#3860 - GSoC enquiries
Ida Delphine idadelm at gmail.com
Mon Apr 12 05:40:48 UTC 2021
Hello all,
I made some changes to my initial proposal draft based on some feedback I
got. Here's is the modified version. Please help me review and suggest
improvements.
https://docs.google.com/document/d/1VADJh3_kIhs578IEmBJ98rjR6p5E1XcksUkq1Ms4jRA/edit?usp=sharing
Cheers,
Ida.
On Fri, Apr 9, 2021 at 1:51 AM Ida Delphine <idadelm at gmail.com> wrote:
> Hello All,
> Just a gentle reminder to please help me review this my proposal draft and
> help me with ways to make it better :)
> Cheers,
> Ida
> On Thu, 8 Apr 2021, 6:51 am Ida Delphine, <idadelm at gmail.com> wrote:
>> Hello everyone,
>> Here is the link to my GSoC proposal. Will love if you leave comments on
>> ways I could make it better or any corrections (Especially the *Proposesd
>> Schedule* section so that I will be sure about my project deliverables
>> when inputting them).
>> I will also love to know about any future improvements to this project.
>> Cheers,
>> Ida.
>> On Wed, Apr 7, 2021 at 5:27 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Apr 7, 2021 at 10:11 AM Ida Delphine <idadelm at gmail.com> wrote:
>>> > Hello,
>>> > In case I succeed with this project will I be required to do some
>>> documentation on how it works?
>>> Yes, in general we expect students to produce documentation while they
>>> work on also creating code.
>>> I think the direction we're heading right now is toward using
>>> clang-format, perhaps with an update to a common coding style. In this
>>> case, we solve our problem by policy rather than technical solution,
>>> and your work should focus on tool integration and automation without
>>> concern about the coding style itself.
>>> > On Wed, Apr 7, 2021 at 9:51 AM Sebastian Huber <
>>> sebastian.huber at embedded-brains.de> wrote:
>>> >> On 07/04/2021 09:03, Chris Johns wrote:
>>> >> > Would it be pragmatic to review these cases and change the standard?
>>> >> I sent a patch to review the format changes done by clang-format
>>> recently:
>>> >> https://lists.rtems.org/pipermail/devel/2021-April/066311.html
>>> >> It doesn't look that bad from my point of view. Fixing the alignment
>>> >> issue would make it even better:
>>> >> https://reviews.llvm.org/D27651
>>> >> > I understand the long history but as you point out we either invest
>>> in the tools
>>> >> > to support the format, we change what we have or we manage it
>>> manually.
>>> >> I would prefer to change the style and use a widely used formatting
>>> >> tool. I think we spend to much time on the coding style in reviews.
>>> This
>>> >> is quite bad since we are all busy with all sorts of things and our
>>> time
>>> >> is better spent on more important tasks. A consistently formatted
>>> source
>>> >> code is very important, but enforcing this style manually is a waste
>>> of
>>> >> time.
>>> >> embedded brains GmbH
>>> >> Herr Sebastian HUBER
>>> >> Dornierstr. 4
>>> >> 82178 Puchheim
>>> >> Germany
>>> >> email: sebastian.huber at embedded-brains.de
>>> >> phone: +49-89-18 94 741 - 16
>>> >> fax:   +49-89-18 94 741 - 08
>>> >> Registergericht: Amtsgericht München
>>> >> Registernummer: HRB 157899
>>> >> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
>>> Dörfler
>>> >> Unsere Datenschutzerklärung finden Sie hier:
>>> >> https://embedded-brains.de/datenschutzerklaerung/
>>> >> _______________________________________________
>>> >> devel mailing list
>>> >> devel at rtems.org
>>> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210412/cfdcd504/attachment.html>
