AW: [PATCH 0/1] grlib/genirq: Issue when enabling/disabling interrupt
Gabriel.Moyano at dlr.de Gabriel.Moyano at dlr.de
Tue Apr 13 08:08:38 UTC 2021
>Yes, rtems 5 also has it. I can create a ticket.
Here is the link to the ticket https://devel.rtems.org/ticket/4385#ticket.
BTW the proposed solution for the master branch can be also applied to 5 as well.
>Regarding the proposed solution, I wanted to start a thread for discussing it (maybe there is better was to do it).
>>Is this a bug in rtems 5 also?
>>If so, does it warrant a back-port fix and a ticket?
>>On Mon, Apr 12, 2021 at 3:16 AM Moyano, Gabriel <gabriel.moyano at dlr.de> wrote:
>>> Hello everyone,
>>> I've found what can be an issue in the function genirq_set_active(): under some conditions it can return a value greater than 1.
>>> This function is used by genirq_enable() and genirq_disable() and both of them returns the value returned by genirq_set_active(). According to the documentation in genirq.h, they should return -1, 0 or 1.
>>> When this issue can happen? If there are 3 entries in the list of IRQ and 2 of them are already enabled, the variable `enabled` would be 2, because of `enabled += isrentry->enabled`.
>>> As a possible solution, the value of `enabled` can changed to 1 if it's greater than 1 (see the patch) or maybe improve the search.
>>> Thanks in advance,
>>> Gabriel Moyano
>>> Moyano, Gabriel (1):
>>>   grlib/genirq: Taking into account that it could be more than one ISR
>>>     enabled/disabled
>>>  bsps/shared/grlib/irq/genirq.c | 5 +++++
>>>  1 file changed, 5 insertions(+)
