[PATCH 0/3] rtemstoolkit: Add SMTP login to mailer
Tue Apr 13 02:09:12 UTC 2021
On Mon, Apr 12, 2021, 6:47 PM Chris Johns <chrisj at rtems.org> wrote:
> Hi Alex,
> This looks great. Thank you for adding this feature. OK to push.
> Do you think a small section called "Posting Reports" that explains how to
> use
> these options, ie with GMail, would be good to have?
Yes. And it would be even better after it can read your . gitconfig for
sendemail options. We would be encouraging people to have E git send-email
and all the RTEMS tools able to send. :)
Alex.. does this all.need to go to both rsb and tester?
The docs probably should also tell how to get through Office365.
> Chris
> On 13/4/21 6:22 am, Alex White wrote:
> > This patch set includes changes to allow for authentication with the
> > SMTP host using login information provided by command line options.
> > This allows, for example, standard Gmail or Outlook STMP servers to be
> > specified for the `--smtp-host` option.
> > Alex White (3):
> >   rtemstoolkit/mailer.py: Return full smtp-host arg value
> >   rtemstoolkit: Filter mail options from log output
> >   rtemstoolkit/mailer.py: Add SMTP login options
> >  rtemstoolkit/mailer.py  | 43 ++++++++++++++++++++++++++++++++++-------
> >  rtemstoolkit/options.py | 17 +++++++++++++++-
> >  2 files changed, 52 insertions(+), 8 deletions(-)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210412/1bbf8e96/attachment.html>
