[PATCH 0/3] rtemstoolkit: Add SMTP login to mailer
Mon Apr 12 23:47:22 UTC 2021
Hi Alex,
This looks great. Thank you for adding this feature. OK to push.
Do you think a small section called "Posting Reports" that explains how to use
these options, ie with GMail, would be good to have?
On 13/4/21 6:22 am, Alex White wrote:
> This patch set includes changes to allow for authentication with the
> SMTP host using login information provided by command line options.
> This allows, for example, standard Gmail or Outlook STMP servers to be
> specified for the `--smtp-host` option.
> Alex White (3):
>   rtemstoolkit/mailer.py: Return full smtp-host arg value
>   rtemstoolkit: Filter mail options from log output
>   rtemstoolkit/mailer.py: Add SMTP login options
>  rtemstoolkit/mailer.py  | 43 ++++++++++++++++++++++++++++++++++-------
>  rtemstoolkit/options.py | 17 +++++++++++++++-
>  2 files changed, 52 insertions(+), 8 deletions(-)
