45:28 UTC 2021
ok
On Sat, Apr 10, 2021 at 5:56 PM Joel Sherrill <joel at rtems.org> wrote:
> Both flagged by CID #1399638.
>  tester/covoar/TargetBase.h | 13 -------------
>  1 file changed, 13 deletions(-)
> diff --git a/tester/covoar/TargetBase.h b/tester/covoar/TargetBase.h
> index d13216d..6db08f2 100644
> --- a/tester/covoar/TargetBase.h
> +++ b/tester/covoar/TargetBase.h
> @@ -122,19 +122,6 @@ namespace Target {
>      std::string    targetName_m;
> -     * This member variable indicates either the column that the instruction
> -     * starts in the object dump file, when the objdump has no tabs; or the
> -     * number of tabs to find the instruction.
> -    int objdumpInstructionLocation;
> -     *  This member variable indicates whether or not the objdump has
> -     *  tabs as delemeters.
> -    bool objdumpHasTabs;
>       * This member variable is an array of all conditional branch instructions
>       * for this target.
> 1.8.3.1
> devel mailing list
> devel at rtems.org
