How to run the full RTEMS testsuite
Ida Delphine idadelm at gmail.com
Mon Apr 12 05:41:49 UTC 2021
Thanks, I'll check it out.
On Sun, Apr 11, 2021 at 6:57 AM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> On 11-Apr-2021, at 1:15 AM, Ida Delphine <idadelm at gmail.com> wrote:
> For some reason I get this:
> rtems-test: command not found
> I've used this command a few times and it worked. I don't know what I
> am doing wrong now...
> Any idea what I am doing wrong?
> Did you add the path to the toolchain to your $PATH variable in the
> terminal ? (This might be a reason )
> Or rtems-test isn’t built for the bsp you are using try looking into
> rtems-testing repo
> On Sat, Apr 10, 2021 at 12:43 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> Hi
>> You can use rtems-test to run tests in a directory
>> Eg :
>> rtems-test --rtems-bsp=erc32-run --rtems-tools=$HOME/development/rtems/5 ~/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples
>> Thanks
>> Eshan
>> On 10-Apr-2021, at 5:01 PM, Ida Delphine <idadelm at gmail.com> wrote:
>> Hello everyone,
>> I'm looking forward to work on automatic style checking and code
>> formatting for RTEMS as my GSoC project and will need to test that style
>> changes do not cause any implementation bugs. I will carryout this test by
>> running the full RTEMS testsuite. I've tried looking in the RTEMS
>> documentation for a detailed step by step guide on how to do this but I
>> can't find anything helpful. Can someone please guide me on how to achieve
>> this?
>> Cheers,
>> Ida.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210412/8e0ec696/attachment.html>
