How to run the full RTEMS testsuite
Eshan Dhawan eshandhawan51 at gmail.com
Sun Apr 11 05:57:27 UTC 2021
> On 11-Apr-2021, at 1:15 AM, Ida Delphine <idadelm at gmail.com> wrote:
> For some reason I get this:
> rtems-test: command not found
> I've used this command a few times and it worked. I don't know what I am doing wrong now...
> Any idea what I am doing wrong?
Did you add the path to the toolchain to your $PATH variable in the terminal ? (This might be a reason )
Or rtems-test isn’t built for the bsp you are using try looking into rtems-testing repo
>> On Sat, Apr 10, 2021 at 12:43 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> Hi
>> You can use rtems-test to run tests in a directory
>> Eg :
>> rtems-test --rtems-bsp=erc32-run --rtems-tools=$HOME/development/rtems/5 ~/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples
>> Thanks
>> Eshan
>>> On 10-Apr-2021, at 5:01 PM, Ida Delphine <idadelm at gmail.com> wrote:
>>> Hello everyone,
>>> I'm looking forward to work on automatic style checking and code formatting for RTEMS as my GSoC project and will need to test that style changes do not cause any implementation bugs. I will carryout this test by running the full RTEMS testsuite. I've tried looking in the RTEMS documentation for a detailed step by step guide on how to do this but I can't find anything helpful. Can someone please guide me on how to achieve this?
>>> Cheers,
>>> Ida.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210411/f36b6ca5/attachment.html>
