AW: [PATCH 0/1] grlib/genirq: Issue when enabling/disabling interrupt
    Gabriel.Moyano at dlr.de
    Tue Apr 13 05:35:16 UTC 2021
Yes, rtems 5 also has it. I can create a ticket.
Regarding the proposed solution, I wanted to start a thread for discussing it (maybe there is better was to do it).
>Is this a bug in rtems 5 also?
>If so, does it warrant a back-port fix and a ticket?
>On Mon, Apr 12, 2021 at 3:16 AM Moyano, Gabriel <gabriel.moyano at dlr.de> wrote:
>> Hello everyone,
>> I've found what can be an issue in the function genirq_set_active(): under some conditions it can return a value greater than 1.
>> This function is used by genirq_enable() and genirq_disable() and both of them returns the value returned by genirq_set_active(). According to the documentation in genirq.h, they should return -1, 0 or 1.
>> When this issue can happen? If there are 3 entries in the list of IRQ and 2 of them are already enabled, the variable `enabled` would be 2, because of `enabled += isrentry->enabled`.
>> As a possible solution, the value of `enabled` can changed to 1 if it's greater than 1 (see the patch) or maybe improve the search.
>> Thanks in advance,
>> Gabriel Moyano
>> Moyano, Gabriel (1):
>>   grlib/genirq: Taking into account that it could be more than one ISR
>>     enabled/disabled
>>  bsps/shared/grlib/irq/genirq.c | 5 +++++
>>  1 file changed, 5 insertions(+)
